Tesla Battery Gateway Plugin
Mon Oct 19, 2020 6:05 pm
GlennNZ online
Re: Tesla Battery Gateway Plugin
Try 0.5.7
Pretty sure fixes issue reported.
Thu Oct 29, 2020 2:29 pm
jonc offline
Glenn,
The latest version fixed my issue. I have been integrating and testing for the last week and it all works perfectly. Thanks for the rapid response and fantastic support.
Jon
Sun Nov 01, 2020 11:50 pm
GlennNZ online
New Release 0.6.4
Given changes in Battery software 1.50.1 removing local control
Moves to using Tesla online API to change battery mode, and now optional battery reserve percentage.
Update code to achieve this, update pluginConfig data, remove unneeded data
Also enables addition of online states in Battery
Online Battery States:
    battery mode
    Current set battery backup reserve percentage
    software version of battery
    battery count
This remains optional, if not controlling battery fields can be left blank, new states will also remain blank.
Usage:
Enables rapid changing mode of battery to suit electricity prices, multiple times
Works instantaneously, no downtime and no risk of battery going offline.
In Plugin Store.
Fri Jan 01, 2021 12:15 pm
ChiefMonk offline
Early days for me with this and all generally great.
I am getting this when trying to change the mode though. Is this a set up error on my part or is there some other issue?
Regards
Chris
Tesla Battery Error Error change Operatonal Mode : ValueError('could not convert string to float: ',)
File "plugin.py", line 872, in setOperationalModeOnline
if self.changeOperationOnline(mode, reserve, setreserve): ## success do the rest
File "plugin.py", line 674, in changeOperationOnline
percentage = float("%.1f" % float(reservepercentage))
ValueError: could not convert string to float:
WebServer request to execute "_preview_01 - Temperature copy" control #14 from 192.168.10.25
WebServer could not find control page "_preview_01 - Temperature copy"
1 Jan 2021 at 18:08:09
Fri Jan 01, 2021 4:29 pm
GlennNZ online
Hi
Thanks - have had a look and it is a small bug, presumably you were not wanting to change battery reserve?
I’ll post an update (involves moving a line of code down 5 lines!)
But for moment could in current action - select alter battery reserve percentage, enter your usual value, save, then reopen action and unselect alter battery reserve. That should sort it out.
Basically I added the option not to alter reserve percentage late and the code expects a valid value battery reserve to be present before will do anything.
Glenn
Sat Jan 02, 2021 3:01 pm
ChiefMonk offline
Awesome - thx
Chris
Mon Jan 04, 2021 5:14 am
ChiefMonk offline
Hi Glenn, just to confirm what you already know .... that it works fine if you do the state and level change at the same time.
GlennNZ wrote:
Hi
Glenn
Mon Jan 04, 2021 5:15 am
GlennNZ online
Thanks. Good to hear all is good.
Sorry had meant to fix/update - will do so in next 24hours or so...
