Centura spots
Fri Oct 09, 2020 4:54 pm
Patje73 offline
Centura spots
I am not able to select the HUE Centura color spot.
The lights grouped together in a zone I can select as a whole zone but I cannot add the individual spots.
What am I doing wrong?
Thanks for your help.
Patrick
Fri Oct 09, 2020 5:06 pm
nsheldon offline
Re: Centura spots
Hi Patrick.
Thanks for the report.
It's unlikely you're doing anything wrong. Support has to be manually added to the plugin for every new type of light. Since I haven't heard of that one until now, support hasn't been added.
I can add support, but I need to know the exact model ID and the type of light (color, color temperature only, dimming only, etc). The easiest way to get that information is to enable debug logging for about 10 seconds (Plugins menu -> Hue Lights -> Toggle Debugging) and post the debug logs in your reply. It'll be big, so you'll need to tell me what name you've given one of the lights in the Hue app so I can find it in the debug log you post.
Mon Oct 12, 2020 2:35 pm
Patje73 offline
Re: Centura spots
below the log.
Names of the groups are "Keuken' and ' Insel' and ' keuken zonder insel' .
I found them in the logging.
Random website with the spots I am talking about : https://www.dmlights.com/philips_hue_ce ... nium~1876A
Thank you for your help! :-)
Hue Lights Turning on debug logging
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Debug Starting updateLightsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.6/api/IaSxK2JUBqRDC5EX ... zp2/lights
Hue Lights Debug Got response {u'24': {u'swversion': u'5.130.1.30000', u'name': u'Midden', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-04-07T09:04:47'}, u'uniqueid': u'00:17:88:01:04:a3:e2:fb-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'25': {u'swversion': u'1.50.2_r30933', u'name': u'TV rechts', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:26'}, u'productid': u'3241-3127-7871-LS00', u'uniqueid': u'00:17:88:01:06:53:e2:fe-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 100, u'maxlumen': 540, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue play', u'state': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'reachable': False, u'mode': u'homeautomation', u'bri': 89, u'ct': 370, u'sat': 143}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'949259E6', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'hueplay'}, u'type': u'Extended color light', u'modelid': u'LCT024'}, u'26': {u'swversion': u'1.50.2_r30933', u'name': u'TV Links', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:21'}, u'productid': u'3241-3127-7871-LS00', u'uniqueid': u'00:17:88:01:06:53:db:f9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 100, u'maxlumen': 540, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue play', u'state': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'reachable': False, u'mode': u'homeautomation', u'bri': 89, u'ct': 370, u'sat': 143}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'949259E6', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'hueplay'}, u'type': u'Extended color light', u'modelid': u'LCT024'}, u'27': {u'swversion': u'1.50.2_r30933', u'name': u'Leeslamp Kerstin', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:17'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:06:ec:8b:d9-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 144, u'ct': 443}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'20': {u'swversion': u'1.50.2_r30933', u'name': u'Wijnkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-05-24T20:37:46'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:39:49:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'none', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'28': {u'swversion': u'1.50.2_r30933', u'name': u'Leeslamp Patrick', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:31'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:06:ec:8b:d2-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 143, u'ct': 382}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'5': {u'swversion': u'1.50.2_r30933', u'name': u'Tafel', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:52'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:31:f7:f0-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 192, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'4': {u'swversion': u'1.50.2_r30933', u'name': u'Schilderij', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:36'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:e4:c9:f8-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 191, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'9': {u'swversion': u'1.50.2_r30933', u'name': u'Muur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:57'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:30:32:c7-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 191, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'8': {u'swversion': u'1.50.2_r30933', u'name': u'TV Kast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:13'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:02:9c:1b:14-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 6056, u'colormode': u'xy', u'effect': u'none', u'alert': u'lselect', u'xy': [0.5437, 0.3978], u'reachable': False, u'mode': u'homeautomation', u'bri': 102, u'ct': 454, u'sat': 221}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'59F2C3A3', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'38': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:41'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:4c:49-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'11': {u'swversion': u'5.130.1.30000', u'name': u'Rechts', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:42'}, u'uniqueid': u'00:17:88:01:10:27:92:4f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'13': {u'swversion': u'1.50.2_r30933', u'name': u'Rechtsboven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:41'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:93:32:7a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 47423, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.1823, 0.0815], u'reachable': False, u'mode': u'homeautomation', u'bri': 194, u'ct': 454, u'sat': 231}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'292E579A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'12': {u'swversion': u'1.50.2_r30933', u'name': u'Staanlamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:46'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:d8:d0:6a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5035, 0.4086], u'reachable': False, u'mode': u'homeautomation', u'bri': 128, u'ct': 454, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'292E579A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'15': {u'swversion': u'1.50.2_r30933', u'name': u'Rechtsonder', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:08'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:71:b1:83-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 43467, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2709, 0.2699], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 124}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'14': {u'swversion': u'1.50.2_r30933', u'name': u'Linksonder', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:36'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:54:af:8a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 50820, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2743, 0.1296], u'reachable': False, u'mode': u'homeautomation', u'bri': 182, u'ct': 454, u'sat': 227}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'17': {u'swversion': u'5.130.1.30000', u'name': u'Links', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:56:48'}, u'uniqueid': u'00:17:88:01:10:27:91:c5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'16': {u'swversion': u'1.50.2_r30933', u'name': u'Linksboven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:02'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:54:af:cd-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'reachable': False, u'mode': u'homeautomation', u'bri': 187, u'ct': 454, u'sat': 240}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'19': {u'swversion': u'5.130.1.30000', u'name': u'Spot boom', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:19'}, u'uniqueid': u'00:17:88:01:04:54:9b:d2-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 141}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'18': {u'swversion': u'5.130.1.30000', u'name': u'Schuifdeur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:24'}, u'uniqueid': u'00:17:88:01:04:54:a9:46-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 21840, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.4481, 0.4892], u'reachable': True, u'mode': u'homeautomation', u'bri': 204, u'ct': 350, u'sat': 254}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'31': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:16'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:1b:c5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'37': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken achterdeur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:46'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:f8:44-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 138, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'36': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken kastjes', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:51'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:be:06-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 137, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'35': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:56'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:05:25-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'34': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:00'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:f2:da-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'33': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken voorraadkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:14'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:5e:72-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'32': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken Koelkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:11'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:fb:b4-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}}
Hue Lights Debug Loaded lights list - {u'24': {u'swversion': u'5.130.1.30000', u'name': u'Midden', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-04-07T09:04:47'}, u'uniqueid': u'00:17:88:01:04:a3:e2:fb-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'25': {u'swversion': u'1.50.2_r30933', u'name': u'TV rechts', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:26'}, u'productid': u'3241-3127-7871-LS00', u'uniqueid': u'00:17:88:01:06:53:e2:fe-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 100, u'maxlumen': 540, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue play', u'state': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'reachable': False, u'mode': u'homeautomation', u'bri': 89, u'ct': 370, u'sat': 143}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'949259E6', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'hueplay'}, u'type': u'Extended color light', u'modelid': u'LCT024'}, u'26': {u'swversion': u'1.50.2_r30933', u'name': u'TV Links', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:21'}, u'productid': u'3241-3127-7871-LS00', u'uniqueid': u'00:17:88:01:06:53:db:f9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 100, u'maxlumen': 540, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue play', u'state': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'reachable': False, u'mode': u'homeautomation', u'bri': 89, u'ct': 370, u'sat': 143}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'949259E6', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'hueplay'}, u'type': u'Extended color light', u'modelid': u'LCT024'}, u'27': {u'swversion': u'1.50.2_r30933', u'name': u'Leeslamp Kerstin', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:17'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:06:ec:8b:d9-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 144, u'ct': 443}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'20': {u'swversion': u'1.50.2_r30933', u'name': u'Wijnkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-05-24T20:37:46'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:39:49:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'none', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'28': {u'swversion': u'1.50.2_r30933', u'name': u'Leeslamp Patrick', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:31'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:06:ec:8b:d2-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 143, u'ct': 382}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'5': {u'swversion': u'1.50.2_r30933', u'name': u'Tafel', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:52'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:31:f7:f0-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 192, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'4': {u'swversion': u'1.50.2_r30933', u'name': u'Schilderij', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:36'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:e4:c9:f8-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 191, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'9': {u'swversion': u'1.50.2_r30933', u'name': u'Muur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:57'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:30:32:c7-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 191, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'8': {u'swversion': u'1.50.2_r30933', u'name': u'TV Kast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:13'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:02:9c:1b:14-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 6056, u'colormode': u'xy', u'effect': u'none', u'alert': u'lselect', u'xy': [0.5437, 0.3978], u'reachable': False, u'mode': u'homeautomation', u'bri': 102, u'ct': 454, u'sat': 221}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'59F2C3A3', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'38': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:41'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:4c:49-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'11': {u'swversion': u'5.130.1.30000', u'name': u'Rechts', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:42'}, u'uniqueid': u'00:17:88:01:10:27:92:4f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'13': {u'swversion': u'1.50.2_r30933', u'name': u'Rechtsboven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:41'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:93:32:7a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 47423, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.1823, 0.0815], u'reachable': False, u'mode': u'homeautomation', u'bri': 194, u'ct': 454, u'sat': 231}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'292E579A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'12': {u'swversion': u'1.50.2_r30933', u'name': u'Staanlamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:46'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:d8:d0:6a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5035, 0.4086], u'reachable': False, u'mode': u'homeautomation', u'bri': 128, u'ct': 454, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'292E579A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'15': {u'swversion': u'1.50.2_r30933', u'name': u'Rechtsonder', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:08'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:71:b1:83-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 43467, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2709, 0.2699], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 124}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'14': {u'swversion': u'1.50.2_r30933', u'name': u'Linksonder', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:36'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:54:af:8a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 50820, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2743, 0.1296], u'reachable': False, u'mode': u'homeautomation', u'bri': 182, u'ct': 454, u'sat': 227}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'17': {u'swversion': u'5.130.1.30000', u'name': u'Links', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:56:48'}, u'uniqueid': u'00:17:88:01:10:27:91:c5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'16': {u'swversion': u'1.50.2_r30933', u'name': u'Linksboven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:02'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:54:af:cd-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'reachable': False, u'mode': u'homeautomation', u'bri': 187, u'ct': 454, u'sat': 240}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'19': {u'swversion': u'5.130.1.30000', u'name': u'Spot boom', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:19'}, u'uniqueid': u'00:17:88:01:04:54:9b:d2-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 141}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'18': {u'swversion': u'5.130.1.30000', u'name': u'Schuifdeur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:24'}, u'uniqueid': u'00:17:88:01:04:54:a9:46-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 21840, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.4481, 0.4892], u'reachable': True, u'mode': u'homeautomation', u'bri': 204, u'ct': 350, u'sat': 254}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'31': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:16'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:1b:c5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'37': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken achterdeur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:46'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:f8:44-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 138, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'36': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken kastjes', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:51'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:be:06-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 137, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'35': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:56'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:05:25-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'34': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:00'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:f2:da-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'33': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken voorraadkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:14'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:5e:72-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'32': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken Koelkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:11'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:fb:b4-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'reces[/b]sedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}}
Hue Lights Debug Starting parseAllHueLightsData.
Hue Lights Debug parseAllHueLightsData: There are 27 lights on the Hue bridge and 11 Indigo devices controlling Hue devices.
Hue Lights Debug Starting updateGroupsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.6/api/IaSxK2JUBqRDC5EX ... zp2/groups
Hue Lights Debug Got response {u'10': {u'name': u'Keuken zonder Insel', u'lights': [u'32', u'33', u'36', u'37'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 138, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Kitchen'}, u'13': {u'name': u'TV', u'lights': [u'26', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'15': {u'name': u'Entertainmentruimte 1', u'stream': {u'proxymode': u'auto', u'active': False, u'proxynode': u'/bridge', u'owner': None}, u'locations': {u'25': [0.78, 0.9, 0.0], u'26': [-0.77, 0.9, 0.0], u'12': [1.0, -0.97, 0.0], u'8': [0.01, 0.6, -1.0]}, u'lights': [u'25', u'8', u'12', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}, u'recycle': False, u'sensors': [], u'type': u'Entertainment', u'class': u'TV'}, u'21': {u'name': u'Slaapkamer rechts', u'lights': [u'28'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 143, u'ct': 382}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'17': {u'name': u'4b', u'lights': [u'14', u'13', u'15', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'bri': 187, u'ct': 454, u'sat': 240}}, u'16': {u'name': u'Slaapkamer Links', u'lights': [u'27'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 144, u'ct': 443}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'19': {u'name': u'Buiten', u'lights': [u'11', u'18', u'17', u'24', u'19'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'bri': 1, u'ct': 366, u'sat': 141}}, u'22': {u'name': u'Woonkamer', u'lights': [u'4', u'5', u'8', u'9', u'12', u'20', u'26', u'25'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'20': {u'name': u'TV links en rechts', u'lights': [u'11', u'17'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'bri': 1, u'ct': 362, u'sat': 140}}, u'1': {u'name': u'Ventilator', u'lights': [u'4', u'5', u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select', u'colormode': u'ct', u'bri': 191, u'ct': 366}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Woonkamer', u'lights': [u'8', u'12'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5035, 0.4086], u'bri': 128, u'ct': 454, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Tuin', u'lights': [u'24', u'11', u'17', u'18', u'19'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'bri': 1, u'ct': 366, u'sat': 141}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Garden'}, u'5': {u'name': u'discoAGroup', u'lights': [u'8', u'12', u'13', u'14', u'15', u'16', u'26', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'4': {u'name': u'Kerstin 4b', u'lights': [u'13', u'14', u'15', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'bri': 187, u'ct': 454, u'sat': 240}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'7': {u'name': u'discoAGroupEven', u'lights': [u'8', u'13', u'15', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'6': {u'name': u'discoAGroupOdd', u'lights': [u'12', u'14', u'16', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'9': {u'name': u'Insel', u'lights': [u'31', u'34', u'35', u'38'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Kitchen'}, u'8': {u'name': u'Keuken', u'lights': [u'31', u'34', u'35', u'38', u'32', u'33', u'36', u'37'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 138, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}}
Hue Lights Debug Loaded groups list - {u'10': {u'name': u'Keuken zonder Insel', u'lights': [u'32', u'33', u'36', u'37'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 138, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Kitchen'}, u'13': {u'name': u'TV', u'lights': [u'26', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'15': {u'name': u'Entertainmentruimte 1', u'stream': {u'proxymode': u'auto', u'active': False, u'proxynode': u'/bridge', u'owner': None}, u'locations': {u'25': [0.78, 0.9, 0.0], u'26': [-0.77, 0.9, 0.0], u'12': [1.0, -0.97, 0.0], u'8': [0.01, 0.6, -1.0]}, u'lights': [u'25', u'8', u'12', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}, u'recycle': False, u'sensors': [], u'type': u'Entertainment', u'class': u'TV'}, u'21': {u'name': u'Slaapkamer rechts', u'lights': [u'28'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 143, u'ct': 382}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'17': {u'name': u'4b', u'lights': [u'14', u'13', u'15', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'bri': 187, u'ct': 454, u'sat': 240}}, u'16': {u'name': u'Slaapkamer Links', u'lights': [u'27'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 144, u'ct': 443}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'19': {u'name': u'Buiten', u'lights': [u'11', u'18', u'17', u'24', u'19'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'bri': 1, u'ct': 366, u'sat': 141}}, u'22': {u'name': u'Woonkamer', u'lights': [u'4', u'5', u'8', u'9', u'12', u'20', u'26', u'25'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'20': {u'name': u'TV links en rechts', u'lights': [u'11', u'17'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'bri': 1, u'ct': 362, u'sat': 140}}, u'1': {u'name': u'Ventilator', u'lights': [u'4', u'5', u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select', u'colormode': u'ct', u'bri': 191, u'ct': 366}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Woonkamer', u'lights': [u'8', u'12'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5035, 0.4086], u'bri': 128, u'ct': 454, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Tuin', u'lights': [u'24', u'11', u'17', u'18', u'19'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'bri': 1, u'ct': 366, u'sat': 141}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Garden'}, u'5': {u'name': u'discoAGroup', u'lights': [u'8', u'12', u'13', u'14', u'15', u'16', u'26', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'4': {u'name': u'Kerstin 4b', u'lights': [u'13', u'14', u'15', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'bri': 187, u'ct': 454, u'sat': 240}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'7': {u'name': u'discoAGroupEven', u'lights': [u'8', u'13', u'15', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'6': {u'name': u'discoAGroupOdd', u'lights': [u'12', u'14', u'16', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'9': {u'name': u'Insel', u'lights': [u'31', u'34', u'35', u'38'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Kitchen'}, u'8': {u'name': u'Keuken', u'lights': [u'31', u'34', u'35', u'38', u'32', u'33', u'36', u'37'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 138, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}}
Hue Lights Debug Starting parseAllHueGroupsData.
Hue Lights Debug Starting parseOneHueGroupData.
Hue Lights Debug updateDeviceState: Updating device 4b - All Lights state: alertMode. Old value = . New value = select
Hue Lights Debug updateDeviceState: Updating device 4b - All Lights state: effect. Old value = . New value = none
Hue Lights Debug updateDeviceState: Updating device 4b - All Lights state: effect. Old value = none. New value =
Hue Lights Debug updateDeviceState: Updating device 4b - All Lights state: alertMode. Old value = select. New value =
Hue Lights Debug Starting didDeviceCommPropertyChange.
Hue Lights Debug updateDeviceState: Updating device Eettafel lampen state: alertMode. Old value = . New value = select
Hue Lights Debug updateDeviceState: Updating device Eettafel lampen state: alertMode. Old value = select. New value =
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Debug Starting updateLightsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.6/api/IaSxK2JUBqRDC5EX ... zp2/lights
Hue Lights Debug Got response {u'24': {u'swversion': u'5.130.1.30000', u'name': u'Midden', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-04-07T09:04:47'}, u'uniqueid': u'00:17:88:01:04:a3:e2:fb-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'25': {u'swversion': u'1.50.2_r30933', u'name': u'TV rechts', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:26'}, u'productid': u'3241-3127-7871-LS00', u'uniqueid': u'00:17:88:01:06:53:e2:fe-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 100, u'maxlumen': 540, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue play', u'state': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'reachable': False, u'mode': u'homeautomation', u'bri': 89, u'ct': 370, u'sat': 143}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'949259E6', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'hueplay'}, u'type': u'Extended color light', u'modelid': u'LCT024'}, u'26': {u'swversion': u'1.50.2_r30933', u'name': u'TV Links', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:21'}, u'productid': u'3241-3127-7871-LS00', u'uniqueid': u'00:17:88:01:06:53:db:f9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 100, u'maxlumen': 540, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue play', u'state': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'reachable': False, u'mode': u'homeautomation', u'bri': 89, u'ct': 370, u'sat': 143}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'949259E6', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'hueplay'}, u'type': u'Extended color light', u'modelid': u'LCT024'}, u'27': {u'swversion': u'1.50.2_r30933', u'name': u'Leeslamp Kerstin', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:17'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:06:ec:8b:d9-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 144, u'ct': 443}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'20': {u'swversion': u'1.50.2_r30933', u'name': u'Wijnkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-05-24T20:37:46'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:39:49:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'none', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'28': {u'swversion': u'1.50.2_r30933', u'name': u'Leeslamp Patrick', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:31'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:06:ec:8b:d2-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 143, u'ct': 382}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'5': {u'swversion': u'1.50.2_r30933', u'name': u'Tafel', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:52'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:31:f7:f0-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 192, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'4': {u'swversion': u'1.50.2_r30933', u'name': u'Schilderij', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:36'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:e4:c9:f8-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 191, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'9': {u'swversion': u'1.50.2_r30933', u'name': u'Muur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:57'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:30:32:c7-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 191, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'8': {u'swversion': u'1.50.2_r30933', u'name': u'TV Kast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:13'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:02:9c:1b:14-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 6056, u'colormode': u'xy', u'effect': u'none', u'alert': u'lselect', u'xy': [0.5437, 0.3978], u'reachable': False, u'mode': u'homeautomation', u'bri': 102, u'ct': 454, u'sat': 221}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'59F2C3A3', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'38': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:41'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:4c:49-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'11': {u'swversion': u'5.130.1.30000', u'name': u'Rechts', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:42'}, u'uniqueid': u'00:17:88:01:10:27:92:4f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'13': {u'swversion': u'1.50.2_r30933', u'name': u'Rechtsboven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:41'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:93:32:7a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 47423, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.1823, 0.0815], u'reachable': False, u'mode': u'homeautomation', u'bri': 194, u'ct': 454, u'sat': 231}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'292E579A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'12': {u'swversion': u'1.50.2_r30933', u'name': u'Staanlamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:46'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:d8:d0:6a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5035, 0.4086], u'reachable': False, u'mode': u'homeautomation', u'bri': 128, u'ct': 454, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'292E579A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'15': {u'swversion': u'1.50.2_r30933', u'name': u'Rechtsonder', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:08'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:71:b1:83-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 43467, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2709, 0.2699], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 124}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'14': {u'swversion': u'1.50.2_r30933', u'name': u'Linksonder', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:36'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:54:af:8a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 50820, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2743, 0.1296], u'reachable': False, u'mode': u'homeautomation', u'bri': 182, u'ct': 454, u'sat': 227}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'17': {u'swversion': u'5.130.1.30000', u'name': u'Links', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:56:48'}, u'uniqueid': u'00:17:88:01:10:27:91:c5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True},
Mon Oct 12, 2020 2:36 pm
Patje73 offline
Re: Centura spots part 2
u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'16': {u'swversion': u'1.50.2_r30933', u'name': u'Linksboven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:02'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:54:af:cd-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'reachable': False, u'mode': u'homeautomation', u'bri': 187, u'ct': 454, u'sat': 240}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'19': {u'swversion': u'5.130.1.30000', u'name': u'Spot boom', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:19'}, u'uniqueid': u'00:17:88:01:04:54:9b:d2-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 141}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'18': {u'swversion': u'5.130.1.30000', u'name': u'Schuifdeur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:24'}, u'uniqueid': u'00:17:88:01:04:54:a9:46-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 21840, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.4481, 0.4892], u'reachable': True, u'mode': u'homeautomation', u'bri': 204, u'ct': 350, u'sat': 254}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'31': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:16'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:1b:c5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'37': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken achterdeur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:46'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:f8:44-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 138, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'36': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken kastjes', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:51'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:be:06-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 137, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'35': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:56'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:05:25-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'34': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:00'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:f2:da-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'33': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken voorraadkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:14'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:5e:72-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'32': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken Koelkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:11'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:fb:b4-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}}
Hue Lights Debug Loaded lights list - {u'24': {u'swversion': u'5.130.1.30000', u'name': u'Midden', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-04-07T09:04:47'}, u'uniqueid': u'00:17:88:01:04:a3:e2:fb-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'25': {u'swversion': u'1.50.2_r30933', u'name': u'TV rechts', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:26'}, u'productid': u'3241-3127-7871-LS00', u'uniqueid': u'00:17:88:01:06:53:e2:fe-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 100, u'maxlumen': 540, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue play', u'state': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'reachable': False, u'mode': u'homeautomation', u'bri': 89, u'ct': 370, u'sat': 143}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'949259E6', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'hueplay'}, u'type': u'Extended color light', u'modelid': u'LCT024'}, u'26': {u'swversion': u'1.50.2_r30933', u'name': u'TV Links', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:21'}, u'productid': u'3241-3127-7871-LS00', u'uniqueid': u'00:17:88:01:06:53:db:f9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 100, u'maxlumen': 540, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue play', u'state': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'reachable': False, u'mode': u'homeautomation', u'bri': 89, u'ct': 370, u'sat': 143}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'949259E6', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'hueplay'}, u'type': u'Extended color light', u'modelid': u'LCT024'}, u'27': {u'swversion': u'1.50.2_r30933', u'name': u'Leeslamp Kerstin', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:17'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:06:ec:8b:d9-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 144, u'ct': 443}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'20': {u'swversion': u'1.50.2_r30933', u'name': u'Wijnkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-05-24T20:37:46'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:39:49:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'none', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'28': {u'swversion': u'1.50.2_r30933', u'name': u'Leeslamp Patrick', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:31'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:06:ec:8b:d2-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 143, u'ct': 382}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'5': {u'swversion': u'1.50.2_r30933', u'name': u'Tafel', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:52'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:31:f7:f0-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 192, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'4': {u'swversion': u'1.50.2_r30933', u'name': u'Schilderij', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:36'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:e4:c9:f8-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 191, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'9': {u'swversion': u'1.50.2_r30933', u'name': u'Muur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:57'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:30:32:c7-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 191, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'8': {u'swversion': u'1.50.2_r30933', u'name': u'TV Kast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:13'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:02:9c:1b:14-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 6056, u'colormode': u'xy', u'effect': u'none', u'alert': u'lselect', u'xy': [0.5437, 0.3978], u'reachable': False, u'mode': u'homeautomation', u'bri': 102, u'ct': 454, u'sat': 221}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'59F2C3A3', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'38': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:41'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:4c:49-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'11': {u'swversion': u'5.130.1.30000', u'name': u'Rechts', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:42'}, u'uniqueid': u'00:17:88:01:10:27:92:4f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'13': {u'swversion': u'1.50.2_r30933', u'name': u'Rechtsboven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:41'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:93:32:7a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 47423, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.1823, 0.0815], u'reachable': False, u'mode': u'homeautomation', u'bri': 194, u'ct': 454, u'sat': 231}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'292E579A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'12': {u'swversion': u'1.50.2_r30933', u'name': u'Staanlamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:46'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:d8:d0:6a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5035, 0.4086], u'reachable': False, u'mode': u'homeautomation', u'bri': 128, u'ct': 454, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'292E579A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'15': {u'swversion': u'1.50.2_r30933', u'name': u'Rechtsonder', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:08'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:71:b1:83-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 43467, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2709, 0.2699], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 124}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'14': {u'swversion': u'1.50.2_r30933', u'name': u'Linksonder', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:36'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:54:af:8a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 50820, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2743, 0.1296], u'reachable': False, u'mode': u'homeautomation', u'bri': 182, u'ct': 454, u'sat': 227}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'17': {u'swversion': u'5.130.1.30000', u'name': u'Links', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:56:48'}, u'uniqueid': u'00:17:88:01:10:27:91:c5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'16': {u'swversion': u'1.50.2_r30933', u'name': u'Linksboven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:02'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:54:af:cd-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'reachable': False, u'mode': u'homeautomation', u'bri': 187, u'ct': 454, u'sat': 240}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'19': {u'swversion': u'5.130.1.30000', u'name': u'Spot boom', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:19'}, u'uniqueid': u'00:17:88:01:04:54:9b:d2-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 141}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'18': {u'swversion': u'5.130.1.30000', u'name': u'Schuifdeur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:24'}, u'uniqueid': u'00:17:88:01:04:54:a9:46-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 21840, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.4481, 0.4892], u'reachable': True, u'mode': u'homeautomation', u'bri': 204, u'ct': 350, u'sat': 254}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'31': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:16'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:1b:c5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'37': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken achterdeur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:46'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:f8:44-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 138, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'36': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken kastjes', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:51'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:be:06-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 137, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'35': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:56'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:05:25-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'34': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:00'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:f2:da-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'33': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken voorraadkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:14'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:5e:72-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'32': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken Koelkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:11'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:fb:b4-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}}
Hue Lights Debug Starting parseAllHueLightsData.
Hue Lights Debug parseAllHueLightsData: There are 27 lights on the Hue bridge and 11 Indigo devices controlling Hue devices.
Hue Lights Debug Starting updateGroupsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.6/api/IaSxK2JUBqRDC5EX ... zp2/groups
Hue Lights Debug Got response {u'10': {u'name': u'Keuken zonder Insel', u'lights': [u'32', u'33', u'36', u'37'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 138, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Kitchen'}, u'13': {u'name': u'TV', u'lights': [u'26', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'15': {u'name': u'Entertainmentruimte 1', u'stream': {u'proxymode': u'auto', u'active': False, u'proxynode': u'/bridge', u'owner': None}, u'locations': {u'25': [0.78, 0.9, 0.0], u'26': [-0.77, 0.9, 0.0], u'12': [1.0, -0.97, 0.0], u'8': [0.01, 0.6, -1.0]}, u'lights': [u'25', u'8', u'12', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}, u'recycle': False, u'sensors': [], u'type': u'Entertainment', u'class': u'TV'}, u'21': {u'name': u'Slaapkamer rechts', u'lights': [u'28'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 143, u'ct': 382}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'17': {u'name': u'4b', u'lights': [u'14', u'13', u'15', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'bri': 187, u'ct': 454, u'sat': 240}}, u'16': {u'name': u'Slaapkamer Links', u'lights': [u'27'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 144, u'ct': 443}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'19': {u'name': u'Buiten', u'lights': [u'11', u'18', u'17', u'24', u'19'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'bri': 1, u'ct': 366, u'sat': 141}}, u'22': {u'name': u'Woonkamer', u'lights': [u'4', u'5', u'8', u'9', u'12', u'20', u'26', u'25'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'20': {u'name': u'TV links en rechts', u'lights': [u'11', u'17'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'bri': 1, u'ct': 362, u'sat': 140}}, u'1': {u'name': u'Ventilator', u'lights': [u'4', u'5', u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select', u'colormode': u'ct', u'bri': 191, u'ct': 366}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Woonkamer', u'lights': [u'8', u'12'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5035, 0.4086], u'bri': 128, u'ct': 454, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Tuin', u'lights': [u'24', u'11', u'17', u'18', u'19'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'bri': 1, u'ct': 366, u'sat': 141}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Garden'}, u'5': {u'name': u'discoAGroup', u'lights': [u'8', u'12', u'13', u'14', u'15', u'16', u'26', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'4': {u'name': u'Kerstin 4b', u'lights': [u'13', u'14', u'15', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'bri': 187, u'ct': 454, u'sat': 240}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'7': {u'name': u'discoAGroupEven', u'lights': [u'8', u'13', u'15', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'6': {u'name': u'discoAGroupOdd', u'lights': [u'12', u'14', u'16', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'9': {u'name': u'Insel', u'lights': [u'31', u'34', u'35', u'38'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Kitchen'}, u'8': {u'name': u'Keuken', u'lights': [u'31', u'34', u'35', u'38', u'32', u'33', u'36', u'37'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 138, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}}
Hue Lights Debug Loaded groups list - {u'10': {u'name': u'Keuken zonder Insel', u'lights': [u'32', u'33', u'36', u'37'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 138, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Kitchen'}, u'13': {u'name': u'TV', u'lights': [u'26', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'15': {u'name': u'Entertainmentruimte 1', u'stream': {u'proxymode': u'auto', u'active': False, u'proxynode': u'/bridge', u'owner': None}, u'locations': {u'25': [0.78, 0.9, 0.0], u'26': [-0.77, 0.9, 0.0], u'12': [1.0, -0.97, 0.0], u'8': [0.01, 0.6, -1.0]}, u'lights': [u'25', u'8', u'12', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}, u'recycle': False, u'sensors': [], u'type': u'Entertainment', u'class': u'TV'}, u'21': {u'name': u'Slaapkamer rechts', u'lights': [u'28'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 143, u'ct': 382}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'17': {u'name': u'4b', u'lights': [u'14', u'13', u'15', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'bri': 187, u'ct': 454, u'sat': 240}}, u'16': {u'name': u'Slaapkamer Links', u'lights': [u'27'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 144, u'ct': 443}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'19': {u'name': u'Buiten', u'lights': [u'11', u'18', u'17', u'24', u'19'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'bri': 1, u'ct': 366, u'sat': 141}}, u'22': {u'name': u'Woonkamer', u'lights': [u'4', u'5', u'8', u'9', u'12', u'20', u'26', u'25'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'20': {u'name': u'TV links en rechts', u'lights': [u'11', u'17'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'bri': 1, u'ct': 362, u'sat': 140}}, u'1': {u'name': u'Ventilator', u'lights': [u'4', u'5', u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select', u'colormode': u'ct', u'bri': 191, u'ct': 366}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Woonkamer', u'lights': [u'8', u'12'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5035, 0.4086], u'bri': 128, u'ct': 454, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Tuin', u'lights': [u'24', u'11', u'17', u'18', u'19'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'bri': 1, u'ct': 366, u'sat': 141}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Garden'}, u'5': {u'name': u'discoAGroup', u'lights': [u'8', u'12', u'13', u'14', u'15', u'16', u'26', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'4': {u'name': u'Kerstin 4b', u'lights': [u'13', u'14', u'15', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'bri': 187, u'ct': 454, u'sat': 240}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'7': {u'name': u'discoAGroupEven', u'lights': [u'8', u'13', u'15', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'6': {u'name': u'discoAGroupOdd', u'lights': [u'12', u'14', u'16', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'9': {u'name': u'Insel', u'lights': [u'31', u'34', u'35', u'38'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Kitchen'}, u'8': {u'name': u'Keuken', u'lights': [u'31', u'34', u'35', u'38', u'32', u'33', u'36', u'37'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 138, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}}
Hue Lights Debug Starting parseAllHueGroupsData.
Hue Lights Debug Starting parseOneHueGroupData.
Hue Lights Debug updateDeviceState: Updating device 4b - All Lights state: alertMode. Old value = . New value = select
Hue Lights Debug updateDeviceState: Updating device 4b - All Lights state: effect. Old value = . New value = none
Hue Lights Debug Starting didDeviceCommPropertyChange.
Hue Lights Debug updateDeviceState: Updating device 4b - All Lights state: effect. Old value = none. New value =
Hue Lights Debug updateDeviceState: Updating device 4b - All Lights state: alertMode. Old value = select. New value =
Hue Lights Debug updateDeviceState: Updating device Eettafel lampen state: alertMode. Old value = . New value = select
Hue Lights Debug updateDeviceState: Updating device Eettafel lampen state: alertMode. Old value = select. New value =
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Debug Starting updateLightsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.6/api/IaSxK2JUBqRDC5EX ... zp2/lights
Hue Lights Debug Got response {u'24': {u'swversion': u'5.130.1.30000', u'name': u'Midden', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-04-07T09:04:47'}, u'uniqueid': u'00:17:88:01:04:a3:e2:fb-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'25': {u'swversion': u'1.50.2_r30933', u'name': u'TV rechts', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:26'}, u'productid': u'3241-3127-7871-LS00', u'uniqueid': u'00:17:88:01:06:53:e2:fe-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 100, u'maxlumen': 540, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue play', u'state': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'reachable': False, u'mode': u'homeautomation', u'bri': 89, u'ct': 370, u'sat': 143}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'949259E6', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'hueplay'}, u'type': u'Extended color light', u'modelid': u'LCT024'}, u'26': {u'swversion': u'1.50.2_r30933', u'name': u'TV Links', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:21'}, u'productid': u'3241-3127-7871-LS00', u'uniqueid': u'00:17:88:01:06:53:db:f9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 100, u'maxlumen': 540, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue play', u'state': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'reachable': False, u'mode': u'homeautomation', u'bri': 89, u'ct': 370, u'sat': 143}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'949259E6', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'hueplay'}, u'type': u'Extended color light', u'modelid': u'LCT024'}, u'27': {u'swversion': u'1.50.2_r30933', u'name': u'Leeslamp Kerstin', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:17'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:06:ec:8b:d9-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 144, u'ct': 443}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'20': {u'swversion': u'1.50.2_r30933', u'name': u'Wijnkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-05-24T20:37:46'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:39:49:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'none', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'28': {u'swversion': u'1.50.2_r30933', u'name': u'Leeslamp Patrick', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:31'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:06:ec:8b:d2-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 143, u'ct': 382}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'5': {u'swversion': u'1.50.2_r30933', u'name': u'Tafel', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:52'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:31:f7:f0-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 192, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'4': {u'swversion': u'1.50.2_r30933', u'name': u'Schilderij', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:36'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:e4:c9:f8-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 191, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'9': {u'swversion': u'1.50.2_r30933', u'name': u'Muur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:57'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:30:32:c7-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 191, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'8': {u'swversion': u'1.50.2_r30933', u'name': u'TV Kast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:13'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:02:9c:1b:14-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 6056, u'colormode': u'xy', u'effect': u'none', u'alert': u'lselect', u'xy': [0.5437, 0.3978], u'reachable': False, u'mode': u'homeautomation', u'bri': 102, u'ct': 454, u'sat': 221}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'59F2C3A3', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'38': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:41'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:4c:49-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'11': {u'swversion': u'5.130.1.30000', u'name': u'Rechts', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:42'}, u'uniqueid': u'00:17:88:01:10:27:92:4f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'13': {u'swversion': u'1.50.2_r30933', u'name': u'Rechtsboven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:41'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:93:32:7a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 47423, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.1823, 0.0815], u'reachable': False, u'mode': u'homeautomation', u'bri': 194, u'ct': 454, u'sat': 231}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'292E579A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'12': {u'swversion': u'1.50.2_r30933', u'name': u'Staanlamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:46'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:d8:d0:6a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5035, 0.4086], u'reachable': False, u'mode': u'homeautomation', u'bri': 128, u'ct': 454, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'292E579A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'15': {u'swversion': u'1.50.2_r30933', u'name': u'Rechtsonder', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:08'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:71:b1:83-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 43467, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2709, 0.2699], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 124}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'14': {u'swversion': u'1.50.2_r30933', u'name': u'Linksonder', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:36'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:54:af:8a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 50820, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2743, 0.1296], u'reachable': False, u'mode': u'homeautomation', u'bri': 182, u'ct': 454, u'sat': 227}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'17': {u'swversion': u'5.130.1.30000', u'name': u'Links', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:56:48'}, u'uniqueid': u'00:17:88:01:10:27:91:c5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'16': {u'swversion': u'1.50.2_r30933', u'name': u'Linksboven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:02'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:54:af:cd-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'reachable': False, u'mode': u'homeautomation', u'bri': 187, u'ct': 454, u'sat': 240}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'19': {u'swversion': u'5.130.1.30000', u'name': u'Spot boom', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:19'}, u'uniqueid': u'00:17:88:01:04:54:9b:d2-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 141}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'18': {u'swversion': u'5.130.1.30000', u'name': u'Schuifdeur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:24'}, u'uniqueid': u'00:17:88:01:04:54:a9:46-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 21840, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.4481, 0.4892], u'reachable': True, u'mode': u'homeautomation', u'bri': 204, u'ct': 350, u'sat': 254}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'31': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:16'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:1b:c5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'37': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken achterdeur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:46'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:f8:44-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 138, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'36': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken kastjes', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:51'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:be:06-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 137, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'35': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:56'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:05:25-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'34': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:00'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:f2:da-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'33': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken voorraadkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:14'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:5e:72-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'32': {u'swversion': u'1.65.11_hB798F2', u'name': u'Keuken Koelkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:11'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:50:fb:b4-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}}
Hue Lights Debug Loaded lights list - {u'24': {u'swversion': u'5.130.1.30000', u'name': u'Midden', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-04-07T09:04:47'}, u'uniqueid': u'00:17:88:01:04:a3:e2:fb-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'25': {u'swversion': u'1.50.2_r30933', u'name': u'TV rechts', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:26'}, u'productid': u'3241-3127-7871-LS00', u'uniqueid': u'00:17:88:01:06:53:e2:fe-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 100, u'maxlumen': 540, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue play', u'state': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'reachable': False, u'mode': u'homeautomation', u'bri': 89, u'ct': 370, u'sat': 143}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'949259E6', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'hueplay'}, u'type': u'Extended color light', u'modelid': u'LCT024'}, u'26': {u'swversion': u'1.50.2_r30933', u'name': u'TV Links', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:21'}, u'productid': u'3241-3127-7871-LS00', u'uniqueid': u'00:17:88:01:06:53:db:f9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 100, u'maxlumen': 540, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue play', u'state': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'reachable': False, u'mode': u'homeautomation', u'bri': 89, u'ct': 370, u'sat': 143}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'949259E6', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'hueplay'}, u'type': u'Extended color light', u'modelid': u'LCT024'}, u'27': {u'swversion': u'1.50.2_r30933', u'name': u'Leeslamp Kerstin', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:17'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:06:ec:8b:d9-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 144, u'ct': 443}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'20': {u'swversion': u'1.50.2_r30933', u'name': u'Wijnkast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-05-24T20:37:46'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:39:49:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'none', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'28': {u'swversion': u'1.50.2_r30933', u'name': u'Leeslamp Patrick', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:31'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:06:ec:8b:d2-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 143, u'ct': 382}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'5': {u'swversion': u'1.50.2_r30933', u'name': u'Tafel', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:52'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:31:f7:f0-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 192, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'4': {u'swversion': u'1.50.2_r30933', u'name': u'Schilderij', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:36'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:e4:c9:f8-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 191, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'9': {u'swversion': u'1.50.2_r30933', u'name': u'Muur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:57'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:30:32:c7-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 191, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FBD2BF7E', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'8': {u'swversion': u'1.50.2_r30933', u'name': u'TV Kast', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:13'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:02:9c:1b:14-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 6056, u'colormode': u'xy', u'effect': u'none', u'alert': u'lselect', u'xy': [0.5437, 0.3978], u'reachable': False, u'mode': u'homeautomation', u'bri': 102, u'ct': 454, u'sat': 221}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'59F2C3A3', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'38': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:28:41'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:4c:49-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 300, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue Centura color spot', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'9FD98F72', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'recessedceiling'}, u'type': u'Extended color light', u'modelid': u'5045131P7'}, u'11': {u'swversion': u'5.130.1.30000', u'name': u'Rechts', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:42'}, u'uniqueid': u'00:17:88:01:10:27:92:4f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'13': {u'swversion': u'1.50.2_r30933', u'name': u'Rechtsboven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:41'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:93:32:7a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 47423, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.1823, 0.0815], u'reachable': False, u'mode': u'homeautomation', u'bri': 194, u'ct': 454, u'sat': 231}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'292E579A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'12': {u'swversion': u'1.50.2_r30933', u'name': u'Staanlamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:53:46'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:d8:d0:6a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5035, 0.4086], u'reachable': False, u'mode': u'homeautomation', u'bri': 128, u'ct': 454, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'292E579A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'15': {u'swversion': u'1.50.2_r30933', u'name': u'Rechtsonder', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:08'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:71:b1:83-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 43467, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2709, 0.2699], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 124}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'14': {u'swversion': u'1.50.2_r30933', u'name': u'Linksonder', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:36'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:54:af:8a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 50820, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2743, 0.1296], u'reachable': False, u'mode': u'homeautomation', u'bri': 182, u'ct': 454, u'sat': 227}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'17': {u'swversion': u'5.130.1.30000', u'name': u'Links', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:56:48'}, u'uniqueid': u'00:17:88:01:10:27:91:c5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'16': {u'swversion': u'1.50.2_r30933', u'name': u'Linksboven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:02'}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:54:af:cd-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'reachable': False, u'mode': u'homeautomation', u'bri': 187, u'ct': 454, u'sat': 240}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'772B0E5E', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'19': {u'swversion': u'5.130.1.30000', u'name': u'Spot boom', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:19'}, u'uniqueid': u'00:17:88:01:04:54:9b:d2-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 141}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'18': {u'swversion': u'5.130.1.30000', u'name': u'Schuifdeur', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-02-26T10:54:24'}, u'uniqueid': u'00:17:88:01:04:54:a9:46-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 21840, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.4481, 0.4892], u'reachable': True, u'mode': u'homeautomation', u'bri': 204, u'ct': 350, u'sat': 254}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'31': {u'swversion': u'1.65.11_hB798F2', u'name': u'Insel 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-10-04T19:29:16'}, u'productid': u'Philips-LCG002-1-GU10ECLv2', u'uniqueid': u'00:17:88:01:08:4b:1b:c5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel':
Mon Oct 12, 2020 2:36 pm
Patje73 offline
Re: Centura spots part 3
Hue Lights Debug Starting parseAllHueLightsData.
Hue Lights Debug parseAllHueLightsData: There are 27 lights on the Hue bridge and 11 Indigo devices controlling Hue devices.
Hue Lights Debug Starting updateGroupsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.6/api/IaSxK2JUBqRDC5EX ... zp2/groups
Hue Lights Debug Got response {u'10': {u'name': u'Keuken zonder Insel', u'lights': [u'32', u'33', u'36', u'37'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 138, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Kitchen'}, u'13': {u'name': u'TV', u'lights': [u'26', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'15': {u'name': u'Entertainmentruimte 1', u'stream': {u'proxymode': u'auto', u'active': False, u'proxynode': u'/bridge', u'owner': None}, u'locations': {u'25': [0.78, 0.9, 0.0], u'26': [-0.77, 0.9, 0.0], u'12': [1.0, -0.97, 0.0], u'8': [0.01, 0.6, -1.0]}, u'lights': [u'25', u'8', u'12', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}, u'recycle': False, u'sensors': [], u'type': u'Entertainment', u'class': u'TV'}, u'21': {u'name': u'Slaapkamer rechts', u'lights': [u'28'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 143, u'ct': 382}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'17': {u'name': u'4b', u'lights': [u'14', u'13', u'15', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False,u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'bri': 187, u'ct': 454, u'sat': 240}}, u'16': {u'name': u'Slaapkamer Links', u'lights': [u'27'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 144, u'ct': 443}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'19': {u'name': u'Buiten', u'lights': [u'11', u'18', u'17', u'24', u'19'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'bri': 1, u'ct': 366, u'sat': 141}}, u'22': {u'name': u'Woonkamer', u'lights': [u'4', u'5', u'8', u'9', u'12', u'20', u'26', u'25'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'20': {u'name': u'TV links en rechts', u'lights': [u'11', u'17'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'bri': 1, u'ct': 362, u'sat': 140}}, u'1': {u'name': u'Ventilator', u'lights': [u'4', u'5', u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select', u'colormode': u'ct', u'bri': 191, u'ct': 366}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Woonkamer', u'lights': [u'8', u'12'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5035, 0.4086], u'bri': 128, u'ct': 454, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Tuin', u'lights': [u'24', u'11', u'17', u'18', u'19'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'bri': 1, u'ct': 366, u'sat': 141}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Garden'}, u'5': {u'name': u'discoAGroup', u'lights': [u'8', u'12', u'13', u'14', u'15', u'16', u'26', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'4': {u'name': u'Kerstin 4b', u'lights': [u'13', u'14', u'15', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'bri': 187, u'ct': 454, u'sat': 240}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'7': {u'name': u'discoAGroupEven', u'lights': [u'8', u'13', u'15', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'6': {u'name': u'discoAGroupOdd', u'lights': [u'12', u'14', u'16', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'9': {u'name': u'Insel', u'lights': [u'31', u'34', u'35', u'38'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Kitchen'}, u'8': {u'name': u'Keuken', u'lights': [u'31', u'34', u'35', u'38', u'32', u'33', u'36', u'37'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 138, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}}
Hue Lights Debug Loaded groups list - {u'10': {u'name': u'Keuken zonder Insel', u'lights': [u'32', u'33', u'36', u'37'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 138, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Kitchen'}, u'13': {u'name': u'TV', u'lights': [u'26', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'15': {u'name': u'Entertainmentruimte 1', u'stream': {u'proxymode': u'auto', u'active': False, u'proxynode': u'/bridge', u'owner': None}, u'locations': {u'25': [0.78, 0.9, 0.0], u'26': [-0.77, 0.9, 0.0], u'12': [1.0, -0.97, 0.0], u'8': [0.01, 0.6, -1.0]}, u'lights': [u'25', u'8', u'12', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}, u'recycle': False, u'sensors': [], u'type': u'Entertainment', u'class': u'TV'}, u'21': {u'name': u'Slaapkamer rechts', u'lights': [u'28'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 143, u'ct': 382}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'17': {u'name': u'4b', u'lights': [u'14', u'13', u'15', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'bri': 187, u'ct': 454, u'sat': 240}}, u'16': {u'name': u'Slaapkamer Links', u'lights': [u'27'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 144, u'ct': 443}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'19': {u'name': u'Buiten', u'lights': [u'11', u'18', u'17', u'24', u'19'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'bri': 1, u'ct': 366, u'sat': 141}}, u'22': {u'name': u'Woonkamer', u'lights': [u'4', u'5', u'8', u'9', u'12', u'20', u'26', u'25'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'20': {u'name': u'TV links en rechts', u'lights': [u'11', u'17'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 14974, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.457, 0.4098], u'bri': 1, u'ct': 362, u'sat': 140}}, u'1': {u'name': u'Ventilator', u'lights': [u'4', u'5', u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select', u'colormode': u'ct', u'bri': 191, u'ct': 366}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Woonkamer', u'lights': [u'8', u'12'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5035, 0.4086], u'bri': 128, u'ct': 454, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Tuin', u'lights': [u'24', u'11', u'17', u'18', u'19'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'bri': 1, u'ct': 366, u'sat': 141}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Garden'}, u'5': {u'name': u'discoAGroup', u'lights': [u'8', u'12', u'13', u'14', u'15', u'16', u'26', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'4': {u'name': u'Kerstin 4b', u'lights': [u'13', u'14', u'15', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 52128, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3044, 0.1329], u'bri': 187, u'ct': 454, u'sat': 240}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'7': {u'name': u'discoAGroupEven', u'lights': [u'8', u'13', u'15', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'6': {u'name': u'discoAGroupOdd', u'lights': [u'12', u'14', u'16', u'25'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8382, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4596, 0.4105], u'bri': 89, u'ct': 370, u'sat': 143}}, u'9': {u'name': u'Insel', u'lights': [u'31', u'34', u'35', u'38'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Kitchen'}, u'8': {u'name': u'Keuken', u'lights': [u'31', u'34', u'35', u'38', u'32', u'33', u'36', u'37'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 138, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}}
Hue Lights Debug Starting parseAllHueGroupsData.
Hue Lights Debug Starting parseOneHueGroupData.
Hue Lights Debug updateDeviceState: Updating device 4b - All Lights state: alertMode. Old value = . New value = select
Hue Lights Debug updateDeviceState: Updating device 4b - All Lights state: effect. Old value = . New value = none
Hue Lights Debug updateDeviceState: Updating device 4b - All Lights state: effect. Old value = none. New value =
Hue Lights Debug updateDeviceState: Updating device 4b - All Lights state: alertMode. Old value = select. New value =
Hue Lights Debug updateDeviceState: Updating device Eettafel lampen state: alertMode. Old value = . New value = select
Hue Lights Debug updateDeviceState: Updating device Eettafel lampen state: alertMode. Old value = select. New value =
Hue Lights Debug Starting didDeviceCommPropertyChange.
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Turning off debug logging
Hue Lights Debug Turning off debug logging (Toggle Debugging menu item chosen).
Mon Oct 12, 2020 2:45 pm
nsheldon offline
Re: Centura spots
Thank you. I’ll include support in the next release which should be within a week.
Tue Oct 27, 2020 1:52 pm
Patje73 offline
Re: Centura spots
:D Perfect. Thank you so much!
Thu Oct 29, 2020 3:16 am
nsheldon offline
Re: Centura spots
Version 1.7.38 Posted
  • Added support for a new Hue LED filament bulb variant.
  • Added support for a new Hue Centura color downlight.
  • Added support for a new Hue Ambiance downlight.
