I was quite excited to see that you have added temperature and (I hope) associations to the little temperature sensor. It is the cheapest way to measure temperature in the UK and will be a Godsend when it starts to work.
The resync failed so I excluded and re-included into the system ... no luck, it would not sync.
Setting parameter 7 failed, the instructions say it should be 0 (Off) or 255 (On - default). I tried to upload the instructions but the pdf extension was rejected. Are uploads not permitted?
Here is the log:
Z-Wave Syncing - started for device "035 - Binary Sensor"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 23 01 01 5A
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E
Z-Wave Debug . . getNodeNeighbors: nodeId 035, neighbors: - none -
Z-Wave Syncing - requesting neighbor list update of "035 - Binary Sensor"
Z-Wave Debug SENT requestNeighborUpdate: 01 04 00 48 23 90
Z-Wave Debug RCVD requestNeighborUpdate: 06 (ACK)
Z-Wave Debug RCVD requestNeighborUpdate: 01 05 00 48 01 21 92
Z-Wave Debug . . requestNeighborUpdate: node 035, update starting
Z-Wave Debug RCVD requestNeighborUpdate: 01 05 00 48 01 22 91
Z-Wave Debug . . requestNeighborUpdate: node 035, update finished
Z-Wave Syncing - neighbor list update complete (no change)
Z-Wave Syncing - assigning return route to "035 - Binary Sensor"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 23 01 9E
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 035, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 23 04 42 FC
Z-Wave Debug RCVD requestNodeInfo: 01 14 00 49 84 23 0E 04 20 00 71 85 80 70 72 30 86 84 31 EF 20 95
Z-Wave Debug . . requestNodeInfo: node 035, combined class list: 20v1 80v1 84v1 85v1 86v1 71v1 70v1 30v1 31v1 72v1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 23 02 72 04 05 43 F4
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 23 08 72 05 00 97 11 82 45 01 E9
Z-Wave Debug . . requestManufactureInfo: node 035, manufacturerId 0097, productId 11824501
Z-Wave Debug . . requestManufactureInfo: Digital Home Systems, Temperature/Binary Sensor (iTemp)
Z-Wave Syncing - retrieved manufacture and model names: Digital Home Systems - 0097, Temperature/Binary Sensor (iTemp) - 11824501
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 23 02 86 11 05 44 12
Z-Wave Debug RCVD requestVersInfoGen: 01 0D 00 04 00 23 07 86 12 06 02 61 00 27 04
Z-Wave Debug . . requestVersInfoGen: node 035, protoVers 2.97, appVers 0.39
Z-Wave Syncing - retrieved protocol version 2.97, app version 0.39
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 23 03 86 13 84 05 45 97
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 23 04 86 14 84 01 C1
Z-Wave Debug . . requestVersInfoCmdClass: node 035, class command 84 using version 1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 23 03 86 13 31 05 46 21
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 23 04 86 14 31 01 74
Z-Wave Debug . . requestVersInfoCmdClass: node 035, class command 31 using version 1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Binary Sensor : -- (04 : 20 : 00, base 30)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v1 85v1 86v1 71v1 70v1 30v1 31v1 72v1
Z-Wave Debug SENT requestWakeInterval: 01 09 00 13 23 02 84 05 05 47 07
Z-Wave Debug RCVD requestWakeInterval: 01 0C 00 04 00 23 06 84 06 00 0E 10 01 4F
Z-Wave Debug . . requestWakeInterval: node 035, interval 60 minutes, wakeTarget 001
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 23 02 85 05 05 48 09
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 23 03 85 06 02 53
Z-Wave Debug . . requestAssociationGroupCount: node 035, group count: 2
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 23 03 85 02 01 05 49 0C
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 23 06 85 03 01 05 00 01 51
Z-Wave Debug . . requestAssociations: node 035, group: 1, num associations: 1, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 035, group: 1, associations: [1]
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 23 03 85 02 02 05 4A 0C
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 23 05 85 03 02 05 00 57
Z-Wave Debug . . requestAssociations: node 035, group: 2, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 035, group: 2, associations: []
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 23 03 70 05 03 05 4B FE
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 23 05 70 06 03 01 00 A2
Z-Wave Debug . . requestConfigVal: node 035, parm index 3, value 0 (size 1)
Z-Wave Syncing - retrieved setting: "External switch mode" is 0
Z-Wave Debug . . requestConfigVal: node 035, combined config vals: 3:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 23 03 70 05 06 05 4C FC
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 23 06 70 06 06 02 00 00 A0
Z-Wave Debug . . requestConfigVal: node 035, parm index 6, value 0 (size 2)
Z-Wave Syncing - retrieved setting: "Enable external switch sensor" is 0
Z-Wave Debug SENT setConfigVal: 01 0C 00 13 23 05 70 04 06 01 FF 05 4D 02
Z-Wave Syncing - device "035 - Binary Sensor" setting "Enable external switch sensor" changed to 255
Z-Wave Debug . . pushNewValToNode: node 035, combined config vals: 3:0 6:255
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 23 03 70 05 07 05 4E FF
Z-Wave Debug module failed to reply to request (non-fatal, skipping request)
Z-Wave Syncing - failed to retrieve setting for parm 7: "Enable upper temperature trigger" (skipping)
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 23 03 70 05 08 05 4F F1
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 4F 01 A7 (node NAK)
Z-Wave Error Syncing - failed
Z-Wave Error No response from "035 - Binary Sensor". Module might be asleep, or is unreachable.
