Starting today whenever I start the plugin in and authenticate, I get
- Code: Select all
{"error":{"code":404,"message":"method not found"}}
I would assume this is a Netatmo issue. But, do you know anything about this?
siclark wrote:I had tried that, no joy.I just requested a new token from the plugin menu. Usual webpage opened and I accepted and got 200 code indicating all worked.
Restart of teh plugin works as well.
racarter wrote:Well, I can login into their website with a browser and display my data..As a matter of interest, can you access your system via the Netatmo app?
5 Dec 2023 at 21:10:43
NetatmoWelcome Processing Weather Station 0
NetatmoWelcome Processing Modules:
NetatmoWelcome Processing Master Bedroom NAMain
NetatmoWelcome Processing Noise
NetatmoWelcome Processing Temp
NetatmoWelcome Processing Temp Trend
NetatmoWelcome Processing Pressure
NetatmoWelcome Processing Humidity
NetatmoWelcome Processing CO2
NetatmoWelcome Processing CO2 Cal
NetatmoWelcome Processing Min/Max
NetatmoWelcome Processing Timestamp
NetatmoWelcome Finding weather device
NetatmoWelcome - Updating Netatmo Indoor
NetatmoWelcome Processing Outdoor NAModule1
NetatmoWelcome Error Outdoor module WS0M1 update error: <class 'KeyError'>
MartinG wrote:May or may not be related, but spomtaneously and for the last few days I've been seeing this error. Just haven't had time to deal with it. I can see sensible data from this module in the app, including good battery status info.
Debug info is as below:5 Dec 2023 at 21:10:43
Neither requesting a new access token nor restarting the plugin worked for me.
berkinet wrote:Can no longer authenticate with Netatmo.
- Code: Select all
9 Dec 2023 at 18:04:14
9 Dec 2023 at 18:14:16
9 Dec 2023 at 18:24:19
NetatmoWelcome Weather Station update fault cleared
10 Dec 2023 at 16:44:57
NetatmoWelcome Error Device Netatmo Outdoor is unreachable after ten attempts
12 Dec 2023 at 15:37:17
NetatmoWelcome {'min_temp': 6.6, 'max_temp': 8.6, 'date_max_temp': 1702351435, 'date_min_temp': 1702339336}
NetatmoWelcome Device reachable is True
13 Dec 2023 at 00:21:30
NetatmoWelcome Error Weather station WS-0 update error: <class 'KeyError'> 'dashboard_data'
13 Dec 2023 at 00:31:32
13 Dec 2023 at 10:57:42
NetatmoWelcome Logging all Healthy Home messages to Event Log
NetatmoWelcome Logging all weather station messages to Event Log
NetatmoWelcome Webhook messages will be written to Event Log
NetatmoWelcome Debug messages will be written to Event Log
13 Dec 2023 at 11:27:39
NetatmoWelcome Weather station message logging is off
NetatmoWelcome Webhook messages will not be written to Event Log
NetatmoWelcome Debug messages will not be written to Event Log
13 Dec 2023 at 11:56:02
