not able to add Rm mini to indigo
Sat Jan 18, 2020 1:59 pm
stebertu offline
Hi, thank you for the fantistic plugin... I was using it with 4 Rm pro+ with no problems , then I tried to add 2 newRm mini 3, but I´m struggling without success to comunicate with them. They are all working perfectly with the new Broadlink APP , but not with the old e-Control. Neither homebridge on my mac or my Raspbian Homebridge seem to find the new Rm mini.. On the last try I got this message from Indigo log
Broadlink Devices Error 6 Device(s) Discovered! If you did not receive the device you're looking for, enter the data manually.
Broadlink Devices Error Discovered Device: IR|RM2 Pro Plus3 - type: 0x279d, IP: 192.168.1.189, Auth: True, Device: True
Broadlink Devices Error Discovered Device: IR|RM2 Pro Plus3 - type: 0x279d, IP: 192.168.1.186, Auth: True, Device: True
Broadlink Devices Error Discovered Device: UNKNOWN|UNKNOWN - type: 0x5f36, IP: 192.168.1.185, Auth: False, Device: False
Broadlink Devices Error Discovered Device: IR|RM2 Pro Plus3 - type: 0x279d, IP: 192.168.1.188, Auth: True, Device: True
Broadlink Devices Error Discovered Device: IR|RM2 Pro Plus3 - type: 0x279d, IP: 192.168.1.192, Auth: True, Device: True
Broadlink Devices Error Discovered Device: UNKNOWN|UNKNOWN - type: 0x5f36, IP: 192.168.1.184, Auth: False, Device: False
any suggestion ?
thank you
Stefano
Tue Oct 06, 2020 4:57 pm
agame offline
Re: not able to add Rm mini to indigo
did you have any joy with this?
I've had no success with two RM minis, and am assuming the current firmware no longer supports 3rd party control.
Sun Apr 11, 2021 7:03 pm
rustyhodge offline
While researching these to think about adding to my system, I saw this:
viewtopic.php?f=300&t=24260#p194495
tl;dr If you enable the cloud service, it disables the local control.
You may need to do a factory reset and re-add the device without cloud features.
Sun Apr 11, 2021 7:04 pm
rustyhodge offline
However, this may NOT solve the issue, per the thread above.
Mon May 03, 2021 7:42 am
kennybroh offline
I'm having the same issue. I haven't yet removed the device from the Cloud but am wondering if anyone has gotten the mini to work with the plug in?
Mon May 03, 2021 3:52 pm
agame offline
it seems the python library [i assume] used in the plugin is now a stale version, the python-broadlink library here is being actively maintained and purports to support recent firmware versions.
https://github.com/mjg59/python-broadlink
its on my list to give it a go (independently of the plugin)...
Sat Aug 28, 2021 2:35 pm
vtmikel offline
Anyone having any luck updating the plugin? I'm trying to get a RM4 Pro to work with RF. I'm experimenting with the python 3 library on a separate box.
