Several modules are not added
Sat Nov 28, 2020 8:48 am
racarter offline
Re: Several modules are not added
The latest version of the plugin uses the MAC number of the module for third party stations so yes, you would have to delete the third party devices and allow the plugin to recreate.
In the case of your 'guest station', if the owner uploads the station data to the Netatmo weather map you should be able to add it as a favourite and have it processed in the same way as others.
Sat Nov 28, 2020 9:00 am
davinci offline
No, sorry the same issue again.
They are still labeled as WS-0 etc. and the labels are wrong.
The script fails when having guest stations. When I remove it, it works.
Sat Nov 28, 2020 9:23 am
racarter offline
Your OWN station will be labelled WS. I have left it like this for backward compatibility for all other users.
Third party stations use their MAC numbers.
Wed Dec 02, 2020 6:38 am
davinci offline
Just wanted to add this: the plugin does not work with shared houses, it only works with third party stations when they are added over Netatmo weathermap. So internal sensor can't be shared with this plugin.
In my case that is not an issue:
Thanks for adding support for the rain and wind sensor for third party sensors.
