Page 2 of 2
Re: Disable FanLinc LEDs?
PostPosted: Thu Jul 11, 2013 12:21 pm
by jay (support)
Probably won't get to it. But, since you can use the Send Raw to do it you can just do it that way.
PostPosted: Wed Jul 06, 2016 12:14 am
by akimball
I just used the raw command on seven installed FanLincs... bought since then end of 2012. Extended command worked on all 7. Would love to see this (on/off) in the Indigo FanLinc device itself if you ever get a wild hair. For now I just set it up as "contingent" action which I can select the fanlinc just prior to execution. 5 of my 7 fans, the LED's were brightly visible... cool effect, until I had a guest complain of the red light. :)
I know... I know you're busy, and yes... I appreciate all you do more than you know. Thanks :)
PostPosted: Wed Jul 06, 2016 5:29 am
by eme jota ce
This is great. Thanks for the commands.
I didn't bother to search the forum to check my memory, but seem to remember a similar discussion about these lights with the fanlincs were originally released. The solution then ... electrical tape (black). :shock:
