[ANSWERED]: Problems with disabling delayed actions
Thu Jul 22, 2010 4:47 am
col offline
I have set up x10 alarm trigger actions that can be enabled by a remote control, when I press 'on', these are delayed by 5 minutes so that I can leave the house without triggering sensors ect, and the 'off' button to disable the trigger actions when I come home.
My problem is if I press 'on' on the remote control and then 'off' within the 5 minutes it disables the trigger actions but still runs the commands, how can I stop them as soon as I press 'off'.
Thu Jul 22, 2010 9:24 am
Re: Problems with disabling delayed actions
Try executing an AppleScript action (copy/paste into the embedded edit field) that looks like this:
remove delayed actions for trigger "originalX10AlarmOnTriggerActionNameHere"
Fri Jul 23, 2010 3:30 am
col offline
Ok tried that but it does not remove the triggers . I put in the script- remove delayed actions for "_delayed_action_41" as this is what comes up in the time/date actions section,
Is this correct?
Fri Jul 23, 2010 8:56 am
Put the original Trigger Action name in there as you entered it in the Trigger Action dialog when you first created the Trigger Action that listens for the remote control button press.
Fri Jul 23, 2010 9:33 am
col offline
That worked,
thanks for the great support you give out here.
Colin
Mon Oct 20, 2014 9:41 am
AndyVirus offline
Hello,
This is exactly what i need to do also but in Python as i need to add it to an existing quite large python script. Do you know the equivalent of "remove delayed actions for trigger "originalX10AlarmOnTriggerActionNameHere"" in Python?
Also is there a document Indigo & Python commands? Or a way to figure out the python equivalent of GUI commands? 9Teach a man to fish and all that) :-)
Mon Oct 20, 2014 10:48 am
http://wiki.indigodomo.com/doku.php?id= ... :documents
There's scripting examples and the IOM (Indigo Object Model) at the bottom of that page.
Mon Oct 20, 2014 12:10 pm
Take a look at Remove Delayed Actions - should do what you want.
Just replace the 123 with the id of your trigger or with its name in quotes :)
Mon Oct 20, 2014 1:57 pm
AndyVirus offline
Perfect! Thanks for the direct link to exactly what i needed and thanks for the link to the IOM and examples!
Tue Nov 11, 2014 11:56 am
Juju offline
Re: [ANSWERED]: Problems with disabling delayed actions
Hello,
Is it possible to do the same thing (Python preferred but I think it's not possible, so Applescript) for delayed actions from a schedule ?
Julien
Auto answer :wink: : indigo.schedule.removeDelayedActions(123)
