jay (support) wrote:Try to factory reset the EZSnsRF and see if that makes a difference.
Been there done that; if I do a define and sync or resync before I try and attach the EZSnsRF to the Dakota transmitter, the EZ won't enter it's "slow flash" linking mode when I press the button on the side. If I get the EZ into slow to "fast flash on transmitter detect" with the button after a factory and just use the "press the button" in the dialog WITHOUT doing the Resync, the fast blinking on the EZ goes out, but the device doesn't show up in the Trigger sources, although it does show up as something like "state change 01" in the log when the driveway sensor triggers. If I do a define and sync after that, the state changes stop showing up in the log. I ran out of time to try other stuff, and since the driveway transmitter is buried at my sister's house 200 miles away, it'll probably be July before I get another shot, but I guess I'll try using the appliance module as an intermediary. However, it sure looks like (for some versions of the firmware anyway) the commands that Indigo 5 are sending to initially validate the PLC as a responder are totally trashing the EZSnsRF's programming (unless I've got a defective EZSnsRF).
