- Posted on
Thu Nov 29, 2012 1:52 pm
jay (support)
offline
- Site Admin
Unfortunately, looking at the issue, it's clear that the old communication mechanism isn't going to work. The first thing you do is issue a login command, which passes back a token that you use on every subsequent request. iTunes 11 is returning an error (503, service unavailable) when we issue the login command. That means that iTunes no longer supports that particular function. Without the token that's passed back, there is no way to further communicate with iTunes.
So, it looks like the plugin will not work with iTunes 11 unless some industrious hacker out there can reverse engineer what's happening between the remote app and iTunes. My guess is that they've switched over to the encrypted method they use when talking to the Apple TV. Because of the encryption, it will never work unless they publish a key. Which they won't.
Thanks Apple - way to support your users.
I will be sticking with iTunes 10 until I can figure out something else. So disappointed at the moment even though I've been expecting this.
