hue lights strip fade in over time
Tue Nov 27, 2018 11:34 pm
bsp9493 offline
Hi... sorry if this has been asked, but I can't seem to find the solution
I've been using your plugin for a while (love it)
what i want to do... basically fade a hue light on from 0-50% over a 30 min period
what I have tried
add an action group - set brightness with ramp rate
select my hue device
set brightness to 50
set ramp rate to 540 (I'm guessing 9 minutes is the max)
what happens...
I run the action group, the light turns on to 50%
your help would be appreciated.
Thanx
dave
Tue Nov 27, 2018 11:36 pm
bsp9493 offline
Re: hue lights strip fade in over time
what happens...
I run the action group, the light turns on to 50% instantly, then will start to increase from a lower percentage over 540 seconds.
What am I doing wrong?
Thu Nov 29, 2018 12:58 pm
bsp9493 offline
if it helps... this is what the log file looks like
Nov 29, 2018 at 10:54:02 AM
   Action Group                    hue lightstrip fade in
   Sent Hue Lights                 "masterBedroom - LightStrip" on to 100 with RGB values 0, 0 and 255 at ramp rate 0.0 sec.
   Sent Hue Lights                 "masterBedroom - LightStrip" on to 10 at ramp rate 0.0 sec.
   Sent Hue Lights                 "masterBedroom - LightStrip" on to 50 at ramp rate 540.0 sec.
Nov 29, 2018 at 10:54:25 AM
   Updated                         "masterBedroom - LightStrip" on to 11
   Updated                         "masterBedroom - LightStrip" on to 12
   Updated                         "masterBedroom - LightStrip" on to 13
   Updated                         "masterBedroom - LightStrip" on to 14
Fri Nov 30, 2018 7:51 am
roussell offline
It’s probably because items in action groups are executed (near)simultaneously, not sequentially. Try setting the ramp rate first and then after a short delay setting the brightness to 50%.
I don’t use this functionality so it’s just a guess but maybe it will get you on the right track.
Terry
Fri Nov 30, 2018 4:28 pm
CliveS offline
Try this but put it in an external file, not an embedded file.
It will give you the 30 Minutes fade in required and you are right 540 seconds is the max but this script will get round that.
30 Nov 2018, 21:18:00
Action Group new action group
Sent Hue Lights "Conservatory Light" off at ramp rate 0.0 sec.
Sent Hue Lights "Conservatory Light" on to 17 at ramp rate 540.0 sec.
30 Nov 2018, 21:18:36
Updated "Conservatory Light" on to 2
30 Nov 2018, 21:19:39
Updated "Conservatory Light" on to 3
30 Nov 2018, 21:20:00
Updated "Conservatory Light" on to 4
30 Nov 2018, 21:20:53
Updated "Conservatory Light" on to 5
30 Nov 2018, 21:21:35
Updated "Conservatory Light" on to 7
30 Nov 2018, 21:22:00
Updated "Conservatory Light" on to 8
30 Nov 2018, 21:22:59
Updated "Conservatory Light" on to 9
Cut out the next 20 minutes of log!!
30 Nov 2018, 21:41:00
Updated "Conservatory Light" on to 43
30 Nov 2018, 21:41:54
Updated "Conservatory Light" on to 44
30 Nov 2018, 21:42:26
Updated "Conservatory Light" on to 45
30 Nov 2018, 21:43:29
Updated "Conservatory Light" on to 47
30 Nov 2018, 21:44:00
Updated "Conservatory Light" on to 48
30 Nov 2018, 21:44:18
Updated "Conservatory Light" on to 49
30 Nov 2018, 21:45:37
Updated "Conservatory Light" on to 50
import time
plug = indigo.server.getPlugin("com.nathansheldon.indigoplugin.HueLights")
rate = 540
if plug.isEnabled():
   plug.executeAction("setBrightness", indigo.devices["Conservatory Light"].id, props={"brightness":00, "rate":0})
   time.sleep(2)
   plug.executeAction("setBrightness", indigo.devices["Conservatory Light"].id, props={"brightness":17, "rate":rate})
   time.sleep(rate)
   plug.executeAction("setBrightness", indigo.devices["Conservatory Light"].id, props={"brightness":34, "rate":rate})
   time.sleep(rate)
   plug.executeAction("setBrightness", indigo.devices["Conservatory Light"].id, props={"brightness":50, "rate":rate})
CliveS
Fri Nov 30, 2018 10:16 pm
bsp9493 offline
Thanx for that... that does get me the desired 30 mins, however, same fundamental problem...
instant on to 17, then begins brighten from 1
instant on to 34, then begins brighten from 17
instant on to 50, then begins brighten from 34
your suggestion prompted me to do this (from within a file)
import time
from time import sleep
bright = 2
for i in range(25):
     plug.executeAction("setBrightness", indigo.devices["masterBedroom - LightStrip"].id, props={"brightness":bright, "rate":0})
     bright = bright+2
     sleep(72)
just checking my delays, but should be close:)
d
Sat Dec 01, 2018 4:47 am
nsheldon offline
Hi Dave.
Yea, for a 30 minute fade, you'd have to use a script like CliveS suggested. The 540 second limit in the Hue Lights plugin is somewhat arbitrary because I couldn't find any Hue API documentation on exactly how long a transient time is allowed by the Hue bridge. So the limit is intended to maintain consistency with other Indigo supported hardware (namely the INSTEON dimmers which has a 540 second max transition time).
As for the lights initially coming on to a higher value than the destination brightness, that's likely a bug in either the light behavior itself or how the Hue bridge sends the ZigBee commands to the lights. The Hue Lights plugin sends all parameters related to a brightness change request in a single command to the Hue bridge. So if you select an Indigo action to brighten a Hue bulb to 50% brightness with a ramp rate of 540 seconds, the Hue Lights plugin sends a single command to the Hue bridge that tells it to set the light to 50% brightness with a transition time of 540 seconds. If there's a way to prevent the light from going on to a brighter level before starting the transition, I wasn't able to find info on that in the Hue API.
Sorry I couldn't help more. I'm glad the Python scripting option appears to be working as a workaround though.
Sat Dec 01, 2018 5:04 am
CliveS offline
Nathan,
Could you not use
   time.sleep(2)
   plug.executeAction("setBrightness", indigo.devices["Conservatory Light"].id, props={"brightness":xx, "rate":rate})
That worked fine when I was writing the script, what I don't understand is why my script increased gradually over 30 minutes as seen by the log but when @bsp9493 ran it he still got
all I can think is he has an RGB device and mine was plain original white.
anyway he got it working and his code looks more eloquent than mine :)
CliveS
Sat Dec 01, 2018 9:39 am
bsp9493 offline
Thanx Nathan... kinda figured it was something to do with hue itself as the command and the logic makes sense..
Nice gradual transition from off to 50% brightness this morning:).
Now to see if i can get fancy and transition some sunrise colours in there - LOL
Thanx again guys!
d
