device "Tesla Site Info" state key deviceStatus not defined
Sat Jun 15, 2019 10:39 am
ZachBenz offline
Have started getting these in the log on a regular interval:
Tesla Battery Error             Caught Exception in fillsiteinfo
  File "plugin.py", line 554, in fillsiteinfo
    {'key': 'gridCode', 'value': data['grid_code']},
KeyError: 'grid_code'
   Error                           device "Tesla Site Info" state key deviceStatus not defined (ignoring update request)
ZachBenz's Plugins: RingForIndigo
Sat Jun 15, 2019 2:21 pm
GlennNZ online
Re: device "Tesla Site Info" state key deviceStatus not defi
Ok
Probably need the whole debug output, as not seeing this issue.
Looks like something has changed, or has been updated - interestingly working fine here with Grid_code being filled.
I'm on software version 1.37.1 - which seems to be latest...
Glenn
Sat Jun 15, 2019 8:09 pm
ZachBenz offline
Here's a 7 minute debug log capture. The error pops up every 10 minutes, regularly. Was a bit strange to me that there was so much polling going on during the 7 minute capture. My powerwall gateway is on version 1.37.1 as well.
Jun 15, 2019 at 7:59:49 PM
   Tesla Battery                   Debugging on.
   Tesla Battery Debug             Debug level: 20
   Tesla Battery Debug             New logLevel = 10
   Tesla Battery Debug             HTTPS CURL result:
   Tesla Battery Debug             ReturnCode:0
   Tesla Battery Debug             fill grid status info called
   Tesla Battery Debug             fillmetersinfo called
   Tesla Battery Debug             fill battery info called
   Tesla Battery Debug             Battery Per:98.1712720535
   Tesla Battery Debug             fill grid faults info called
   Tesla Battery Debug             Battery Per:98.1670225194
   Tesla Battery Debug             Battery Per:98.1714193652
   Tesla Battery Debug             Battery Per:98.1752265861
   Tesla Battery Debug             fillsiteinfo called
   Tesla Battery Debug             Battery Per:98.1553085226
   Tesla Battery Debug             closedPrefsConfigUi() method called.
   Tesla Battery Debug             User prefs saved.
   Tesla Battery Debug             logLevel = 10
   Tesla Battery Debug             Debugging on (Level: 10)
   Tesla Battery Debug             toggleDebugEnabled() method called.
   Tesla Battery                   Debugging off.  Debug level: 10
Sat Jun 15, 2019 8:14 pm
GlennNZ online
device
[code]
OK - think you are missed debug checkboxes being enabled?
Can you run debug with everything on (all three debug checkboxes from plugin Config) from beginning/reload plugin, until error and post or PM?
Should be a quick fix I would think
Sat Jun 15, 2019 9:40 pm
GlennNZ online
Ok - had limited time to check.
Have released Version 0.3.9
In Plugin Store.
Checks for missing site_info data and only updates that which received.
Would still like the debug logging though if possible! - so can check what else is going on/or different in your install.
Sun Jun 16, 2019 8:56 am
ZachBenz offline
Ah, yep will do. Had only hit the "Toggle Debugging" in the plugin menu, not the three checkboxes. I'll do that now.
