Hi Nathan,
Hopefully this is what you need, I have 48 hue lights so the log is pretty long
. The bulb is named "Back Yard Pergola 1". Thanks again for your help and fast response.
Hue Lights Debug Got response {u'42': {u'swversion': u'5.130.1.30000', u'name': u'Hue go', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:19'}, u'uniqueid': u'00:17:88:01:01:15:6d:87-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue go', u'state': {u'on': True, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3804, 0.3768], u'reachable': True, u'mode': u'homeautomation', u'bri': 100, u'ct': 247, u'sat': 0}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'huego'}, u'type': u'Extended color light', u'modelid': u'LLC020'}, u'43': {u'swversion': u'1.50.2_r30933', u'name': u'Garage Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:31:50'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:54:e2:95-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 39820, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3638, 0.3687], u'reachable': True, u'mode': u'homeautomation', u'bri': 204, u'ct': 226, u'sat': 19}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'731A795D', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'49': {u'swversion': u'1.65.11_hB798F2', u'name': u'Backyard Pergola 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-12-08T22:18:49'}, u'productid': u'Philips-LTD010-1-DownWA_ML_v1', u'uniqueid': u'00:17:88:01:09:0a:68:a5-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 700, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'372E4961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Color temperature light', u'modelid': u'LTD010'}, u'52': {u'swversion': u'1.65.11_hB798F2', u'name': u'Back Yard Pergola 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-12-11T22:45:37'}, u'productid': u'Philips-LTD010-1-DownWA_ML_v1', u'uniqueid': u'00:17:88:01:09:0a:6e:ea-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 700, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'372E4961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Color temperature light', u'modelid': u'LTD010'}, u'24': {u'swversion': u'5.130.1.30000', u'name': u'Addison\u2019s Room 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:33:46'}, u'uniqueid': u'00:17:88:01:10:44:94:17-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 800, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT007'}, u'25': {u'swversion': u'5.130.1.30000', u'name': u'Addison\u2019s Room 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:33:41'}, u'uniqueid': u'00:17:88:01:10:44:a1:29-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 800, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT007'}, u'26': {u'swversion': u'5.130.1.30000', u'name': u'Matster Bedroom', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:34:04'}, u'uniqueid': u'00:17:88:01:10:50:c1:74-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'27': {u'swversion': u'5.127.1.26581', u'name': u'Pantry', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:05:33'}, u'uniqueid': u'00:17:88:01:00:f4:da:97-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 16630, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4072, 0.3928], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 289, u'sat': 56}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'20': {u'swversion': u'5.127.1.26581', u'name': u'Garage Rafter 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:05:49'}, u'uniqueid': u'00:17:88:01:00:ee:de:e8-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': True, u'hue': 16630, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4072, 0.3928], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 289, u'sat': 56}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'21': {u'swversion': u'5.130.1.30000', u'name': u'Front Yard Tree 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:34:10'}, u'uniqueid': u'00:17:88:01:00:e8:72:73-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'22': {u'swversion': u'5.130.1.30000', u'name': u'Chandelier 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:36:26'}, u'uniqueid': u'00:17:88:01:10:3b:54:f0-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 800, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT007'}, u'23': {u'swversion': u'5.130.1.30000', u'name': u'Chandelier 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:36:03'}, u'uniqueid': u'00:17:88:01:10:54:45:c6-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 800, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT007'}, u'46': {u'swversion': u'1.46.13_r26312', u'name': u'Front Yard Tree 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:03:28'}, u'productid': u'Philips-LWB015-1-PAR38DLv1', u'uniqueid': u'00:17:88:01:03:1d:38:36-0b', u'capabilities': {u'control': {u'mindimlevel': 5000}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'8B1FA8F3', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB015'}, u'47': {u'swversion': u'1.65.11_hB798F2', u'name': u'Backyard Pergola 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-12-07T00:52:11'}, u'productid': u'Philips-LTD010-1-DownWA_ML_v1', u'uniqueid': u'00:17:88:01:09:0a:6f:93-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 700, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'372E4961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Color temperature light', u'modelid': u'LTD010'}, u'44': {u'swversion': u'1.50.2_r30933', u'name': u'Garage Door Hue Bulb', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:11'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:4b:22:53-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 89, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'AC54D87F', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'45': {u'swversion': u'1.46.13_r26312', u'name': u'Front Yard Tree 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:02:52'}, u'productid': u'Philips-LWB015-1-PAR38DLv1', u'uniqueid': u'00:17:88:01:04:b0:16:94-0b', u'capabilities': {u'control': {u'mindimlevel': 5000}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'8B1FA8F3', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB015'}, u'28': {u'swversion': u'5.127.1.26581', u'name': u'Wine Rack', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:05:27'}, u'uniqueid': u'00:17:88:01:00:cb:f8:5e-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue lightstrip', u'state': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.489, 0.3831], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'sat': 51}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Color light', u'modelid': u'LST001'}, u'29': {u'swversion': u'5.127.1.26581', u'name': u'Addison\u2019s Hue Iris', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:05:10'}, u'uniqueid': u'00:17:88:01:00:11:bf:75-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 210, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue iris', u'state': {u'on': True, u'hue': 56536, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4722, 0.2001], u'reachable': True, u'mode': u'homeautomation', u'bri': 76, u'sat': 254}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'upwards', u'archetype': u'hueiris'}, u'type': u'Color light', u'modelid': u'LLC010'}, u'40': {u'swversion': u'1.50.2_r30933', u'name': u'Office 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:03'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:70:84:51-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8348, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.462, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 374, u'sat': 147}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'731A795D', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'41': {u'swversion': u'1.50.2_r30933', u'name': u'Office 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:31:57'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:70:88:21-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8348, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.462, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 374, u'sat': 147}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'731A795D', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'3': {u'swversion': u'5.127.1.26581', u'name': u'Garage Rafters 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-22T15:44:52'}, u'uniqueid': u'00:17:88:01:00:b8:20:c3-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'2': {u'swversion': u'5.127.1.26581', u'name': u'Garage Rafters 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-22T15:44:49'}, u'uniqueid': u'00:17:88:01:00:b4:d2:51-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'5': {u'swversion': u'5.127.1.26581', u'name': u'Garage Door 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-22T15:44:56'}, u'uniqueid': u'00:17:88:01:00:ba:51:50-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'6': {u'swversion': u'5.127.1.26581', u'name': u'Front Door', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-22T15:45:01'}, u'uniqueid': u'00:17:88:01:00:ba:65:93-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'9': {u'swversion': u'5.127.1.26581', u'name': u'Dining Room 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:52'}, u'uniqueid': u'00:17:88:01:00:bb:30:24-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': True, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'8': {u'swversion': u'5.127.1.26581', u'name': u'Garage Door 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:57'}, u'uniqueid': u'00:17:88:01:00:ba:f6:ca-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'51': {u'swversion': u'1.65.11_hB798F2', u'name': u'Back Yard Pergola 5', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-12-11T22:45:42'}, u'productid': u'Philips-LTD010-1-DownWA_ML_v1', u'uniqueid': u'00:17:88:01:09:0a:69:08-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 700, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'372E4961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Color temperature light', u'modelid': u'LTD010'}, u'39': {u'swversion': u'5.130.1.30000', u'name': u'Home Kit Trigger Bulb', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:25'}, u'uniqueid': u'00:17:88:01:10:52:d4:0d-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'38': {u'swversion': u'5.130.1.30000', u'name': u'Front Path 6', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:34'}, u'uniqueid': u'00:17:88:01:10:52:d8:32-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'11': {u'swversion': u'5.127.1.26581', u'name': u'Entryway 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:03:02'}, u'uniqueid': u'00:17:88:01:00:b3:eb:c2-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'10': {u'swversion': u'5.127.1.26581', u'name': u'Dining Room 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:46'}, u'uniqueid': u'00:17:88:01:00:bb:1d:c4-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': True, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'13': {u'swversion': u'5.127.1.26581', u'name': u'Entryway 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:24'}, u'uniqueid': u'00:17:88:01:00:d0:6e:28-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'12': {u'swversion': u'5.127.1.26581', u'name': u'Hallway 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:30'}, u'uniqueid': u'00:17:88:01:00:b3:e2:f6-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'15': {u'swversion': u'5.127.1.26581', u'name': u'Front Arch 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:14'}, u'uniqueid': u'00:17:88:01:00:ee:fa:dd-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'14': {u'swversion': u'5.127.1.26581', u'name': u'Hallway 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:19'}, u'uniqueid': u'00:17:88:01:00:bb:6d:c6-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'17': {u'swversion': u'5.127.1.26581', u'name': u'Front Arch 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:06'}, u'uniqueid': u'00:17:88:01:00:ee:f7:79-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'16': {u'swversion': u'5.127.1.26581', u'name': u'Front Arch 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:03:23'}, u'uniqueid': u'00:17:88:01:00:ee:fa:6e-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'19': {u'swversion': u'5.127.1.26581', u'name': u'Garage Rafter 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:05:55'}, u'uniqueid': u'00:17:88:01:00:f3:32:7e-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': True, u'hue': 16630, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4072, 0.3928], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 289, u'sat': 56}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'32': {u'swversion': u'5.130.1.30000', u'name': u'Front Path 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:33:10'}, u'uniqueid': u'00:17:88:01:10:2f:2d:8e-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'31': {u'swversion': u'5.130.1.30000', u'name': u'Front Boulders 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:33:16'}, u'uniqueid': u'00:17:88:01:10:35:7e:2f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'30': {u'swversion': u'5.130.1.30000', u'name': u'Front Boulders 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:33:25'}, u'uniqueid': u'00:17:88:01:10:35:8b:3d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'37': {u'swversion': u'5.130.1.30000', u'name': u'Front Yard Side', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:43'}, u'uniqueid': u'00:17:88:01:10:3c:58:aa-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'36': {u'swversion': u'5.130.1.30000', u'name': u'Front Path 5', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:51'}, u'uniqueid': u'00:17:88:01:10:2d:c5:e9-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'35': {u'swversion': u'5.130.1.30000', u'name': u'Front Path 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:57'}, u'uniqueid': u'00:17:88:01:10:2f:af:9f-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'34': {u'swversion': u'5.130.1.30000', u'name': u'Front Path 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:31:40'}, u'uniqueid': u'00:17:88:01:10:2d:c8:b4-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'33': {u'swversion': u'5.130.1.30000', u'name': u'Front Path 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:33:02'}, u'uniqueid': u'00:17:88:01:10:2c:cb:36-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'48': {u'swversion': u'1.65.11_hB798F2', u'name': u'Backyard Pergola 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-12-08T22:18:54'}, u'productid': u'Philips-LTD010-1-DownWA_ML_v1', u'uniqueid': u'00:17:88:01:09:0a:73:67-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 700, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'372E4961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Color temperature light', u'modelid': u'LTD010'}, u'50': {u'swversion': u'1.65.11_hB798F2', u'name': u'Backyard Barbecue', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-12-08T22:18:44'}, u'productid': u'Philips-LTD010-1-DownWA_ML_v1', u'uniqueid': u'00:17:88:01:09:0a:6c:a1-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 700, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'372E4961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Color temperature light', u'modelid': u'LTD010'}}
Hue Lights Debug Loaded lights list - {u'42': {u'swversion': u'5.130.1.30000', u'name': u'Hue go', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:19'}, u'uniqueid': u'00:17:88:01:01:15:6d:87-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue go', u'state': {u'on': True, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3804, 0.3768], u'reachable': True, u'mode': u'homeautomation', u'bri': 100, u'ct': 247, u'sat': 0}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'huego'}, u'type': u'Extended color light', u'modelid': u'LLC020'}, u'43': {u'swversion': u'1.50.2_r30933', u'name': u'Garage Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:31:50'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:54:e2:95-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 39820, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3638, 0.3687], u'reachable': True, u'mode': u'homeautomation', u'bri': 204, u'ct': 226, u'sat': 19}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'731A795D', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'49': {u'swversion': u'1.65.11_hB798F2', u'name': u'Backyard Pergola 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-12-08T22:18:49'}, u'productid': u'Philips-LTD010-1-DownWA_ML_v1', u'uniqueid': u'00:17:88:01:09:0a:68:a5-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 700, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'372E4961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Color temperature light', u'modelid': u'LTD010'}, u'52': {u'swversion': u'1.65.11_hB798F2', u'name': u'Back Yard Pergola 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-12-11T22:45:37'}, u'productid': u'Philips-LTD010-1-DownWA_ML_v1', u'uniqueid': u'00:17:88:01:09:0a:6e:ea-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 700, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'372E4961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Color temperature light', u'modelid': u'LTD010'}, u'24': {u'swversion': u'5.130.1.30000', u'name': u'Addison\u2019s Room 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:33:46'}, u'uniqueid': u'00:17:88:01:10:44:94:17-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 800, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT007'}, u'25': {u'swversion': u'5.130.1.30000', u'name': u'Addison\u2019s Room 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:33:41'}, u'uniqueid': u'00:17:88:01:10:44:a1:29-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 800, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT007'}, u'26': {u'swversion': u'5.130.1.30000', u'name': u'Matster Bedroom', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:34:04'}, u'uniqueid': u'00:17:88:01:10:50:c1:74-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'27': {u'swversion': u'5.127.1.26581', u'name': u'Pantry', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:05:33'}, u'uniqueid': u'00:17:88:01:00:f4:da:97-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 16630, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4072, 0.3928], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 289, u'sat': 56}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'20': {u'swversion': u'5.127.1.26581', u'name': u'Garage Rafter 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:05:49'}, u'uniqueid': u'00:17:88:01:00:ee:de:e8-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': True, u'hue': 16630, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4072, 0.3928], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 289, u'sat': 56}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'21': {u'swversion': u'5.130.1.30000', u'name': u'Front Yard Tree 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:34:10'}, u'uniqueid': u'00:17:88:01:00:e8:72:73-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'22': {u'swversion': u'5.130.1.30000', u'name': u'Chandelier 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:36:26'}, u'uniqueid': u'00:17:88:01:10:3b:54:f0-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 800, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT007'}, u'23': {u'swversion': u'5.130.1.30000', u'name': u'Chandelier 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:36:03'}, u'uniqueid': u'00:17:88:01:10:54:45:c6-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 800, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT007'}, u'46': {u'swversion': u'1.46.13_r26312', u'name': u'Front Yard Tree 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:03:28'}, u'productid': u'Philips-LWB015-1-PAR38DLv1', u'uniqueid': u'00:17:88:01:03:1d:38:36-0b', u'capabilities': {u'control': {u'mindimlevel': 5000}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'8B1FA8F3', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB015'}, u'47': {u'swversion': u'1.65.11_hB798F2', u'name': u'Backyard Pergola 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-12-07T00:52:11'}, u'productid': u'Philips-LTD010-1-DownWA_ML_v1', u'uniqueid': u'00:17:88:01:09:0a:6f:93-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 700, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'372E4961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Color temperature light', u'modelid': u'LTD010'}, u'44': {u'swversion': u'1.50.2_r30933', u'name': u'Garage Door Hue Bulb', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:11'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:4b:22:53-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 89, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'AC54D87F', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'45': {u'swversion': u'1.46.13_r26312', u'name': u'Front Yard Tree 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:02:52'}, u'productid': u'Philips-LWB015-1-PAR38DLv1', u'uniqueid': u'00:17:88:01:04:b0:16:94-0b', u'capabilities': {u'control': {u'mindimlevel': 5000}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'8B1FA8F3', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB015'}, u'28': {u'swversion': u'5.127.1.26581', u'name': u'Wine Rack', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:05:27'}, u'uniqueid': u'00:17:88:01:00:cb:f8:5e-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue lightstrip', u'state': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.489, 0.3831], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'sat': 51}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Color light', u'modelid': u'LST001'}, u'29': {u'swversion': u'5.127.1.26581', u'name': u'Addison\u2019s Hue Iris', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:05:10'}, u'uniqueid': u'00:17:88:01:00:11:bf:75-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 210, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue iris', u'state': {u'on': True, u'hue': 56536, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4722, 0.2001], u'reachable': True, u'mode': u'homeautomation', u'bri': 76, u'sat': 254}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'upwards', u'archetype': u'hueiris'}, u'type': u'Color light', u'modelid': u'LLC010'}, u'40': {u'swversion': u'1.50.2_r30933', u'name': u'Office 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:03'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:70:84:51-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8348, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.462, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 374, u'sat': 147}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'731A795D', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'41': {u'swversion': u'1.50.2_r30933', u'name': u'Office 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:31:57'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:70:88:21-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8348, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.462, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 374, u'sat': 147}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'731A795D', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'3': {u'swversion': u'5.127.1.26581', u'name': u'Garage Rafters 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-22T15:44:52'}, u'uniqueid': u'00:17:88:01:00:b8:20:c3-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'2': {u'swversion': u'5.127.1.26581', u'name': u'Garage Rafters 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-22T15:44:49'}, u'uniqueid': u'00:17:88:01:00:b4:d2:51-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'5': {u'swversion': u'5.127.1.26581', u'name': u'Garage Door 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-22T15:44:56'}, u'uniqueid': u'00:17:88:01:00:ba:51:50-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'6': {u'swversion': u'5.127.1.26581', u'name': u'Front Door', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-22T15:45:01'}, u'uniqueid': u'00:17:88:01:00:ba:65:93-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'9': {u'swversion': u'5.127.1.26581', u'name': u'Dining Room 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:52'}, u'uniqueid': u'00:17:88:01:00:bb:30:24-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': True, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'8': {u'swversion': u'5.127.1.26581', u'name': u'Garage Door 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:57'}, u'uniqueid': u'00:17:88:01:00:ba:f6:ca-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'51': {u'swversion': u'1.65.11_hB798F2', u'name': u'Back Yard Pergola 5', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-12-11T22:45:42'}, u'productid': u'Philips-LTD010-1-DownWA_ML_v1', u'uniqueid': u'00:17:88:01:09:0a:69:08-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 700, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'372E4961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Color temperature light', u'modelid': u'LTD010'}, u'39': {u'swversion': u'5.130.1.30000', u'name': u'Home Kit Trigger Bulb', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:25'}, u'uniqueid': u'00:17:88:01:10:52:d4:0d-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'38': {u'swversion': u'5.130.1.30000', u'name': u'Front Path 6', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:34'}, u'uniqueid': u'00:17:88:01:10:52:d8:32-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'11': {u'swversion': u'5.127.1.26581', u'name': u'Entryway 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:03:02'}, u'uniqueid': u'00:17:88:01:00:b3:eb:c2-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'10': {u'swversion': u'5.127.1.26581', u'name': u'Dining Room 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:46'}, u'uniqueid': u'00:17:88:01:00:bb:1d:c4-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': True, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'13': {u'swversion': u'5.127.1.26581', u'name': u'Entryway 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:24'}, u'uniqueid': u'00:17:88:01:00:d0:6e:28-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'12': {u'swversion': u'5.127.1.26581', u'name': u'Hallway 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:30'}, u'uniqueid': u'00:17:88:01:00:b3:e2:f6-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'15': {u'swversion': u'5.127.1.26581', u'name': u'Front Arch 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:14'}, u'uniqueid': u'00:17:88:01:00:ee:fa:dd-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'14': {u'swversion': u'5.127.1.26581', u'name': u'Hallway 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:19'}, u'uniqueid': u'00:17:88:01:00:bb:6d:c6-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'17': {u'swversion': u'5.127.1.26581', u'name': u'Front Arch 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:06:06'}, u'uniqueid': u'00:17:88:01:00:ee:f7:79-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'16': {u'swversion': u'5.127.1.26581', u'name': u'Front Arch 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:03:23'}, u'uniqueid': u'00:17:88:01:00:ee:fa:6e-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'19': {u'swversion': u'5.127.1.26581', u'name': u'Garage Rafter 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-14T22:05:55'}, u'uniqueid': u'00:17:88:01:00:f3:32:7e-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': True, u'hue': 16630, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4072, 0.3928], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 289, u'sat': 56}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'32': {u'swversion': u'5.130.1.30000', u'name': u'Front Path 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:33:10'}, u'uniqueid': u'00:17:88:01:10:2f:2d:8e-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'31': {u'swversion': u'5.130.1.30000', u'name': u'Front Boulders 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:33:16'}, u'uniqueid': u'00:17:88:01:10:35:7e:2f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'30': {u'swversion': u'5.130.1.30000', u'name': u'Front Boulders 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:33:25'}, u'uniqueid': u'00:17:88:01:10:35:8b:3d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14850, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4621, 0.4111], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 374, u'sat': 148}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'37': {u'swversion': u'5.130.1.30000', u'name': u'Front Yard Side', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:43'}, u'uniqueid': u'00:17:88:01:10:3c:58:aa-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 15532, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4386, 0.4048], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 337, u'sat': 111}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'36': {u'swversion': u'5.130.1.30000', u'name': u'Front Path 5', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:51'}, u'uniqueid': u'00:17:88:01:10:2d:c5:e9-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'35': {u'swversion': u'5.130.1.30000', u'name': u'Front Path 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:32:57'}, u'uniqueid': u'00:17:88:01:10:2f:af:9f-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'34': {u'swversion': u'5.130.1.30000', u'name': u'Front Path 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:31:40'}, u'uniqueid': u'00:17:88:01:10:2d:c8:b4-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'33': {u'swversion': u'5.130.1.30000', u'name': u'Front Path 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T21:33:02'}, u'uniqueid': u'00:17:88:01:10:2c:cb:36-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'48': {u'swversion': u'1.65.11_hB798F2', u'name': u'Backyard Pergola 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-12-08T22:18:54'}, u'productid': u'Philips-LTD010-1-DownWA_ML_v1', u'uniqueid': u'00:17:88:01:09:0a:73:67-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 700, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'372E4961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Color temperature light', u'modelid': u'LTD010'}, u'50': {u'swversion': u'1.65.11_hB798F2', u'name': u'Backyard Barbecue', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-12-08T22:18:44'}, u'productid': u'Philips-LTD010-1-DownWA_ML_v1', u'uniqueid': u'00:17:88:01:09:0a:6c:a1-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 700, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'372E4961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Color temperature light', u'modelid': u'LTD010'}}
