durosity wrote:I'm quite glad you posted about that, i was about ready to buy a few z-wave plugin sockets and was thinking of the TKBHome Plug Socket.. i think i might avoid them and just go for the everspring ones that i know don't do that.
autolog wrote:durosity wrote:I'm quite glad you posted about that, i was about ready to buy a few z-wave plugin sockets and was thinking of the TKBHome Plug Socket.. i think i might avoid them and just go for the everspring ones that i know don't do that.
I think you have misunderstood what I meant or I didn't explain it well enough
There is nothing wrong with the TKBHome Plug Socket (I am using the switch relay version NOT the dimmable socket), it works very well
The issue is with the bulb, it is a dimmable 20w CFL (see http://www.tlc-direct.co.uk/Products/LASD20BC.html) that is controlled by switching it on and off as I described i.e the dimming is programmed into the bulb by a sequence of ON/OFFs. I just wanted to prevent inadvertant resetting of the dimming level.
Hope this helps
durosity wrote:That's an idea I'll consider. At the moment I am trying to get some basics sorted out. I just wanted to make sure the software and z-wave would work for me. It looks like it will and so now I am going to look at extending the system... On a side note then have you considered just getting a dimmable z-wave plug and one of those new fancy LEDs that ikea are selling that are dimmable?
kw123 wrote:Not sure If I am doing this correctly but I appear to have crashed Indigothere is an option to disable and enable triggers in action.. and can be timed to re-enable after xx sec/minutes/hours
in actions:
Server Actions / Enable-Disable / enable xxx -disable xxx
jay (support) wrote:Well actually, I think all I want to do is prevent Indigo from sending commands to it for two seconds. The device could still remain active. I haven't been able to find anyway to prevent the on/off command from being sent from the device tab? I presume that when I click it On or Click it Off that the command isn't invoked via a trigger (although a trigger may be kicked off as a result of the state change)?I think what you're wanting to do is actually disable the device itself for 2 seconds - which is not possible.
Users browsing this forum: No registered users and 19 guests
