New Release
Mon Jan 25, 2021 10:58 am
racarter offline
New Release
I've just uploaded a new release of this plugin which fixes processing of multiple weather stations with the same owner. This necessitated changing the address nomenclature for weather station modules, so:
*** PLEASE NOTE ***
Before installing this release it is necessary to delete or rename all existing weather station modules (but not stations) with addresses starting 'WSM' to allow creation of new modules with a revised address nomenclature. Failure to do this will result in 'name not unique' errors. Note that any renamed devices will no longer be updated.
Tue Aug 10, 2021 11:22 am
berkinet offline
Re: New Release
Finally updating to 1.5.5, and I have a question.
Am I understanding this correctly? If I do nothing, I will get errors. But, if I do change the names, then the devices will never get updated? And, indeed, that is what happens. So, is the point of the renaming so I can do a dependency check and an orderly conversion to the new devices, then delete the old (renamed) devices?
Tue Aug 10, 2021 11:27 am
racarter offline
Re: New Release
Exactly that. :)
Tue Aug 10, 2021 11:33 am
berkinet offline
Re: New Release
racarter wrote:
Exactly that. :)
Thanks. And, thanks for the update.
