Hue Lights discussion
Thu Aug 10, 2017 3:21 am
Busta999 offline
Re: Hue Lights discussion
I looked into it.
The Innr bulbs look like they will be ok, but you are just a firmware update away from them not working.
Plus, there is not that much difference in price when you compare apples to apples
[url]https://www.amazon.de/Philips-Erweiterung-warmweißes-steuerbar-kompatibel/dp/B0152WXI0E/ref=sr_1_4?s=lighting&ie=UTF8&qid=1502356691&sr=1-4&keywords=Hue+e27[/url]
In this instance, no difference in price, so I decided it just wasn’t worth the risk of lighting no longer working.
Thu Aug 10, 2017 3:40 am
yassi offline
You're right, didn't saw the Philips ones...
And the risk is huge the Innr will not work anymore after an update.
Yassi
Thu Aug 10, 2017 11:46 am
CliveS offline
The IKEA bulbs look like they are back in the frame as a cheaper alternative to Hue bulbs, just read this on 9to5Mac
https://9to5mac.com/2017/08/10/ikea-adds-homekit-to-existing-smart-bulbs-with-software-update-new-multi-color-bulbs-coming-in-october/
[quote]
Earlier in the year, IKEA had announced that it would be bringing HomeKit integration to its Tradfri range of lighting systems by fall 2017. Now, the company has started rolling out a software update to its Wireless hub that enables HomeKit integration on its products.
The retailer has updated the listing of its products on its website to reflect the change. While not mentioned on the website, the update will also allow for integration with Philips Hue bridge. This means that you will be able to see your smart Ikea bulbs in Philips Hue app as well.
In addition to HomeKit support, the update also makes the smart bulbs and hub compatible with Google Home and Amazon Alexa. This means that you can control the Ikea smart bulbs installed in your premises from your iPhone, iPad, Apple Watch, Android device, any smart speaker running Amazon Alexa, or Google Home. With support for all major assistants out there, Ikea’s Tradfri lighting system is now among the cheapest smart lighting system in the market.
9to5Mac also reports that Ikea is looking to offer multi-color smart bulbs from October. Right now, the company’s Tradfri series of smart bulbs consist of LEDs that are only white in colour.
/quote]
CliveS
CliveS
Thu Aug 10, 2017 12:16 pm
Different Computers offline
Many of my Hue connected bulbs are actuallyGE Link bulbs. No complaints, and in fact for outdoor use I prefer them.
There is a tendency for them to show up as disconnected to the plugin, but that's because they show as disconnected to the Hue hub! However, they are just not reporting their status regularly enough. They respond to all commands just fine.
Thu Aug 10, 2017 3:21 pm
Busta999 offline
/quote]
CliveS
Looks like an update to the 9to5Mac story, Amazon, Google and Apple support coming in October.
Looks like the Hue support is out now. Ikea bulbs with a firmware of 1.2.217 can be added to a Hue Hub.
But as far as I can tell you need the Ikea Hub to update firmware to the bulb, restore bulb to factory then connect to the Hue App.
There is good thread on this ..
[url]https://developers.meethue.com/content/philips-hue-and-ikea-trådfri?page=2[/url]
I like the idea, but would remain concerned that Philips update the Hub firmware to lock out non Philips bulbs. Then you are left with bulbs that are inoperable.
I’d love to hear Philips’ views on this before I put down money on it.
Thu Aug 10, 2017 3:29 pm
CliveS offline
They tried to block 3rd party bulbs in Dec 2015 and then had to back down and revert back to allowing them after a massive backlash
Of course they may consider IKEA too big a threat so as you say, wait and see what happens in the next month or two.
CliveS
CliveS
Sat Aug 12, 2017 2:27 am
Gusten offline
Hi i couldn't resist to try this, and I can confirm that you need the IKEA gateway to update the light, but it was relative cheap. And I had no issue get the IKEA bulbs into hue. But it doesn't seems to work in the indigo plugin. I have 7 hue and 1 IKEA and when I reload lights in the plugin it's reporting only 7 lights?
Anyone else got it to work?
Sat Aug 12, 2017 3:04 am
nsheldon offline
Do you know the model ID of the Ikea bulb? It should show up in the Hue app on your iOS or Android device in Settings -> Light setup -> "i" icon for the light. If you give me the model ID shown there I can add support for it to the Hue Lights plugin. I also need to know what kind of capabilities it has (such as whether it supports full color, whether it supports color temperature or whether it's just a basic dimmer bulb that doesn't change color at all).
Sat Aug 12, 2017 5:07 am
Gusten offline
Nice, this model only dims nothing else.
There were no device ID under light setting, it was blank but I found this
Its number 8 in the images
Sat Aug 12, 2017 5:03 pm
nsheldon offline
That looks like the right information, though the model information is a bit long. I'd like to double-check what the Hue hub is reporting as the model ID for that Ikea light. Could you please enable debug logging in the Hue Lights plugin (Plugins -> Hue Lights -> Toggle Debugging) then reload the plugin (Plugins -> Hue Lights -> Reload). Then copy the log from where it says "Starting plugin 'Hue Lights 1.6.4'..." to "Hue Lights Loaded XX lights" (where "XX" is the number of lights you have on the Hue hub). Paste that copied log into your reply. That way I'll know exactly how the Hue hub is seeing the Ikea light.
Sat Aug 12, 2017 11:19 pm
Gusten offline
Hi
Thanx, Here it is
   Started plugin "Hue Lights 1.6.4"
   Hue Lights Debug                Startup called.
   Hue Lights Debug                Running plugin version check (if enabled).
   Hue Lights Debug                pluginPrefs contains 30 presets.
   Hue Lights Debug                pluginPrefs are:
Prefs : (dict)
     address : 192.168.0.222 (string)
     debugLabel :  (string)
     emailLabel :  (string)
     hostId : df621c0558702cc0f371c27c85410cad (string)
     instructions0 :  (string)
     instructions1 :  (string)
     instructions2 :  (string)
     instructions3 :  (string)
     labelAddress :  (string)
     labelHostId :  (string)
     noticeLabel :  (string)
     presets : (list)
          Item : (list)
               Item : Preset 1 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 2 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 3 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 4 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 5 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 6 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 7 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 8 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 9 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 10 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 11 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 12 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 13 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 14 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 15 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 16 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 17 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 18 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 19 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 20 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 21 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 22 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 23 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 24 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 25 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 26 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 27 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 28 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 29 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 30 (string)
               Item : (dict)
     sep0 :  (string)
     sep1 :  (string)
     sep2 :  (string)
     showDebugInfo : true (bool)
     startPairingButton :  (string)
     title :  (string)
     updaterEmail :  (string)
     updaterEmailsEnabled : true (bool)
     updaterLastCheck : 1502547840 (real)
   Hue Lights Debug                The username Hue Lights uses to connect to the Hue hub is df621c0558702cc0f371c27c85410cad
   Hue Lights Debug                Starting getHueConfig.
   Hue Lights Debug                Sending command to hub: http://192.168.0.222/api/df621c0558702cc0f371c27c85410cad/
   Hue Lights Debug                Got response {u'rules': {}, u'resourcelinks': {}, u'scenes': {u'M8136N9TOdYp8Hg': {u'picture': u'', u'locked': False, u'name': u'Read', u'appdata': {u'version': 1, u'data': u'Bttgv_r04_d02'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'bVUDOHgvqVLzmDr': {u'picture': u'', u'locked': False, u'name': u'Nightlight', u'appdata': {u'version': 1, u'data': u'ZMGYp_r03_d07'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'087f88f522': {u'picture': u'', u'locked': False, u'name': u'087f88f522', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'BVQv7FXs0Jo02Z4': {u'picture': u'', u'locked': False, u'name': u'Tropical twilight', u'appdata': {u'version': 1, u'data': u'HMQvq_r01_d16'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'02b12e930c8bcc7e': {u'picture': u'', u'locked': False, u'name': u'02b12e930c8bcc7e', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'8bfa5715e0': {u'picture': u'', u'locked': False, u'name': u'8bfa5715e0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'797106fb90': {u'picture': u'', u'locked': False, u'name': u'797106fb90', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'e915785b2-on-0': {u'picture': u'', u'locked': False, u'name': u'Reading on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'2e1dbbb4ac': {u'picture': u'', u'locked': False, u'name': u'2e1dbbb4ac', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'LEbGjCDvYmSFmxN': {u'picture': u'', u'locked': False, u'name': u'Concentrate', u'appdata': {u'version': 1, u'data': u'jahgx_r03_d03'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'f2b600f90-on-0': {u'picture': u'', u'locked': False, u'name': u'Kathy on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'174ojuPVvA2MSOm': {u'picture': u'', u'locked': False, u'name': u'Bright', u'appdata': {u'version': 1, u'data': u'IXKjd_r04_d05'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'ac637e2f0b-on-0': {u'picture': u'', u'locked': False, u'name': u'ac637e2f0b-on-0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'6elNe2LR-WQ8vmm': {u'picture': u'', u'locked': False, u'name': u'Bright', u'appdata': {u'version': 1, u'data': u'TBDOn_r02_d05'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'0f2c67d801': {u'picture': u'', u'locked': False, u'name': u'0f2c67d801', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'e915785b2b': {u'picture': u'', u'locked': False, u'name': u'e915785b2b', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'34659bba95': {u'picture': u'', u'locked': False, u'name': u'34659bba95', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'raiMwsxKgC1HgyN': {u'picture': u'', u'locked': False, u'name': u'Concentrate', u'appdata': {u'version': 1, u'data': u'EWyjk_r04_d03'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'2141cb8bd2': {u'picture': u'', u'locked': False, u'name': u'2141cb8bd2', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'34659bba95-on-0': {u'picture': u'', u'locked': False, u'name': u'Relax on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'kqQI7mV70S-K2iG': {u'picture': u'', u'locked': False, u'name': u'Nightlight', u'appdata': {u'version': 1, u'data': u'Y01mP_r02_d07'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'U6HwlmUJb2tH6VG': {u'picture': u'', u'locked': False, u'name': u'Relax', u'appdata': {u'version': 1, u'data': u'ER8B9_r03_d01'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'31BBd0HMJo53KKV': {u'picture': u'', u'locked': False, u'name': u'Energize', u'appdata': {u'version': 1, u'data': u'GwSCW_r01_d04'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'2778251b21-off-0': {u'picture': u'', u'locked': False, u'name': u'2778251b21-off-0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'OjVUVz1nmDM-Vbh': {u'picture': u'', u'locked': False, u'name': u'Bright', u'appdata': {u'version': 1, u'data': u'0T2jV_r01_d05'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'23eNfxq6trfyG6x': {u'picture': u'', u'locked': False, u'name': u'Savanna sunset', u'appdata': {u'version': 1, u'data': u'vJaLD_r03_d15'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'JzlRoaODjl-PqON': {u'picture': u'', u'locked': False, u'name': u'Dimmed', u'appdata': {u'version': 1, u'data': u'Ket9D_r04_d06'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'34659bba9-on-0': {u'picture': u'', u'locked': False, u'name': u'Relax on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'2e1dbbb4a-on-0': {u'picture': u'', u'locked': False, u'name': u'Pencils on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'Qcqs6iPoHrQSAN-': {u'picture': u'', u'locked': False, u'name': u'Nightlight', u'appdata': {u'version': 1, u'data': u'okLy5_r01_d07'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'Lbrd9TW9huJ0ECV': {u'picture': u'', u'locked': False, u'name': u'Dimmed', u'appdata': {u'version': 1, u'data': u'mpVrB_r02_d06'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'6b6ca6a0d3': {u'picture': u'', u'locked': False, u'name': u'6b6ca6a0d3', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'vkWXxDhRyX99Baq': {u'picture': u'', u'locked': False, u'name': u'Dimmed', u'appdata': {u'version': 1, u'data': u'aY3sa_r01_d06'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'b18Flit5qIWwFrd': {u'picture': u'', u'locked': False, u'name': u'Spring blossom', u'appdata': {u'version': 1, u'data': u'nKQBA_r01_d18'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'e07a35d7e8': {u'picture': u'', u'locked': False, u'name': u'e07a35d7e8', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'Dd63LeP2pc-7N1s': {u'picture': u'', u'locked': False, u'name': u'Concentrate', u'appdata': {u'version': 1, u'data': u'BRV0C_r02_d03'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'9I9lTMVONtKGbn7': {u'picture': u'', u'locked': False, u'name': u'Energize', u'appdata': {u'version': 1, u'data': u'RMhFz_r02_d04'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'FFdmV0uSUGp3NSD': {u'picture': u'', u'locked': False, u'name': u'Dimmed', u'appdata': {u'version': 1, u'data': u'DBS1v_r03_d06'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'GXG7oKAxf6g7jPH': {u'picture': u'', u'locked': False, u'name': u'Savanna sunset', u'appdata': {u'version': 1, u'data': u'wpWB3_r04_d15'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'VKHWL2Ktl8d32RX': {u'picture': u'', u'locked': False, u'name': u'Spring blossom', u'appdata': {u'version': 1, u'data': u'GiEju_r03_d18'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'ac637e2f0b-off-9': {u'picture': u'', u'locked': False, u'name': u'ac637e2f0b-off-9', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'2778251b21': {u'picture': u'', u'locked': False, u'name': u'2778251b21', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'DOJu9IU32rlCTgA': {u'picture': u'', u'locked': False, u'name': u'Energize', u'appdata': {u'version': 1, u'data': u'5FdTo_r03_d04'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'EXNKQfFwGR1Tx5P': {u'picture': u'', u'locked': False, u'name': u'Energize', u'appdata': {u'version': 1, u'data': u'ctotX_r04_d04'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'411c1b0e6e': {u'picture': u'', u'locked': False, u'name': u'411c1b0e6e', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'f2b600f908': {u'picture': u'', u'locked': False, u'name': u'f2b600f908', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'emAde6ttlKilqhh': {u'picture': u'', u'locked': False, u'name': u'Nightlight', u'appdata': {u'version': 1, u'data': u'hTXuj_r04_d07'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'7KyQQ9FPaj37hp6': {u'picture': u'', u'locked': False, u'name': u'Bright', u'appdata': {u'version': 1, u'data': u'agNdX_r03_d05'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'07hpJqDfVmcQxX9': {u'picture': u'', u'locked': False, u'name': u'Relax', u'appdata': {u'version': 1, u'data': u'6Mx6U_r04_d01'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'FaIbyzM6YJ-6Gg5': {u'picture': u'', u'locked': False, u'name': u'Spring blossom', u'appdata': {u'version': 1, u'data': u'VpUZM_r04_d18'}, u'lastupdated': u'2017-02-08T17:54:03', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'6lIgDMBcMx2fAdg': {u'picture': u'', u'locked': False, u'name': u'Spring blossom', u'appdata': {u'version': 1, u'data': u'ZbrzV_r02_d18'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'BEsTM6BJiiHPFUc': {u'picture': u'', u'locked': False, u'name': u'Read', u'appdata': {u'version': 1, u'data': u'l5z0p_r03_d02'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'84fa88aa5f': {u'picture': u'', u'locked': False, u'name': u'84fa88aa5f', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'0OzjHyM1KrOEo-Y': {u'picture': u'', u'locked': False, u'name': u'Savanna sunset', u'appdata': {u'version': 1, u'data': u'ZQg72_r01_d15'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'hemiuT2jo9ugfsK': {u'picture': u'', u'locked': False, u'name': u'Arctic aurora', u'appdata': {u'version': 1, u'data': u'mLvcC_r03_d17'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'gn8mFTSeOOGo2Na': {u'picture': u'', u'locked': False, u'name': u'Tropical twilight', u'appdata': {u'version': 1, u'data': u'j2ZJa_r04_d16'}, u'lastupdated': u'2017-02-08T17:54:03', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'K-osRN5GJYIlUCh': {u'picture': u'', u'locked': False, u'name': u'Relax', u'appdata': {u'version': 1, u'data': u'ruDSm_r02_d01'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'Q3uIpRcvN-HwCBo': {u'picture': u'', u'locked': False, u'name': u'Arctic aurora', u'appdata': {u'version': 1, u'data': u'ovgbT_r01_d17'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'bf0eee1c624497d5': {u'picture': u'', u'locked': False, u'name': u'bf0eee1c624497d5', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'gKZkzLILDdFlnee': {u'picture': u'', u'locked': False, u'name': u'Savanna sunset', u'appdata': {u'version': 1, u'data': u'8vhtf_r02_d15'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'f5d73dbdd-on-0': {u'picture': u'', u'locked': False, u'name': u'Concentrate on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'TIxyQl4p1jTxiER': {u'picture': u'', u'locked': False, u'name': u'Concentrate', u'appdata': {u'version': 1, u'data': u'F1QcU_r01_d03'}, u'lastupdated': u'2017-02-08T17:53:18', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'ac637e2f0b': {u'picture': u'', u'locked': False, u'name': u'ac637e2f0b', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'swjxWxPqkdQvhRY': {u'picture': u'', u'locked': False, u'name': u'Read', u'appdata': {u'version': 1, u'data': u'xoDF0_r01_d02'}, u'lastupdated': u'2017-02-08T17:53:18', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'hdsWuEIkDaF219v': {u'picture': u'', u'locked': False, u'name': u'Read', u'appdata': {u'version': 1, u'data': u'K4pn2_r02_d02'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'c3b59438104f0251': {u'picture': u'', u'locked': False, u'name': u'c3b59438104f0251', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'bkIRa6aFaNXzgN0': {u'picture': u'', u'locked': False, u'name': u'Arctic aurora', u'appdata': {u'version': 1, u'data': u'IcBm0_r02_d17'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'f5d73dbdd5': {u'picture': u'', u'locked': False, u'name': u'f5d73dbdd5', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'2778251b21-on-0': {u'picture': u'', u'locked': False, u'name': u'2778251b21-on-0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'25b485af0a': {u'picture': u'', u'locked': False, u'name': u'25b485af0a', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'rddcXvKCsk5lcpQ': {u'picture': u'', u'locked': False, u'name': u'Tropical twilight', u'appdata': {u'version': 1, u'data': u'FMCVy_r03_d16'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'4PlzgvjvXLMCzrR': {u'picture': u'', u'locked': False, u'name': u'Relax', u'appdata': {u'version': 1, u'data': u'9G5HU_r01_d01'}, u'lastupdated': u'2017-02-08T17:53:18', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'hmMkN6rWSudRKwL': {u'picture': u'', u'locked': False, u'name': u'Tropical twilight', u'appdata': {u'version': 1, u'data': u'n4SSh_r02_d16'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'ej54PDoFU8D2TMl': {u'picture': u'', u'locked': False, u'name': u'Arctic aurora', u'appdata': {u'version': 1, u'data': u'y1U5y_r04_d17'}, u'lastupdated': u'2017-02-08T17:54:03', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'ac637e2f0-on-0': {u'picture': u'', u'locked': False, u'name': u'Relax on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'48aa892d8-on-0': {u'picture': u'', u'locked': False, u'name': u'Test on 0', u'appdata': {}, u'lastupdated': u'2016-01-03T16:53:17', u'lights': [u'4', u'5', u'6'], u'version': 1, u'recycle': True, u'owner': u'h9hlIrWJfU0ffE3k'}}, u'lights': {u'1': {u'name': u'Noahs rum', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 13651, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4983, 0.4152], u'reachable': True, u'bri': 1, u'ct': 439, u'sat': 196}, u'uniqueid': u'00:17:88:01:00:be:87:69-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'3': {u'name': u'Golvlampa vardagsrum', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 12740, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.5222, 0.4142], u'reachable': True, u'bri': 128, u'ct': 488, u'sat': 222}, u'uniqueid': u'00:17:88:01:00:be:7a:b1-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'5': {u'name': u'K\xf6k fl\xe4kt', u'swversion': u'5.50.1.19085', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 14423, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4744, 0.413], u'reachable': True, u'bri': 1, u'ct': 397, u'sat': 165}, u'uniqueid': u'00:17:88:01:00:e8:e6:41-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'4': {u'name': u'K\xf6k fl\xf6kt 2', u'swversion': u'5.50.1.19085', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 13707, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4972, 0.4153], u'reachable': True, u'bri': 1, u'ct': 439, u'sat': 195}, u'uniqueid': u'00:17:88:01:00:e9:07:42-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'7': {u'name': u'Meyas rum', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 13277, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5081, 0.415], u'reachable': True, u'bri': 1, u'ct': 459, u'sat': 207}, u'uniqueid': u'00:12:4b:00:02:3f:69:50-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'6': {u'name': u'K\xf6k diskho', u'swversion': u'5.50.1.19085', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 14956, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4571, 0.4097], u'reachable': True, u'bri': 1, u'ct': 366, u'sat': 140}, u'uniqueid': u'00:17:88:01:00:e8:e7:1a-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'8': {u'name': u'F\xf6nsterlampa Allrum', u'swversion': u'1.2.214', u'manufacturername': u'IKEA of Sweden', u'state': {u'on': True, u'reachable': False, u'bri': 142, u'alert': u'none'}, u'uniqueid': u'00:0b:57:ff:fe:25:04:d8-01', u'type': u'Dimmable light', u'modelid': u'TRADFRI bulb E27 opal 1000lm'}}, u'groups': {u'1': {u'name': u'K\xf6k', u'lights': [u'4', u'5', u'6'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 14956, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4571, 0.4097], u'bri': 1, u'ct': 366, u'sat': 140}, u'recycle': False, u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Meya', u'lights': [u'7'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 13277, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5081, 0.415], u'bri': 1, u'ct': 459, u'sat': 207}, u'recycle': False, u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Noah', u'lights': [u'1'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 13651, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4983, 0.4152], u'bri': 1, u'ct': 439, u'sat': 196}, u'recycle': False, u'type': u'Room', u'class': u'Living room'}, u'4': {u'name': u'Vardagsrum', u'lights': [u'3'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 12740, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.5222, 0.4142], u'bri': 128, u'ct': 488, u'sat': 222}, u'recycle': False, u'type': u'Room', u'class': u'Living room'}}, u'schedules': {}, u'sensors': {u'1': {u'name': u'Daylight', u'config': {u'on': True, u'configured': False, u'sunriseoffset': 30, u'sunsetoffset': -30}, u'swversion': u'1.0', u'state': {u'daylight': None, u'lastupdated': u'none'}, u'manufacturername': u'Philips', u'type': u'Daylight', u'modelid': u'PHDL00'}}, u'config': {u'starterkitid': u'', u'portalconnection': u'connected', u'whitelist': {u'df621c0558702cc0f371c27c85410cad': {u'last use date': u'2017-08-13T05:06:11', u'create date': u'2015-12-16T20:36:53', u'name': u'Indigo Hue Plugin'}, u'421B1E775327E6421F75B7EE12CBC0FE': {u'last use date': u'2013-08-03T11:10:46', u'create date': u'2013-08-03T11:08:31', u'name': u'HueDisco'}, u'1b42aa55441cedda3537f9392827b900': {u'last use date': u'2016-10-16T15:34:31', u'create date': u'2016-10-02T12:19:32', u'name': u'HueDiscoBridgeConnec#SomePhone'}, u'h9hlIrWJfU0ffE3k': {u'last use date': u'2017-08-12T11:01:30', u'create date': u'2013-10-04T16:37:44', u'name': u'Gustens'}, u'0f607264fc6318a92b9e13c65db7cd3c': {u'last use date': u'2014-02-20T18:29:03', u'create date': u'2013-11-24T17:30:05', u'name': u'Martin Gustafssons iPad 4'}, u'A46F6F52F78B9E0184EA015571887655': {u'last use date': u'2013-08-04T12:18:37', u'create date': u'2013-08-01T17:12:40', u'name': u'HueParty'}, u'3382417dacf7765e716e4cd6b6b610a1': {u'last use date': u'2013-09-17T17:26:03', u'create date': u'2013-08-01T17:09:42', u'name': u'Martin Gustafssons iPad 4'}, u'newdeveloper': {u'last use date': u'2013-08-14T17:19:09', u'create date': u'2013-08-14T17:17:48', u'name': u'test user'}, u'4371000000': {u'last use date': u'2014-10-22T15:41:58', u'create date': u'2013-08-14T17:24:58', u'name': u'irule'}, u'7bFgQgnXnXVFkOuR': {u'last use date': u'2017-06-16T16:46:52', u'create date': u'2013-10-24T16:55:10', u'name': u'Martin Gustafssons iPad 4'}, u'57AE2B3549E3E96748E1320C01097F3A': {u'last use date': u'2014-12-26T08:02:56', u'create date': u'2013-12-06T15:12:19', u'name': u'Huelloween'}, u'TDfY148ciZMiOOwSC09maLBrfN9goB01': {u'last use date': u'2015-11-13T14:19:24', u'create date': u'2013-10-25T17:01:49', u'name': u'VeraTest'}, u'60927f10222dd4fc78e6acfb1efe647a': {u'last use date': u'2016-09-24T06:31:50', u'create date': u'2015-12-24T11:33:10', u'name': u'Hue Christmas#Gustens iphone'}, u'43cc09b6b6d4991189f6983d40ed9917': {u'last use date': u'2015-11-09T20:31:53', u'create date': u'2013-08-01T16:35:10', u'name': u'Gustens'}, u'1ce74c37ba2564782180013f7fdb90': {u'last use date': u'2017-05-19T18:18:47', u'create date': u'2016-10-15T16:56:57', u'name': u'iftttv2'}, u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk': {u'last use date': u'2017-08-12T11:01:30', u'create date': u'2017-02-08T17:46:25', u'name': u'hue_ios_app#Gustens iphone'}, u'28C0F5406F3AD7C4969D63FAD94E7993': {u'last use date': u'2015-12-24T11:58:15', u'create date': u'2015-12-24T11:40:49', u'name': u'HueDisco'}, u'3ace6d073e5ec92335c895bc1d988ce3': {u'last use date': u'2016-04-02T18:55:08', u'create date': u'2016-04-02T18:39:45', u'name': u'Hue Disco#Gustens iphone'}, u'7859f6c9297f558817327a7ede54c98': {u'last use date': u'2017-03-07T17:33:31', u'create date': u'2017-01-22T16:50:54', u'name': u'HueDiscoBridgeConnec#SomePhone'}, u'74F35F10AD669E8869510E3A94CE3F4F': {u'last use date': u'2014-11-08T17:55:04', u'create date': u'2013-08-01T17:46:54', u'name': u'HueDisco'}, u'IDabYR3A32J8h-VrCDuvkePM-sOKOSDZW1clJjCx': {u'last use date': u'2017-06-16T16:46:52', u'create date': u'2017-06-16T16:33:08', u'name': u'HueDiscoBridgeConnec#SomePhone'}}, u'zigbeechannel': 15, u'timezone': u'Europe/Stockholm', u'gateway': u'192.168.0.1', u'modelid': u'BSB002', u'portalstate': {u'communication': u'disconnected', u'outgoing': True, u'signedon': True, u'incoming': False}, u'proxyaddress': u'none', u'datastoreversion': u'61', u'replacesbridgeid': u'001788FFFE0AB32F', u'dhcp': False, u'localtime': u'2017-08-13T07:06:11', u'proxyport': 0, u'UTC': u'2017-08-13T05:06:11', u'factorynew': False, u'swupdate': {u'devicetypes': {u'bridge': False, u'sensors': [], u'lights': []}, u'url': u'', u'text': u'', u'checkforupdate': False, u'updatestate': 0, u'notify': False}, u'apiversion': u'1.19.0', u'mac': u'00:17:88:23:b2:62', u'linkbutton': False, u'bridgeid': u'001788FFFE23B262', u'ipaddress': u'192.168.0.222', u'portalservices': True, u'name': u'Philips hue', u'swversion': u'1705121051', u'netmask': u'255.255.255.0', u'internetservices': {u'remoteaccess': u'connected'}, u'backup': {u'status': u'idle', u'errorcode': 0}}}
   Hue Lights Debug                Loaded entire Hue hub configuration - {u'rules': {}, u'resourcelinks': {}, u'scenes': {u'M8136N9TOdYp8Hg': {u'picture': u'', u'locked': False, u'name': u'Read', u'appdata': {u'version': 1, u'data': u'Bttgv_r04_d02'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'bVUDOHgvqVLzmDr': {u'picture': u'', u'locked': False, u'name': u'Nightlight', u'appdata': {u'version': 1, u'data': u'ZMGYp_r03_d07'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'087f88f522': {u'picture': u'', u'locked': False, u'name': u'087f88f522', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'BVQv7FXs0Jo02Z4': {u'picture': u'', u'locked': False, u'name': u'Tropical twilight', u'appdata': {u'version': 1, u'data': u'HMQvq_r01_d16'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'02b12e930c8bcc7e': {u'picture': u'', u'locked': False, u'name': u'02b12e930c8bcc7e', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'8bfa5715e0': {u'picture': u'', u'locked': False, u'name': u'8bfa5715e0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'797106fb90': {u'picture': u'', u'locked': False, u'name': u'797106fb90', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'e915785b2-on-0': {u'picture': u'', u'locked': False, u'name': u'Reading on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'2e1dbbb4ac': {u'picture': u'', u'locked': False, u'name': u'2e1dbbb4ac', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'LEbGjCDvYmSFmxN': {u'picture': u'', u'locked': False, u'name': u'Concentrate', u'appdata': {u'version': 1, u'data': u'jahgx_r03_d03'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'f2b600f90-on-0': {u'picture': u'', u'locked': False, u'name': u'Kathy on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'174ojuPVvA2MSOm': {u'picture': u'', u'locked': False, u'name': u'Bright', u'appdata': {u'version': 1, u'data': u'IXKjd_r04_d05'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'ac637e2f0b-on-0': {u'picture': u'', u'locked': False, u'name': u'ac637e2f0b-on-0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'6elNe2LR-WQ8vmm': {u'picture': u'', u'locked': False, u'name': u'Bright', u'appdata': {u'version': 1, u'data': u'TBDOn_r02_d05'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'0f2c67d801': {u'picture': u'', u'locked': False, u'name': u'0f2c67d801', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'e915785b2b': {u'picture': u'', u'locked': False, u'name': u'e915785b2b', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'34659bba95': {u'picture': u'', u'locked': False, u'name': u'34659bba95', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'raiMwsxKgC1HgyN': {u'picture': u'', u'locked': False, u'name': u'Concentrate', u'appdata': {u'version': 1, u'data': u'EWyjk_r04_d03'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'2141cb8bd2': {u'picture': u'', u'locked': False, u'name': u'2141cb8bd2', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'34659bba95-on-0': {u'picture': u'', u'locked': False, u'name': u'Relax on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'kqQI7mV70S-K2iG': {u'picture': u'', u'locked': False, u'name': u'Nightlight', u'appdata': {u'version': 1, u'data': u'Y01mP_r02_d07'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'U6HwlmUJb2tH6VG': {u'picture': u'', u'locked': False, u'name': u'Relax', u'appdata': {u'version': 1, u'data': u'ER8B9_r03_d01'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'31BBd0HMJo53KKV': {u'picture': u'', u'locked': False, u'name': u'Energize', u'appdata': {u'version': 1, u'data': u'GwSCW_r01_d04'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'2778251b21-off-0': {u'picture': u'', u'locked': False, u'name': u'2778251b21-off-0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'OjVUVz1nmDM-Vbh': {u'picture': u'', u'locked': False, u'name': u'Bright', u'appdata': {u'version': 1, u'data': u'0T2jV_r01_d05'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'23eNfxq6trfyG6x': {u'picture': u'', u'locked': False, u'name': u'Savanna sunset', u'appdata': {u'version': 1, u'data': u'vJaLD_r03_d15'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'JzlRoaODjl-PqON': {u'picture': u'', u'locked': False, u'name': u'Dimmed', u'appdata': {u'version': 1, u'data': u'Ket9D_r04_d06'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'34659bba9-on-0': {u'picture': u'', u'locked': False, u'name': u'Relax on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'2e1dbbb4a-on-0': {u'picture': u'', u'locked': False, u'name': u'Pencils on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'Qcqs6iPoHrQSAN-': {u'picture': u'', u'locked': False, u'name': u'Nightlight', u'appdata': {u'version': 1, u'data': u'okLy5_r01_d07'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'Lbrd9TW9huJ0ECV': {u'picture': u'', u'locked': False, u'name': u'Dimmed', u'appdata': {u'version': 1, u'data': u'mpVrB_r02_d06'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'6b6ca6a0d3': {u'picture': u'', u'locked': False, u'name': u'6b6ca6a0d3', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'vkWXxDhRyX99Baq': {u'picture': u'', u'locked': False, u'name': u'Dimmed', u'appdata': {u'version': 1, u'data': u'aY3sa_r01_d06'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'b18Flit5qIWwFrd': {u'picture': u'', u'locked': False, u'name': u'Spring blossom', u'appdata': {u'version': 1, u'data': u'nKQBA_r01_d18'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'e07a35d7e8': {u'picture': u'', u'locked': False, u'name': u'e07a35d7e8', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'Dd63LeP2pc-7N1s': {u'picture': u'', u'locked': False, u'name': u'Concentrate', u'appdata': {u'version': 1, u'data': u'BRV0C_r02_d03'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'9I9lTMVONtKGbn7': {u'picture': u'', u'locked': False, u'name': u'Energize', u'appdata': {u'version': 1, u'data': u'RMhFz_r02_d04'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'FFdmV0uSUGp3NSD': {u'picture': u'', u'locked': False, u'name': u'Dimmed', u'appdata': {u'version': 1, u'data': u'DBS1v_r03_d06'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'GXG7oKAxf6g7jPH': {u'picture': u'', u'locked': False, u'name': u'Savanna sunset', u'appdata': {u'version': 1, u'data': u'wpWB3_r04_d15'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'VKHWL2Ktl8d32RX': {u'picture': u'', u'locked': False, u'name': u'Spring blossom', u'appdata': {u'version': 1, u'data': u'GiEju_r03_d18'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'ac637e2f0b-off-9': {u'picture': u'', u'locked': False, u'name': u'ac637e2f0b-off-9', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'2778251b21': {u'picture': u'', u'locked': False, u'name': u'2778251b21', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'DOJu9IU32rlCTgA': {u'picture': u'', u'locked': False, u'name': u'Energize', u'appdata': {u'version': 1, u'data': u'5FdTo_r03_d04'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'EXNKQfFwGR1Tx5P': {u'picture': u'', u'locked': False, u'name': u'Energize', u'appdata': {u'version': 1, u'data': u'ctotX_r04_d04'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'411c1b0e6e': {u'picture': u'', u'locked': False, u'name': u'411c1b0e6e', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'f2b600f908': {u'picture': u'', u'locked': False, u'name': u'f2b600f908', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'emAde6ttlKilqhh': {u'picture': u'', u'locked': False, u'name': u'Nightlight', u'appdata': {u'version': 1, u'data': u'hTXuj_r04_d07'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'7KyQQ9FPaj37hp6': {u'picture': u'', u'locked': False, u'name': u'Bright', u'appdata': {u'version': 1, u'data': u'agNdX_r03_d05'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'07hpJqDfVmcQxX9': {u'picture': u'', u'locked': False, u'name': u'Relax', u'appdata': {u'version': 1, u'data': u'6Mx6U_r04_d01'}, u'lastupdated': u'2017-02-08T17:54:02', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'FaIbyzM6YJ-6Gg5': {u'picture': u'', u'locked': False, u'name': u'Spring blossom', u'appdata': {u'version': 1, u'data': u'VpUZM_r04_d18'}, u'lastupdated': u'2017-02-08T17:54:03', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'6lIgDMBcMx2fAdg': {u'picture': u'', u'locked': False, u'name': u'Spring blossom', u'appdata': {u'version': 1, u'data': u'ZbrzV_r02_d18'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'BEsTM6BJiiHPFUc': {u'picture': u'', u'locked': False, u'name': u'Read', u'appdata': {u'version': 1, u'data': u'l5z0p_r03_d02'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'84fa88aa5f': {u'picture': u'', u'locked': False, u'name': u'84fa88aa5f', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'0OzjHyM1KrOEo-Y': {u'picture': u'', u'locked': False, u'name': u'Savanna sunset', u'appdata': {u'version': 1, u'data': u'ZQg72_r01_d15'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'hemiuT2jo9ugfsK': {u'picture': u'', u'locked': False, u'name': u'Arctic aurora', u'appdata': {u'version': 1, u'data': u'mLvcC_r03_d17'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'gn8mFTSeOOGo2Na': {u'picture': u'', u'locked': False, u'name': u'Tropical twilight', u'appdata': {u'version': 1, u'data': u'j2ZJa_r04_d16'}, u'lastupdated': u'2017-02-08T17:54:03', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'K-osRN5GJYIlUCh': {u'picture': u'', u'locked': False, u'name': u'Relax', u'appdata': {u'version': 1, u'data': u'ruDSm_r02_d01'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'Q3uIpRcvN-HwCBo': {u'picture': u'', u'locked': False, u'name': u'Arctic aurora', u'appdata': {u'version': 1, u'data': u'ovgbT_r01_d17'}, u'lastupdated': u'2017-02-08T17:53:19', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'bf0eee1c624497d5': {u'picture': u'', u'locked': False, u'name': u'bf0eee1c624497d5', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'gKZkzLILDdFlnee': {u'picture': u'', u'locked': False, u'name': u'Savanna sunset', u'appdata': {u'version': 1, u'data': u'8vhtf_r02_d15'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'f5d73dbdd-on-0': {u'picture': u'', u'locked': False, u'name': u'Concentrate on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'TIxyQl4p1jTxiER': {u'picture': u'', u'locked': False, u'name': u'Concentrate', u'appdata': {u'version': 1, u'data': u'F1QcU_r01_d03'}, u'lastupdated': u'2017-02-08T17:53:18', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'ac637e2f0b': {u'picture': u'', u'locked': False, u'name': u'ac637e2f0b', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'swjxWxPqkdQvhRY': {u'picture': u'', u'locked': False, u'name': u'Read', u'appdata': {u'version': 1, u'data': u'xoDF0_r01_d02'}, u'lastupdated': u'2017-02-08T17:53:18', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'hdsWuEIkDaF219v': {u'picture': u'', u'locked': False, u'name': u'Read', u'appdata': {u'version': 1, u'data': u'K4pn2_r02_d02'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'c3b59438104f0251': {u'picture': u'', u'locked': False, u'name': u'c3b59438104f0251', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'bkIRa6aFaNXzgN0': {u'picture': u'', u'locked': False, u'name': u'Arctic aurora', u'appdata': {u'version': 1, u'data': u'IcBm0_r02_d17'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'f5d73dbdd5': {u'picture': u'', u'locked': False, u'name': u'f5d73dbdd5', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'2778251b21-on-0': {u'picture': u'', u'locked': False, u'name': u'2778251b21-on-0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'25b485af0a': {u'picture': u'', u'locked': False, u'name': u'25b485af0a', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'rddcXvKCsk5lcpQ': {u'picture': u'', u'locked': False, u'name': u'Tropical twilight', u'appdata': {u'version': 1, u'data': u'FMCVy_r03_d16'}, u'lastupdated': u'2017-02-08T17:53:52', u'lights': [u'7'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'4PlzgvjvXLMCzrR': {u'picture': u'', u'locked': False, u'name': u'Relax', u'appdata': {u'version': 1, u'data': u'9G5HU_r01_d01'}, u'lastupdated': u'2017-02-08T17:53:18', u'lights': [u'4', u'5', u'6'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'hmMkN6rWSudRKwL': {u'picture': u'', u'locked': False, u'name': u'Tropical twilight', u'appdata': {u'version': 1, u'data': u'n4SSh_r02_d16'}, u'lastupdated': u'2017-02-08T17:53:37', u'lights': [u'1'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'ej54PDoFU8D2TMl': {u'picture': u'', u'locked': False, u'name': u'Arctic aurora', u'appdata': {u'version': 1, u'data': u'y1U5y_r04_d17'}, u'lastupdated': u'2017-02-08T17:54:03', u'lights': [u'3'], u'version': 2, u'recycle': False, u'owner': u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk'}, u'ac637e2f0-on-0': {u'picture': u'', u'locked': False, u'name': u'Relax on 0', u'appdata': {}, u'lastupdated': None, u'lights': [u'1', u'3'], u'version': 1, u'recycle': True, u'owner': u'none'}, u'48aa892d8-on-0': {u'picture': u'', u'locked': False, u'name': u'Test on 0', u'appdata': {}, u'lastupdated': u'2016-01-03T16:53:17', u'lights': [u'4', u'5', u'6'], u'version': 1, u'recycle': True, u'owner': u'h9hlIrWJfU0ffE3k'}}, u'lights': {u'1': {u'name': u'Noahs rum', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 13651, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4983, 0.4152], u'reachable': True, u'bri': 1, u'ct': 439, u'sat': 196}, u'uniqueid': u'00:17:88:01:00:be:87:69-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'3': {u'name': u'Golvlampa vardagsrum', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 12740, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.5222, 0.4142], u'reachable': True, u'bri': 128, u'ct': 488, u'sat': 222}, u'uniqueid': u'00:17:88:01:00:be:7a:b1-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'5': {u'name': u'K\xf6k fl\xe4kt', u'swversion': u'5.50.1.19085', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 14423, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4744, 0.413], u'reachable': True, u'bri': 1, u'ct': 397, u'sat': 165}, u'uniqueid': u'00:17:88:01:00:e8:e6:41-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'4': {u'name': u'K\xf6k fl\xf6kt 2', u'swversion': u'5.50.1.19085', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 13707, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4972, 0.4153], u'reachable': True, u'bri': 1, u'ct': 439, u'sat': 195}, u'uniqueid': u'00:17:88:01:00:e9:07:42-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'7': {u'name': u'Meyas rum', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 13277, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5081, 0.415], u'reachable': True, u'bri': 1, u'ct': 459, u'sat': 207}, u'uniqueid': u'00:12:4b:00:02:3f:69:50-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'6': {u'name': u'K\xf6k diskho', u'swversion': u'5.50.1.19085', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 14956, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4571, 0.4097], u'reachable': True, u'bri': 1, u'ct': 366, u'sat': 140}, u'uniqueid': u'00:17:88:01:00:e8:e7:1a-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'8': {u'name': u'F\xf6nsterlampa Allrum', u'swversion': u'1.2.214', u'manufacturername': u'IKEA of Sweden', u'state': {u'on': True, u'reachable': False, u'bri': 142, u'alert': u'none'}, u'uniqueid': u'00:0b:57:ff:fe:25:04:d8-01', u'type': u'Dimmable light', u'modelid': u'TRADFRI bulb E27 opal 1000lm'}}, u'groups': {u'1': {u'name': u'K\xf6k', u'lights': [u'4', u'5', u'6'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 14956, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4571, 0.4097], u'bri': 1, u'ct': 366, u'sat': 140}, u'recycle': False, u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Meya', u'lights': [u'7'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 13277, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5081, 0.415], u'bri': 1, u'ct': 459, u'sat': 207}, u'recycle': False, u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Noah', u'lights': [u'1'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 13651, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4983, 0.4152], u'bri': 1, u'ct': 439, u'sat': 196}, u'recycle': False, u'type': u'Room', u'class': u'Living room'}, u'4': {u'name': u'Vardagsrum', u'lights': [u'3'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 12740, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.5222, 0.4142], u'bri': 128, u'ct': 488, u'sat': 222}, u'recycle': False, u'type': u'Room', u'class': u'Living room'}}, u'schedules': {}, u'sensors': {u'1': {u'name': u'Daylight', u'config': {u'on': True, u'configured': False, u'sunriseoffset': 30, u'sunsetoffset': -30}, u'swversion': u'1.0', u'state': {u'daylight': None, u'lastupdated': u'none'}, u'manufacturername': u'Philips', u'type': u'Daylight', u'modelid': u'PHDL00'}}, u'config': {u'starterkitid': u'', u'portalconnection': u'connected', u'whitelist': {u'df621c0558702cc0f371c27c85410cad': {u'last use date': u'2017-08-13T05:06:11', u'create date': u'2015-12-16T20:36:53', u'name': u'Indigo Hue Plugin'}, u'421B1E775327E6421F75B7EE12CBC0FE': {u'last use date': u'2013-08-03T11:10:46', u'create date': u'2013-08-03T11:08:31', u'name': u'HueDisco'}, u'1b42aa55441cedda3537f9392827b900': {u'last use date': u'2016-10-16T15:34:31', u'create date': u'2016-10-02T12:19:32', u'name': u'HueDiscoBridgeConnec#SomePhone'}, u'h9hlIrWJfU0ffE3k': {u'last use date': u'2017-08-12T11:01:30', u'create date': u'2013-10-04T16:37:44', u'name': u'Gustens'}, u'0f607264fc6318a92b9e13c65db7cd3c': {u'last use date': u'2014-02-20T18:29:03', u'create date': u'2013-11-24T17:30:05', u'name': u'Martin Gustafssons iPad 4'}, u'A46F6F52F78B9E0184EA015571887655': {u'last use date': u'2013-08-04T12:18:37', u'create date': u'2013-08-01T17:12:40', u'name': u'HueParty'}, u'3382417dacf7765e716e4cd6b6b610a1': {u'last use date': u'2013-09-17T17:26:03', u'create date': u'2013-08-01T17:09:42', u'name': u'Martin Gustafssons iPad 4'}, u'newdeveloper': {u'last use date': u'2013-08-14T17:19:09', u'create date': u'2013-08-14T17:17:48', u'name': u'test user'}, u'4371000000': {u'last use date': u'2014-10-22T15:41:58', u'create date': u'2013-08-14T17:24:58', u'name': u'irule'}, u'7bFgQgnXnXVFkOuR': {u'last use date': u'2017-06-16T16:46:52', u'create date': u'2013-10-24T16:55:10', u'name': u'Martin Gustafssons iPad 4'}, u'57AE2B3549E3E96748E1320C01097F3A': {u'last use date': u'2014-12-26T08:02:56', u'create date': u'2013-12-06T15:12:19', u'name': u'Huelloween'}, u'TDfY148ciZMiOOwSC09maLBrfN9goB01': {u'last use date': u'2015-11-13T14:19:24', u'create date': u'2013-10-25T17:01:49', u'name': u'VeraTest'}, u'60927f10222dd4fc78e6acfb1efe647a': {u'last use date': u'2016-09-24T06:31:50', u'create date': u'2015-12-24T11:33:10', u'name': u'Hue Christmas#Gustens iphone'}, u'43cc09b6b6d4991189f6983d40ed9917': {u'last use date': u'2015-11-09T20:31:53', u'create date': u'2013-08-01T16:35:10', u'name': u'Gustens'}, u'1ce74c37ba2564782180013f7fdb90': {u'last use date': u'2017-05-19T18:18:47', u'create date': u'2016-10-15T16:56:57', u'name': u'iftttv2'}, u'pffABdBr206quDYqmqY5OjbBtcpltJdyooQuubFk': {u'last use date': u'2017-08-12T11:01:30', u'create date': u'2017-02-08T17:46:25', u'name': u'hue_ios_app#Gustens iphone'}, u'28C0F5406F3AD7C4969D63FAD94E7993': {u'last use date': u'2015-12-24T11:58:15', u'create date': u'2015-12-24T11:40:49', u'name': u'HueDisco'}, u'3ace6d073e5ec92335c895bc1d988ce3': {u'last use date': u'2016-04-02T18:55:08', u'create date': u'2016-04-02T18:39:45', u'name': u'Hue Disco#Gustens iphone'}, u'7859f6c9297f558817327a7ede54c98': {u'last use date': u'2017-03-07T17:33:31', u'create date': u'2017-01-22T16:50:54', u'name': u'HueDiscoBridgeConnec#SomePhone'}, u'74F35F10AD669E8869510E3A94CE3F4F': {u'last use date': u'2014-11-08T17:55:04', u'create date': u'2013-08-01T17:46:54', u'name': u'HueDisco'}, u'IDabYR3A32J8h-VrCDuvkePM-sOKOSDZW1clJjCx': {u'last use date': u'2017-06-16T16:46:52', u'create date': u'2017-06-16T16:33:08', u'name': u'HueDiscoBridgeConnec#SomePhone'}}, u'zigbeechannel': 15, u'timezone': u'Europe/Stockholm', u'gateway': u'192.168.0.1', u'modelid': u'BSB002', u'portalstate': {u'communication': u'disconnected', u'outgoing': True, u'signedon': True, u'incoming': False}, u'proxyaddress': u'none', u'datastoreversion': u'61', u'replacesbridgeid': u'001788FFFE0AB32F', u'dhcp': False, u'localtime': u'2017-08-13T07:06:11', u'proxyport': 0, u'UTC': u'2017-08-13T05:06:11', u'factorynew': False, u'swupdate': {u'devicetypes': {u'bridge': False, u'sensors': [], u'lights': []}, u'url': u'', u'text': u'', u'checkforupdate': False, u'updatestate': 0, u'notify': False}, u'apiversion': u'1.19.0', u'mac': u'00:17:88:23:b2:62', u'linkbutton': False, u'bridgeid': u'001788FFFE23B262', u'ipaddress': u'192.168.0.222', u'portalservices': True, u'name': u'Philips hue', u'swversion': u'1705121051', u'netmask': u'255.255.255.0', u'internetservices': {u'remoteaccess': u'connected'}, u'backup': {u'status': u'idle', u'errorcode': 0}}}
   Hue Lights                      Loaded 7 lights.
Sat Aug 12, 2017 11:43 pm
nsheldon offline
Re: Hue Lights discussion
Version 1.6.5 Posted
  • Added support for the IKEA dimmable light identified by “TRADFRI bulb E27 opal 1000lm” when paired to the Hue hub.
Sun Aug 13, 2017 12:28 am
Gusten offline
Thankyou, its working perfectly :-)
Sun Aug 13, 2017 12:32 am
nsheldon offline
Excellent! Happy automating. :-)
Thu Aug 31, 2017 1:16 pm
Busta999 offline
Looks like Philips are opening up motion and switches, at least for HomeKit.
Will we be able to piggyback for Indigo?
https://www.cnet.com/news/philips-hue-expands-on-homekit-teases-new-hue-entertainment/
Page 52 of 103 1 ... 49, 50, 51, 52, 53, 54, 55 ... 103
