I have a situation where 3 wall switches, A-B-C, control 1 light.
I have them all synced to each other so when any one of the switches
is on/off the others reflect the change at the switch.
I have 1 button for switch A on a CP
that toggles that switch and displays if it's on or off.
The problem is if switch B or C is turned on locally it doesn't show
the change in the switch A CP button. I made a bunch
of triggers to keep switch A in sync with the changes to B-C
but was hoping for a simpler solution.
Maybe some other way to do this?
Carl
