Am I being hacked?
Wed Nov 20, 2013 1:10 pm
noefresh offline
Am I being hacked?
Not long after I started running Indigo and Prism I noticed an ongoing stream of failed screensharing attempts from random IP addresses in Console. Kinda looks like a brute force attack. Is this a known issue with Indigo and/or any suggestions on how I can stop it from happening?
11/20/13 10:56:44.410 AM screensharingd[120]: Authentication: FAILED :: User Name: N/A :: Viewer Address: 5.79.65.105 :: Type: VNC DES
11/20/13 10:57:45.879 AM screensharingd[120]: Authentication: FAILED :: User Name: N/A :: Viewer Address: 24.56.76.242 :: Type: VNC DES
11/20/13 11:00:06.734 AM screensharingd[120]: Authentication: FAILED :: User Name: N/A :: Viewer Address: 221.141.2.48 :: Type: VNC DES
11/20/13 11:03:02.403 AM screensharingd[120]: Authentication: FAILED :: User Name: N/A :: Viewer Address: 112.175.245.6 :: Type: VNC DES
11/20/13 11:04:03.953 AM screensharingd[120]: Authentication: FAILED :: User Name: N/A :: Viewer Address: 121.125.64.181 :: Type: VNC DES
11/20/13 11:05:17.663 AM screensharingd[120]: Authentication: FAILED :: User Name: N/A :: Viewer Address: 221.143.43.141 :: Type: VNC DES
Wed Nov 20, 2013 1:23 pm
Re: Am I being hacked?
That does look like someone attempting to access screen sharing (VNC) on your Mac, but I don't believe it is related to Indigo or Prism (neither of which use VNC or screensharing).
Choose the Indigo Server->Stop Server menu item then wait a while and see if the connection attempts continue. Normally this type of attack is filtered at your router / DSL/Cable modem level if you have it configured correctly (presuming you don't have port forwarding setup for VNC).
Wed Nov 20, 2013 1:49 pm
Korey offline
[/code]
I had a similar situation, but with VNC (port5900). I changed the incoming port on my router to a non standard port and the attempts stopped.
Likley, someone scanned your IP address looking for known open service ports, found some, and are now trying to get in.
Korey
Wed Nov 20, 2013 1:53 pm
noefresh offline
Thanks guys- I changed the VNC port forward to something less standard and will see if that makes a difference!
