not able to add Rm mini to indigo
Sat Jan 18, 2020 1:59 pm
stebertu offline
Hi, thank you for the fantistic plugin... I was using it with 4 Rm pro+ with no problems , then I tried to add 2 newRm mini 3, but I´m struggling without success to comunicate with them. They are all working perfectly with the new Broadlink APP , but not with the old e-Control. Neither homebridge on my mac or my Raspbian Homebridge seem to find the new Rm mini.. On the last try I got this message from Indigo log
Broadlink Devices Error 6 Device(s) Discovered! If you did not receive the device you're looking for, enter the data manually.
Broadlink Devices Error Discovered Device: IR|RM2 Pro Plus3 - type: 0x279d, IP: 192.168.1.189, Auth: True, Device: True
Broadlink Devices Error Discovered Device: IR|RM2 Pro Plus3 - type: 0x279d, IP: 192.168.1.186, Auth: True, Device: True
Broadlink Devices Error Discovered Device: UNKNOWN|UNKNOWN - type: 0x5f36, IP: 192.168.1.185, Auth: False, Device: False
Broadlink Devices Error Discovered Device: IR|RM2 Pro Plus3 - type: 0x279d, IP: 192.168.1.188, Auth: True, Device: True
Broadlink Devices Error Discovered Device: IR|RM2 Pro Plus3 - type: 0x279d, IP: 192.168.1.192, Auth: True, Device: True
Broadlink Devices Error Discovered Device: UNKNOWN|UNKNOWN - type: 0x5f36, IP: 192.168.1.184, Auth: False, Device: False
any suggestion ?
thank you
Stefano
