Glad the info was helpful.
rainman50 wrote:I have 30 or so Insteon motion sensors and about 150 other Insteon devices. The reason I don't set the motion sensors to a short delay (30 seconds) is due to high traffic. This can cause missed events and too much delay to turn on a light if controlled by Indigo.
Yes, with that many motion sensors and other devices, a 30 second timeout would cause quite a bit of traffic and I imagine cause any number of issues. With only 13 motion sensors and a total of 53 INSTEON products in my setup, it seems the INSTEON network is nearing its limits in terms of speed, especially if there are more than 2 people moving around in the house. It doesn't help that the motion sensors are "chatty" and send out more INSTEON traffic per message than most INSTEON devices (probably to ensure that each responder receives the message, but it's still congestive to the network).
Though I haven't done so myself yet (and I have no experience with Z-Wave), you might try switching over to Z-Wave motion sensors. It would be a costly migration, but you could do it one sensor at a time and it'd give you a good idea of how the Z-Wave motion sensors compare to the INSTEON ones. I suspect they're more reliable, and if I remember correctly, they do use regular "check-in" intervals to allow for attached devices (like your computer Z-Wave interface) to send configuration updates.
