Tesla Battery Gateway Plugin
Mon Oct 19, 2020 6:05 pm
GlennNZ offline
Re: Tesla Battery Gateway Plugin
Try 0.5.7
Pretty sure fixes issue reported.
Thu Oct 29, 2020 2:29 pm
jonc offline
Glenn,
The latest version fixed my issue. I have been integrating and testing for the last week and it all works perfectly. Thanks for the rapid response and fantastic support.
Jon
Sun Nov 01, 2020 11:50 pm
GlennNZ offline
New Release 0.6.4
Given changes in Battery software 1.50.1 removing local control
Moves to using Tesla online API to change battery mode, and now optional battery reserve percentage.
Update code to achieve this, update pluginConfig data, remove unneeded data
Also enables addition of online states in Battery
Online Battery States:
    battery mode
    Current set battery backup reserve percentage
    software version of battery
    battery count
This remains optional, if not controlling battery fields can be left blank, new states will also remain blank.
Usage:
Enables rapid changing mode of battery to suit electricity prices, multiple times
Works instantaneously, no downtime and no risk of battery going offline.
In Plugin Store.
Fri Jan 01, 2021 12:15 pm
ChiefMonk offline
Early days for me with this and all generally great.
I am getting this when trying to change the mode though. Is this a set up error on my part or is there some other issue?
Regards
Chris
Tesla Battery Error Error change Operatonal Mode : ValueError('could not convert string to float: ',)
File "plugin.py", line 872, in setOperationalModeOnline
if self.changeOperationOnline(mode, reserve, setreserve): ## success do the rest
File "plugin.py", line 674, in changeOperationOnline
percentage = float("%.1f" % float(reservepercentage))
ValueError: could not convert string to float:
WebServer request to execute "_preview_01 - Temperature copy" control #14 from 192.168.10.25
WebServer could not find control page "_preview_01 - Temperature copy"
1 Jan 2021 at 18:08:09
Fri Jan 01, 2021 4:29 pm
GlennNZ offline
Hi
Thanks - have had a look and it is a small bug, presumably you were not wanting to change battery reserve?
I’ll post an update (involves moving a line of code down 5 lines!)
But for moment could in current action - select alter battery reserve percentage, enter your usual value, save, then reopen action and unselect alter battery reserve. That should sort it out.
Basically I added the option not to alter reserve percentage late and the code expects a valid value battery reserve to be present before will do anything.
Glenn
Sat Jan 02, 2021 3:01 pm
ChiefMonk offline
Awesome - thx
Chris
Mon Jan 04, 2021 5:14 am
ChiefMonk offline
Hi Glenn, just to confirm what you already know .... that it works fine if you do the state and level change at the same time.
GlennNZ wrote:
Hi
Glenn
Mon Jan 04, 2021 5:15 am
GlennNZ offline
Thanks. Good to hear all is good.
Sorry had meant to fix/update - will do so in next 24hours or so...
Thu Feb 18, 2021 1:53 pm
jonc offline
Hi Glenn,
My Powerwall updated to 20.49.0 and it broke the plugin - not getting battery SOC or current measurements. Debugging showed:
Tesla Battery Error Caught Exception in Fillbattery Info
File "plugin.py", line 1297, in fillbatteryinfo
percentage= float(data['percentage'])
KeyError: 'percentage'
Tesla Battery Error Caught Exception in FillGridStatus Info
File "plugin.py", line 1327, in fillgridstatusinfo
device.updateStateOnServer('gridStatus', value=data['grid_status'])
KeyError: 'grid_status'
Any help appreciated.
Jon
Thu Feb 18, 2021 2:19 pm
GlennNZ offline
Bugger, updates....
My is obviously behind - but probably not for long.
Could you send me debug log output (that should contain the breaking changes) and I’ll have a look late today?
Edit:
On further looking no need to send debug. It won’t be connecting; authenicating period. 20.49 is a bit oauth change that buggers everything up. So bad some have downgraded following DW Tesla. Seems still may to get local data thought - but my eta may be out for a fix!
Fri Feb 19, 2021 12:49 am
GlennNZ offline
Ok - Have managed to get this working on my testing
Update for Battery Software 20.49.0 and above...
Try:
0.6.8
https://github.com/Ghawken/TeslaBatteryPlugin
Changes to Oauth3 token for local access (done in 0.6.6). That aspect seems fairly robust and working well.
Have it rechecking expired token once an hour.
0.6.8
Updates online to Oauth3 as well (which discovered wasn't working - although less loud in errors)
Again working on my limited testing, get online site_info and change mode/battery reserve working on my testing..
Give it a try...
Glenn
Sun Feb 21, 2021 1:17 pm
roquej offline
Glenn,
Have the latest version installed. No errors. Solar production and Grid power are reported correctly. However, the % battery is incorrect. In fact, it's never updated.
Any suggestions?
JP
Sun Feb 21, 2021 2:16 pm
GlennNZ offline
roquej wrote:
Glenn,
Any suggestions?
JP
Hi
Glad no errors.
There have been a lot of Tesla server changes; fixed one and then literally was another.(took a while to discover was another...).
Everything Tesla library has stopped working in the last 12 hours .... for some unknown reason all requests to Tesla need to have No headers; otherwise infinite hang. .. presumably this will change again. But for the moment all good.
Your issue - seems strange,
No obvious code cause that I can see - if it gets other aspects no reason battery/soe data shouldn’t return.
On version 0.7.2?
Battery version? Possible if still on earlier version may see unpredictable issues.
Plugin Checks battery/system_soe every minute so a debug log for 5 minutes or so probably will help.
Glenn
Sun Feb 21, 2021 4:53 pm
roquej offline
I was on 0.6.8, which I thought was the latest version. Just upgraded to 0.7.2 and it seems to be working. I will monitor and let you know.
Thank you for the quick response!
JP
Sun Feb 21, 2021 5:09 pm
GlennNZ offline
JP
Thanks.
Seems Tesla working on their servers.. almost a running commentary of working again.
Presume once Tesla updated/fixed - will need to add headers again to calls... expect some disruption ... but I’ll update code and here.
https://github.com/timdorr/tesla-api/is ... -782824762
Glenn
Page 7 of 9 1 ... 4, 5, 6, 7, 8, 9
