Heatmiser Neo log error
Tue Jan 05, 2021 5:14 pm
Colly offline
Hi Alan,
Noticed this evening that one of my thermostats didn't get set correctly. Found the following in the log.
5 Jan 2021 at 18:00:00
   Schedule                        Winter_Even_Up_18:00
   Heatmiser-Neo Error             {"SET_TEMP":[19.0, "Master"]}
   Heatmiser-Neo Error             Invalid second argument to SET_TEMP, should be a valid device or array of valid devices
Then slightly later for a time delayed action of same schedule:
  File "plugin.py", line 523, in actionControlThermostat
  File "plugin.py", line 295, in getNeoData
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/__init__.py", line 338, in loads
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/decoder.py", line 366, in decode
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/decoder.py", line 384, in raw_decode
ValueError: No JSON object could be decoded
   Heatmiser-Neo Error             Error in plugin execution runConcurrentThread:
  File "plugin.py", line 88, in runConcurrentThread
  File "plugin.py", line 186, in updateReadings
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/decoder.py", line 382, in raw_decode
ValueError: Expecting , delimiter: line 1 column 5761 (char 5760)
   Heatmiser-Neo Error             plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   Heatmiser-Neo                   Starting Heatmiser Neo monitoring thread
The schedule runs fine now if I manually execute it.
Rgds
Colly
Wed Jan 06, 2021 2:15 am
racarter offline
Re: Heatmiser Neo log error
Hi Colly
Looks like the Heatmiser server isn’t returning data. Can you switch on comms logging please? That might provide some clues.
Wed Jan 06, 2021 5:37 am
Colly offline
See below from log:
   Heatmiser-Neo                   --> {"INFO":0}
   Heatmiser-Neo                   <-- {"devices":[{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"19.0","CURRENT_TEMPERATURE":"19.0","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"19.0","MIN_TEMPERATURE":"18.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":true,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":24,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Kids Shower"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"6.0","CURRENT_TEMPERATURE":"6.7","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"8.0","MIN_TEMPERATURE":"7.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":125,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Games Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"15.0","CURRENT_TEMPERATURE":"17.0","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":16,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"20.0","MIN_TEMPERATURE":"17.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":132,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Ryans Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"15.0","CURRENT_TEMPERATURE":"16.9","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":16,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"20.0","MIN_TEMPERATURE":"17.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":119,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Katies Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"15.0","CURRENT_TEMPERATURE":"16.9","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"18.0","MIN_TEMPERATURE":"16.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":115,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Master"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"19.0","CURRENT_TEMPERATURE":"18.6","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"19.0","MIN_TEMPERATURE":"17.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":145,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Spare"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"15.0","CURRENT_TEMPERATURE":"17.5","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":20,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"18.0","MIN_TEMPERATURE":"17.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":124,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Master Ensuite"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"18.0","CURRENT_TEMPERATURE":"19.3","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"20.0","MIN_TEMPERATURE":"18.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":240,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Guest Ensuite"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"18.0","CURRENT_TEMPERATURE":"20.5","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":20,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"20.0","MIN_TEMPERATURE":"19.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":245,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Entrance"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"18.0","CURRENT_TEMPERATURE":"18.7","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"19.0","MIN_TEMPERATURE":"17.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":253,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Guest Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"19.5","CURRENT_TEMPERATURE":"20.2","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"21.0","MIN_TEMPERATURE":"19.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":253,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Living Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"20.0","CURRENT_TEMPERATURE":"19.7","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":20,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"20.0","MIN_TEMPERATURE":"19.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":248,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Sitting Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"19.5","CURRENT_TEMPERATURE":"20.2","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"21.0","MIN_TEMPERATURE":"19.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":254,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Dining Room"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"19.5","CURRENT_TEMPERATURE":"20.8","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"21.0","MIN_TEMPERATURE":"19.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":240,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Kitchen"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"19.0","CURRENT_TEMPERATURE":"19.7","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":21,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"20.0","MIN_TEMPERATURE":"18.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":246,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Back Toilet"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"15.0","CURRENT_TEMPERATURE":"18.5","DEMAND":false,"DEVICE_TYPE":1,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":18,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"19.0","MIN_TEMPERATURE":"18.0","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":false,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"6_HEAT_LEVELS":true,"MANUAL_OFF":true,"THERMOSTAT":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":101,"WRITE_COUNT":114,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Landing"},{"AWAY":false,"COOLING":false,"COOLING_ENABLED":false,"COOLING_TEMPERATURE_IN_WHOLE_DEGREES":0,"COOL_INP":false,"COUNT_DOWN_TIME":"0:00","CRADLE_PAIRED_TO_REMOTE_SENSOR":false,"CRADLE_PAIRED_TO_STAT":false,"CURRENT_FLOOR_TEMPERATURE":127,"CURRENT_SET_TEMPERATURE":"0.0","CURRENT_TEMPERATURE":"255.255","DEMAND":false,"DEVICE_TYPE":6,"ENABLE_BOILER":false,"ENABLE_COOLING":false,"ENABLE_PUMP":false,"ENABLE_VALVE":false,"ENABLE_ZONE":false,"FAILSAFE_STATE":false,"FAIL_SAFE_ENABLED":false,"FLOOR_LIMIT":false,"FULL/PARTIAL_LOCK_AVAILABLE":false,"HEAT/COOL_MODE":false,"HEATING":false,"HOLD_TEMPERATURE":0,"HOLD_TIME":"0:00","HOLIDAY":false,"HOLIDAY_DAYS":0,"HUMIDITY":0,"LOCK":false,"LOCK_PIN_NUMBER":"0000","LOW_BATTERY":false,"MAX_TEMPERATURE":"255.255","MIN_TEMPERATURE":"255.255","MODULATION_LEVEL":0,"NEXT_ON_TIME":"255 days 255:255","OFFLINE":true,"OUPUT_DELAY":false,"OUTPUT_DELAY":0,"PREHEAT":false,"PREHEAT_TIME":"255:255","PROGRAM_MODE":"5DAY/2DAY","PUMP_DELAY":false,"RADIATORS_OR_UNDERFLOOR":false,"SENSOR_SELECTION":"BUILT_IN_AIR_SENSOR","SET_COUNTDOWN_TIME":0,"STANDBY":false,"STAT_MODE":{"4_HEAT_LEVELS":true,"MANUAL_OFF":true,"TIMECLOCK":true},"TEMPERATURE_FORMAT":false,"TEMP_HOLD":false,"TIMECLOCK_MODE":false,"TIMER":false,"TIME_CLOCK_OVERIDE_BIT":false,"ULTRA_VERSION":0,"VERSION_NUMBER":79,"WRITE_COUNT":83,"ZONE_1PAIRED_TO_MULTILINK":true,"ZONE_1_OR_2":false,"ZONE_2_PAIRED_TO_MULTILINK":false,"device":"Heatmiser Plugin"}]}
Wed Jan 06, 2021 6:44 am
racarter offline
Can't see anything wrong with the json. Is the fault still present, or was it a one-off?
Wed Jan 06, 2021 6:52 am
Colly offline
I'll monitor it for this evenings schedules and see what happens.
Wed Jan 06, 2021 7:17 am
racarter offline
The same code runs in scheduled and manual cases, so I'm guessing it was a one-off Heatmiser server glitch - but let me know if it happens again.
Wed Jan 06, 2021 5:03 pm
Colly offline
Hi Alan,
Seems like it was a temporary glitch. All schedules ran this evening without an issue. Thanks for looking in to it.
Wed Jan 06, 2021 5:07 pm
racarter offline
You’re welcome. Glad it’s sorted.
