Trigger and Script question
Tue Aug 27, 2013 3:00 pm
Ian offline
I have a WMR200 weather station running with Indigo and populating the Weathersnoop Plugin info with all the correct values.
I put a temperature Sensor (#07) in the Fridge and setup a trigger to email me should the value be higher than the amount I specified....in my case 5C. This covers me for either fridge failure or leaving the door open/ajar.
I set this up as a trigger. So under the actions menu I have Type "Send Email (notification actions)" ......my email address obviously. Subject "Fridge Alert"
What I want to do is insert the Plugin value of that sensor into a sentence in the body of the email....ie The temperature of the fridge is "Insert Value" and the alert setpoint is 5C.
Any ideas of the best way to accomplish this...I am guessing if it was a variable....It would be a piece of cake but is it easier to setup a script to accomplish this instead.
thks in advance for everbodys opinions.
Cheers......Ian
Tue Aug 27, 2013 3:52 pm
Re: Trigger and Script question
check this wiki out:
http://www.perceptiveautomation.com/wik ... stom_email
1. create variable "fridgeTemp"
2. trigger: if device state has changed (from temp sensor#7), may be in condition you want to check if temp > xx
3. trigger action: insert device state (temp # 7) into variable .. fridgeTemp
4. see wiki how to create email and include variable in applescript
Tue Aug 27, 2013 3:59 pm
nsheldon offline
Currently, the only way to send an email with variable content is to do so using a script. I'm not aware of a way to send emails using Python (there may be one now). I use AppleScript to send all my emails with variable content. This does require that the device state values you wish to send be inserted into Indigo variables.
The link Karl shared provides a more detailed example. For your situation, follow Karl's steps 1 through 3. For step 4, in a separate action, delayed by at least 1 second to prevent previous variable values from being accidentally sent, use an embedded AppleScript to send yourself an email with the content you wish. Example code:
set myTemp to value of variable "fridgeTemp"
send email to "your-email@address.com" with subject "Fridge Alert" with body "The fridge temperature is " & myTemp & "."
Tue Aug 27, 2013 8:09 pm
Tue Aug 27, 2013 8:55 pm
in the email sending action you have to add (I believe)
set ...
send ...
end tell
Wed Aug 28, 2013 12:56 am
nsheldon offline
jay (support) wrote:
Oh cool. Thanks Jay!
set ...
send ...
end tell
While you can do that (it certainly won't hurt), it's not necessary from within an embedded AppleScript. That's only required when using AppleScript with an external script.
Wed Aug 28, 2013 6:42 am
thanks, did not know that..
Wed Aug 28, 2013 8:19 am
Actually, we've had multiple reports in the past of an AppleScript scoping bug where an embedded script somehow didn't end up targeting the server like it's supposed to. Wrapping it in the tell block always seemed to fix the issue so it's recommended practice.
Wed Aug 28, 2013 9:09 am
Ian offline
Thanks Guys
Seems to be working well with the embedded script.
