iMessage not working
Wed Nov 25, 2020 11:33 am
MartynD offline
Hi
About 2 weeks ago iMessage stopped working, and I do not know why. The triggers work manually, but there is nothing in the event log to say that any iMessage has been received like I used to have. I have updated to the latest version. Any ideas please.
Martyn
Wed Nov 25, 2020 2:11 pm
GlennNZ online
Re: iMessage not working
Hi
Probably need a bit more info. Turn on all debug options and restart plugin - may give some info.
Otherwise:
- OS version , didn’t upgrade to Big Sur 2 weeks ago?
- are you logged in to messages app on the Mac? Can you send messages from within the messages app? Are they received?
Thu Nov 26, 2020 6:01 am
MartynD offline
Hi
Restarted plugin with debug, this from the event log:
26 Nov 2020 at 11:49:53
Reloading plugin "iMessage Plugin 0.4.7"
Stopping plugin "iMessage Plugin 0.4.7" (pid 14076)
Stopped plugin "iMessage Plugin 0.4.7"
Starting plugin "iMessage Plugin 0.4.7" (pid 25778)
iMessage Plugin
iMessage Plugin ================================================ Initializing New Plugin Session =================================================
iMessage Plugin Plugin name: iMessage Plugin
iMessage Plugin Plugin version: 0.4.7
iMessage Plugin Plugin ID: com.GlennNZ.indigoplugin.iMessage
iMessage Plugin Indigo version: 7.4.1
iMessage Plugin Python version: 2.7.16 (default, Jun 5 2020, 22:59:21) [GCC 4.2.1 Compatible Apple LLVM 11.0.3 (clang-1103.0.29.20) (-macos10.15-objc-
iMessage Plugin Python Directory: /System/Library/Frameworks/Python.framework/Versions/2.7
iMessage Plugin System Release: 19.6.0
iMessage Plugin System Release Short: 19
iMessage Plugin System Version: Darwin Kernel Version 19.6.0: Mon Aug 31 22:12:52 PDT 2020; root:xnu-6153.141.2~1/RELEASE_X86_64
iMessage Plugin ==================================================================================================================================
Started plugin "iMessage Plugin 0.4.7"
Not yet updated to Big Sur, running 10.15.7. Indigo runs on a Mac mini and iMessages are being received and sent O.K.
Martyn
Thu Nov 26, 2020 2:11 pm
GlennNZ online
But will need to let debug run for a bit after this ‘startup’ period. Should try to connect to database, potentially giving some info if it can’t
If you send and receive a message should be some debug info received?
Glenn
Fri Nov 27, 2020 4:27 am
MartynD offline
O.K. checking the debug file gave me some pointers - thanks. It is now working, but I do not understand why. All I have done is take my mobile number off the iMessages account list in preferences for iMessage and left the email addresses I use, and, so far, it's working. Magic or witchcraft - take your pick.
Many thanks for your help.
Martyn
Fri Nov 27, 2020 4:36 am
GlennNZ online
No problem.
Happy to take the win either way!
Sat Nov 28, 2020 8:38 am
MartynD offline
Teamwork........
Martyn
