Re: NOAA Weather Plus discussions
Posted: Thu Nov 21, 2013 8:55 am
Never mind. Apparently some combination of those things tried again in the last 10 minutes did the trick. I have no idea what went wrong or how I "fixed" it.
Software Support and Home Automation Forum
https://forums.indigodomo.com/
NOAA Weather Plus Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 246, in runConcurrentThread
File "plugin.py", line 528, in update
<type 'exceptions.ValueError'>: need more than 1 value to unpack
Stopped plugin "NOAA Weather Plus 1.1.15"
Starting plugin "NOAA Weather Plus 1.1.15" (pid 6147)
NOAA Weather Plus Debug Initializing Plugin.
Started plugin "NOAA Weather Plus 1.1.15"
NOAA Weather Plus Debug Starting device: Weather (Irvine)
NOAA Weather Plus Debug Updating weather for device: Weather (Irvine)
NOAA Weather Plus Debug Device Weather (Irvine) using URL http://forecast.weather.gov/MapClick.php?FcstType=dwml&lg=english&lat=00.000&lon=-000.00
NOAA Weather Plus Debug Attempt # 1 at downloading and parsing weather data.
NOAA Weather Plus Debug Device Weather (Irvine) reading returned weather data.
NOAA Weather Plus Debug Device Weather (Irvine) parsing weather XML data.
NOAA Weather Plus Debug Device Weather (Irvine) locating "data" elements in XML.
NOAA Weather Plus Debug Device Weather (Irvine) found forecast data.
NOAA Weather Plus Debug Device Weather (Irvine) found current observation data.
NOAA Weather Plus Debug Device Weather (Irvine) looking for observation location coordinate data.
NOAA Weather Plus Debug Device Weather (Irvine) found latitude xx.xxxxx, longitude -xxx.xxxxx
NOAA Weather Plus Debug Device Weather (Irvine) looking for observation time.
NOAA Weather Plus Debug Device Weather (Irvine) observation time listed is "NA."
NOAA Weather Plus Error exception in deviceStartComm(Weather (Irvine)): need more than 1 value to unpack
NOAA Weather Plus Debug Starting runConcurrentThread.
Dec 5, 2013 21:46:17
NOAA Weather Plus Error Error in plugin execution ServerReplacedElem:
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 852, in deviceUpdated
File "plugin.py", line 217, in deviceStartComm
File "plugin.py", line 1224, in update
<type 'exceptions.UnboundLocalError'>: local variable 'e' referenced before assignment
nsheldon wrote:If it's the one I'm thinking of, I've seen the point forecast from NOAA. It has a lot of interesting and useful stats and predictions for mostly niche circumstances. I can see the value in adding it to the plugin, but I don't think I'm going to have the time to do that as it would require fairly significant modifications to the code (and list of device states). If you know some Python, you could probably modify the NOAA Weather Plus plugin code for your own purposes though.
