probably easy question - "on" vs "on (instant)"
Mon Sep 09, 2013 8:44 pm
The Mouse offline
Hi Perceptive..... Thanks in advance for your help, which I'm sure will be quick and concise, as always.
Problem with Insteon keypad not consistently responding. Event log shows sometimes a simple "on" is received, and sometimes "on to 100% (instant)" received, as shown:
Received INSTEON "Kitchen Pad" on (button 1)
or sometimes
Received INSTEON "Kitchen Pad" on (button 1) instant
though it seems I push the button the same each time.
In ignorance, I simply coded two seperate nearly-identical triggers. Works but not elegant. Can you enlighten on the proper approach?.... Thanks, thanks,
KC
So Cal
Sue me if I play too long....
Mon Sep 09, 2013 8:48 pm
Re: probably easy question - "on" vs "on (instant)"
The "instant" means the switch thinks that you double-tapped it, so it sends a different message. I sometimes use this control scenes, so that a normal ON or OFF at a switch just turns off that light, but a double-tap will execute a trigger in Indigo to also turn on some lamps in the same room.
