Watchdog used to work great, but having difficulties
Tue May 21, 2019 4:53 pm
mundmc offline
I am sorry I am unsure which update caused problems for me. I disabled the reliance on Pushover (and no longer use prowl). When I enable it, my log fills with this repeatedly:
Watchdog Starting Watchdog monitoring thread
Watchdog Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 103, in runConcurrentThread
File "plugin.py", line 259, in checkDevices
KeyError: u'D1144855710'
Watchdog Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
I deleted all the items it was watching. I re-installed. I disabled, deleted, and re-installed. Still the same. Thoughts?
Wed May 22, 2019 2:42 am
racarter offline
Re: Watchdog used to work great, but having difficulties
It seems the plugin is trying to process device ID 1144855710. Is this a valid device ID? The plugin should cope with deleted devices, so I don't know what's happened here.
If all else fails, disable the plugin and then delete the preference file com.racarter.indigoplugin.watchdog.indiPref in the /Preferences/Plugins folder and re-enable the plugin.
Wed May 22, 2019 5:24 am
mundmc offline
A-ha! The preference file- that’s what I kept missing in my re-install.
MunDMC
Wed May 29, 2019 6:16 am
changeagent offline
I am having similar problems. Getting these errors:
KeyError: u'D1587412639'
Had to disable the plugin.
Wed May 29, 2019 6:32 am
racarter offline
I suggest you follow the advice I gave in my previous post, which should resolve the issue.
I still can’t figure out how the situation arises; any clues you can provide would be useful.
Wed May 29, 2019 8:20 am
racarter offline
This issue is caused by two dictionaries getting out of sync somehow. I've just released version 1.7.4 which should stop the error from occurring.
