Name conflict?
Tue Jan 05, 2021 12:27 pm
mbordas offline
Name conflict?
I'm trying to setup the Netatmo Multi plugin for the first time, and I'm running into an error. I have two weather stations (in different locations) and no other Netatmo devices (Welcome camera, etc..)
   NetatmoWelcome                  Renewing expired tokens
   NetatmoWelcome                  Authenticating...
   NetatmoWelcome                  Authenticating for Weather Station(s)
   NetatmoWelcome                  Requested: read_station
   NetatmoWelcome                  Your access token is: 583.....
   NetatmoWelcome                  Your refresh token is: 583....
   NetatmoWelcome                  Creating Netatmo weather device for Kitchen
   NetatmoWelcome Error            Error in plugin execution runConcurrentThread:
  File "plugin.py", line 207, in runConcurrentThread
  File "plugin.py", line 659, in createDevices
ValueError: NameNotUniqueError
   NetatmoWelcome Error            plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
It created a few devices for Air Monitor for a few of the modules, but nothing else. It looks like it's getting stuck on 'Kitchen'. I suspect it might be because I have a module named 'Kitchen' in each of the two weather stations, but the curious thing is neither has been created in Indigo yet.
Anyone run into this before?
Tue Jan 05, 2021 1:18 pm
racarter offline
Re: Name conflict?
You can’t have two Indigo devices with the same name. You’ll need to rename one of them in the Netatmo app before running the plug-in.
