copy trigger actions to action group
Thu Sep 05, 2013 8:26 pm
I have some triggers that have MANY actions.. would like to move them over to action groups.
Any function or way I can do that besides reentering everything?
thx
Fri Sep 06, 2013 6:52 am
Re: copy trigger actions to action group
Hi Karl,
I'm afraid not. If there are a ton of them and you feel comfortable hand-editing XML, then you can make a backup copy of the Indigo database file and try to edit the original. The basic technique would be to create empty Action Groups in Indigo (to create placeholders in the XML with ID numbers), stop the Indigo Server, then copy/paste the contents of the ActionSteps node:
<ActionSteps type="vector">
</ActionSteps>
of the Trigger into the placeholder action group objects (replacing its empty ActionSteps node). Lastly you would start up Indigo, check the Action Groups, then delete the actions from the Triggers and replace them with an Execute Action Group type actions.
