Try 0.5.7
Pretty sure fixes issue reported.
Tesla Battery Error Error change Operatonal Mode : ValueError('could not convert string to float: ',)
File "plugin.py", line 872, in setOperationalModeOnline
if self.changeOperationOnline(mode, reserve, setreserve): ## success do the rest
File "plugin.py", line 674, in changeOperationOnline
percentage = float("%.1f" % float(reservepercentage))
ValueError: could not convert string to float:
WebServer request to execute "_preview_01 - Temperature copy" control #14 from 192.168.10.25
WebServer could not find control page "_preview_01 - Temperature copy"
1 Jan 2021 at 18:08:09
GlennNZ wrote:Hi
Thanks - have had a look and it is a small bug, presumably you were not wanting to change battery reserve?
I’ll post an update (involves moving a line of code down 5 lines!)
But for moment could in current action - select alter battery reserve percentage, enter your usual value, save, then reopen action and unselect alter battery reserve. That should sort it out.
Basically I added the option not to alter reserve percentage late and the code expects a valid value battery reserve to be present before will do anything.
Glenn
