Philips Hue Play
Wed Oct 31, 2018 3:34 am
MarcoGT offline
Philips Hue Play
I think the Philips Hue Play are not yet supported, am I right?
Because I cannot control them from Indigo.
Marco
Wed Oct 31, 2018 3:46 am
nsheldon offline
Re: Philips Hue Play
Hi Marco.
No. Philips has not published the model ID information for the Hue Play yet. However, if you provide debug log output from the Hue Lights plugin (turn on debugging, then reload the plugin and paste in the log from the point where the plugin reloaded into your response), I can probably add support. Be sure to also tell me what you named the your Hue Play device in the Hue app so I can find it in the log.
Wed Oct 31, 2018 5:03 am
mat offline
Thanks for posting this, I have already found 6 locations for them - its going to cost me a fortune Marco!
Late 2018 mini 10.14
Wed Oct 31, 2018 6:26 am
MarcoGT offline
thanks for the quick response; this should be the model ID
LCT012
Marco
MarcoGT offline
Ops :oops: :oops: :P :P :mrgreen: :mrgreen:
I have two of them at the moment :D
Wed Oct 31, 2018 9:18 am
nsheldon offline
Thanks Marco.
What capabilities does the Hue Play have? Does it support color temperature and full color or just full color?
LCT012
Marco
Wed Oct 31, 2018 11:17 am
MarcoGT offline
Where do I get this info from?
Maybe this can be helpful? https://www2.meethue.com/en-gb/play
Thu Nov 01, 2018 1:58 am
nsheldon offline
Hi Marco.
Thanks for the link. But I need to see the debug log output from the Hue Lights plugin in order to know exactly what capabilities that device has so I’ll know what device group to put it in. You can get debug logs by going to the Plugins menu -> Hue Lights -> Toggle Debugging. Then reload the plugin (Plugins -> Hue Lights -> Reload). Copy the log from the reload point to where it says how many lights were loaded and paste it into your reply.
Fri Nov 02, 2018 1:00 am
nsheldon offline
Version 1.6.23 Posted
  • Added support for the GLEDOPTO color/color temperature light strip.
  • Added support for the Hue Play color/color temperature light.
  • Fixed bug with existing support for GLEDOPTO generic ZigBee color temperature only light strip. It was previously part of the full color device group. It's now part of the Ambiance device group. This will require users to re-define the device in Indigo.
Sat Nov 03, 2018 1:46 pm
MarcoGT offline
Thanks a lot :)
Hue Play work fine :)
Sat Nov 03, 2018 2:48 pm
nsheldon offline
Awesome! Glad it’s working.
Sat Nov 10, 2018 2:06 pm
mat offline
This post was a costly read, but working perfectly.
Users browsing this forum: Google [Bot] and 1 guest
