Version Supporting Sonoma. aiohttp install needed
Wed Dec 06, 2023 10:46 pm
GlennNZ offline
Hi all,
Bit belated post … but there is new version which a week or so pushed to store, as Sonoma had breaking changes.
(thanks for those posting the fix on the few messages here)
If you believe it apple archived the sql database so you could not read the message sent! And not security based, just in a proprietary apple format and then zipped. So had to work around this - which doesn’t seem had been completely done before. One of those - surely someone else has solved this?? But alas not completely.
That aside all is working well with Sonoma and below.
However I may have introduced a dependency on aiohttp which I hadn’t recognised.
It is likely you may need to manually, from a terminal run the below command to install aiohttp.
pip3 install aiohttp
This is largely unused unless using the chatGPT features which I would strongly encourage a look/play.
ChatGPT particularly 4 via iMessage from phone or Macbook is actually really useful, and bypasses most restrictions placed on it by various networks…..
