Pre-release 2.4.0
Sun Jun 27, 2021 1:24 pm
Pre-release 2.4.0
https://github.com/FlyingDiver/Indigo-E ... /tag/2.4.0
This release finally fixes (I hope) the issues with Celsius and other temperature scales. If you're a non-Fahrenheit user, please test this version.
Mon Jul 05, 2021 12:22 pm
nicb offline
Re: Pre-release 2.4.0
Celsius user here in the US - 2.4.1 and then a downgrade to 2.4.0 both give the following
   Ecobee 2 Error                  Error in plugin execution runConcurrentThread:
  File "plugin.py", line 210, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/Ecobee 2.indigoPlugin/Contents/Server Plugin/ecobee_devices.py", line 369, in update
  File "/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/Ecobee 2.indigoPlugin/Contents/Server Plugin/temperature_scale.py", line 32, in convertFromEcobee
ValueError: could not convert string to float: unknown
Downgrading back to 2.3.5 eliminates the error.
Mon Jul 05, 2021 12:36 pm
Use the menu command to write the data to the log, then open a GitHub issue with that and the error message. I’ll look at it end of the week when I get home.
Mon Jul 05, 2021 12:52 pm
nicb offline
Done. Thanks, enjoy the holiday week
