Generic IOM Access Pattern
Wed Nov 07, 2018 9:04 pm
mundmc offline
Use Case: flexible- run indigo IOM commands from iPhone
Requirements: Shortcuts, SSH server enabled
Sun Nov 11, 2018 1:50 pm
anyone offline
Re: Generic IOM Access Pattern
Is it possible to pass an argument to a script in a similar manner?
i.e. something like:
"/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost" -x ' /SomeFolder/indigo_script.py "dictated text"
Sun Nov 11, 2018 3:55 pm
Yeah, you almost had it:
'/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost' -x /SomeFolder/indigo_script.py "dictated text"
Mon Nov 12, 2018 9:39 am
anyone offline
Thanks Jay, it felt like I was close.
I'm still stuck though. How would I access the argument within the python program? Below is the error I received when attempting to retrieve it with the "sys.argv" command. Should I import something other than sys to do that?
Nov 12, 2018 9:59:51 AM
   Script Error                    indigo-example.py: 'module' object has no attribute 'argv'
   Script Error                    Exception Traceback (most recent call shown last):
     indigo-example.py, line 14, at top level
     indigo-example.py, line 8, in main
AttributeError: 'module' object has no attribute 'argv'
Mon Nov 12, 2018 11:01 am
Post the actual code you're using. Guessing doesn't help anyone.
Mon Nov 12, 2018 1:51 pm
anyone offline
The problem seems deeper than my code. I'm just trying to prove I can pass something.
#!/usr/bin/env python
import sys
def main():
    words = " ".join(sys.argv)
    indigo.server.log(words)
if __name__ == "__main__":
    main()
Mon Nov 12, 2018 6:28 pm
Yeah, that's not gonna work. When specified that way, the args after the script name are just dropped by the IPH process (sorry, I had forgotten this).
We've got a built-in solution coming with 7.3. Basically, you write a wrapper script around an IPH call that accepts the parameters then creates a Indigo Python script that IPH executes and it passes the parameters to a specified method in a shared Indigo Python script. It's a little complicated to get right, but our built-in solution will be pretty easy.
You build a shared Indigo Python script like the one specified in the Scripting Tutorial.
When Indigo 7.3 ships, you execute this:
/usr/local/indigo/indigohost -m indigo_attachments. log "Here is the message"
Which will call the log method in the indigo_attachments.py file example in the above link via a script that we construct. The shell script is this:
from {path} import {method}
return {method}({args})
I insert the module in for path (indigo_attachments) and the method name for method (log) and the args as a string of the args. I then pass that script to the IPH process to run.
