- Posted on
Fri Aug 23, 2013 2:52 pm
jingai
offline
In attempt to work around this for now, I figured I could send an Off command to the Device Group. But it appears the Action Group UI won't let me send commands to these Virtual Devices -- there is nothing in the pull-down menu. It only lets me Update Status.
In the Device UI, I can manually set it to Off, and it does what I'm trying to do; that is, on the next motion, the Device Group is set to On and my triggers fire.
Is this a bug in the Action Group UI? If not, can I do this via AppleScript or something, even if it's a Bad Idea? I just want to work around this without adding a bunch of new action groups until you get this feature implemented.
