Where can I buy it? 8 Channel Network Relay
Fri Jun 07, 2019 10:20 am
anhbloginc offline
I'm interested in this product but it seems the eBay link you mentioned on the page only has one unit in stock. I need more than one as well as less relay version as well.
Could anyone please tell me where I can seek for a working product?
Fri Jun 07, 2019 10:34 am
Re: Where can I buy it? 8 Channel Network Relay
Fri Jun 07, 2019 10:50 am
anhbloginc offline
FlyingDiver wrote:
Is it working with this plugin and has the same API details as the one that mentioned on the plugin page?
Fri Jun 07, 2019 11:04 am
anhbloginc wrote:
You should ask the eBay seller that. There's no manufacturer part number on either page, so the only way to be sure is to ask the seller.
Mon Jun 10, 2019 1:02 am
TwitchCaptain offline
This thread has a few links to give you some more ideas where to find these boards. viewtopic.php?f=302&t=22371
Good luck!
-Captain
Mon Jun 10, 2019 7:36 am
anhbloginc offline
Good luck!
-Captain
I recently purchased two units of this version and hope it works.
https://www.thanksbuyer.com/8-channel-2 ... ay%20board
It's the same seller which named thanksbuyer-hobby on eBay, I think.
One thing I noticed that there is a new feature, have you tried yet?
https://www.thanksbuyer.com/download/35 ... l-V1.0.pdf
According to this document, I can use "800ms pluse,Open relay for 800ms,then close" feature. However, I don't know whether this plugin in Indigodomo support this new feature or not.
P(n),n=1:8,Such as the need to pluse the relay 1, then send the string “P1”. The board will
return “Press 1” after the relay in operation.
Sun Jun 16, 2019 12:25 am
Thanks for the update anhbloginc! They keep adding new features; it's pretty cool. Unfortunately I have a board with version 5.0.0 and it has none of these new features. I have no real way to test that they work, so I can't really write code for them. I can and will at some point make the port configurable, but I don't imagine I'll do much more than that. Community contributions are always welcomed.
Sun Jun 16, 2019 1:36 am
Not that I need any of these changes in features but I’m assuming there’s no way to upgrade the firmware on these boards to add said functionality?
