Interested in how others are using iTunes.
1a) Do you have iTunes always open and paused? [I'm concerned that being in constant pause might hang iTunes]
1b) Do you use a script to launch iTunes/play, then stop/quit iTunes?
The iTunes plugin doesn't seem to be able to select/control a particular playlist. It just plays from the entire MUSIC library. So I need a way to get to playlists.
2) Applescript: set shuffle prefs and playlist. I use this now and it works fine if my action requires just 1 exact playlist every time.
What I'm looking for now is 1 CP element button that cycles thru my playlists. I'll know when I've selected the right one because the plugin shows Current Playlist Name. I don't want a button for each playlist name.
Is this do-able?
