Every time I reboot my server, it comes back up with "Enable Indigo communication" unchecked for my iTunes server device. I've turned off the new "dirt nap" feature with iTunes and Indigo. Any ideas?
Phil
10/31/13 6:32:11.107 PM IndigoServer[333]: NOAA Weather Plus Error Unknown error getting weather for coordinates 38.633, -76.55: <urlopen error timed out>
10/31/13 7:00:00.577 PM IndigoServer[333]: Airfoil Error Speaker Master Bedroom is not available to disconnect from
10/31/13 7:18:58.866 PM Indigo 6[8498]: unable to modify user startup items preference
10/31/13 7:19:06.464 PM Indigo 6[8498]: HandlerError -- all command handlers are disabled
10/31/13 7:20:42.613 PM IndigoServer[333]: Quiting Indigo Server - received slow quit signal
10/31/13 7:20:42.613 PM IndigoServer[333]: Quiting Indigo Server - stopping plugins
Trigger Indigo Startup
Trigger Enable iTunes
iTunes Debug deviceStartComm: starting thread for 'iTunes'
iTunes Debug getMediaServerList: called
Connected to PowerLinc 2413U interface on port usbserial-A600exe2
PowerLinc address 18.B6.A4, firmware version 9.2
iTunes Debug deviceStartComm: updating from old address prop
iTunes Debug deviceStartComm: adding device id 1173155478 to the active thread queue
iTunes Debug statusThread.run(): creating iTunes Controller...
iTunes Debug statusThread.run(): connecting and logging in at: 2013-11-03 06:21:56.363372
iTunes Debug statusThread.run(): unknown Error for iTunes
iTunes Error iTunes stopped due to the following error (will attempt to recover in 10 seconds):
File "statusThread.py", line 117, in run
File "itunes.py", line 57, in iTunesLogin
File "itunes.py", line 205, in updateCache
AttributeError: 'ITunesController' object has no attribute 'errorLog'
iTunes Debug deviceStopComm: stopping thread for iTunes
iTunes Debug statusThread.run(): closing controller for exit at 2013-11-03 06:22:06.469773
iTunes Error iTunes has an unknown error - disabling
Starting plugin "iTunes 1.1.1" (pid 5605)
Started plugin "iTunes 1.1.1"
iTunes Debug deviceStartComm: starting thread for 'iTunes Server'
iTunes Debug deviceStartComm: adding device id 1523202327 to the active thread queue
iTunes Debug statusThread.run(): connecting and logging in at: 2013-11-10 10:40:14.272175
iTunes Debug statusThread.run(): unknown Error for iTunes Server
iTunes Error iTunes Server stopped due to the following error (will attempt to recover in 10 seconds):
iTunes Debug deviceStopComm: stopping thread for iTunes Server
iTunes Debug getDeviceConfigUiValues called
iTunes Debug getDeviceConfigUiValues(): starting pairing thread
iTunes Debug pairingThread: Starting run method
iTunes Debug pairingThread: Waiting for pairing message
iTunes Debug closedDeviceConfigUi: device config dialog closed
iTunes Debug closedDeviceConfigUi: pairing thread exists
iTunes Debug closedDeviceConfigUi: pairing thread is running, cancelling
iTunes Debug pairingThread: Received pairing message
iTunes Debug pairingThread: From host: ('127.0.0.1', 59993)
iTunes Debug pairingThread: Closing down
iTunes Debug statusThread.run(): closing controller for exit at 2013-11-10 10:40:24.355576
iTunes Error iTunes Server has an unknown error - disabling
iTunes Debug statusThread.run(): connecting and logging in at: 2013-11-10 10:40:31.346986
