Using 8 Channel Input to display in HomeKit
Posted: Sat Jan 12, 2019 5:25 am
Hi Captain,
This is a mix between this plugin and the HomeKit Bridge plugin. Anyhow I'll start here and move over to the other forum if needs be. In the absence of a standard alarm system I've added a number of door contacts to the inputs of the 8 Channel board and this works absolutely great - thanks for the plugin, I'll be buying more boards..
Question: is the input status the same as other devices? On / Off? They appear to be. The reason I ask is that I can't get it to display in my Home App. If the status is the same as other devices then maybe it's a question for C4W.
TIA
Colly
TIA
Colly
