Jun 21, 2013 6:55:16 PM
Reloading plugin "SQL Logger 1.1.6"
Stopping plugin "SQL Logger 1.1.6" (pid 64659)
SQL Logger closing SQL connection
Stopped plugin "SQL Logger 1.1.6"
Starting plugin "SQL Logger 1.1.6" (pid 64676)
Started plugin "SQL Logger 1.1.6"
SQL Logger connected to /Library/Application Support/Perceptive Automation/Indigo 6/Logs/indigo_history.sqlite
SQL Logger searching for unused device and variable tables
SQL Logger Error Error in plugin execution startup:
File "plugin.py", line 553, in startup
File "plugin.py", line 486, in _connectToSqlDb
File "plugin.py", line 763, in removeUnusedTablesAction
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/SQL Logger.indigoPlugin/Contents/Server Plugin/indigologger/indigosql.py", line 110, in GetAllTableNames
<class 'sqlite3.DatabaseError'>: database disk image is malformed
hamw wrote:I do have a UPS. Unfortunately here in Atlanta the power outages last longer than a few hours, so I suppose I should just shut down the computer manually in the case of a power outage. If I don't get there in time, is it reasonable to replace the file with one from the backup drive?
hamw wrote:Would be great if that data were easily exported for graphing.
