Carrier Infinity and Ecobee?
Mon Apr 19, 2021 8:39 am
Different Computers offline
I ran across a mention today of homebridge-infinitude https://cnpmjs.org/package/homebridge-infinitude and followed down that rabbit hole until I discovered that Carrier now offers Ecobee thermostats that are compatible with Carrier Infinity. Strange they don't direct market to targets like me!
This raises a bunch of questions:
Anyone here using this combo? Do you like it?
Is the Ecobee compatible with **all** Carrier Infinity systems, or just newer ones? My heat pump system was installed in about 2005.
I'm probably going to investigate with my local HVAC company, but thought it worth asking here.
Mon Apr 19, 2021 8:43 am
Re: Carrier Infinity and Ecobee?
Interesting. The plugin currently supports a model type of "corSmart" which is supposed to be for "'Carrier or Bryant". I got that from the API docs. I have no idea what it actually represents in terms of Carrier hardware.
Sat May 22, 2021 9:56 pm
sbe08 offline
I don't currently have much time on hands for writing a plug-in for Carrier Infinity, but this could jumpstart the effort for anyone looking to create a plug-in for it. This is the RS-232 protocol but it shouldn't be too far off the IP protocol.
    <control_interfaces preferred="rs232">
       <rs232 data_length="8" parity_bit="no" stop_bit="1" preferred_baud_rate="9600" response_time_length_ms="5000" flow_control="none" name_on_component="RS-232" connector_type="db9 female" cable_type="rs232 straight">
            <baud_rate speed="9600"/>
            <send_postfix type="hex">0D0A</send_postfix>
            <receive_end_condition test_condition="data" type="hex">0D0A</receive_end_condition>
        </rs232>
    </control_interfaces>
    <media_interfaces>
        <internal name_on_component="HVAC Controller">
            <environmental_media></environmental_media>
            <resource resource_type="ENV_HVACCONTROLLER_SOURCE"/>
        </internal>
    </media_interfaces>
    <state_variable_list>
        <!-- Temp Cool, Heat Point state variables -->
        <state_variable name="WorkingCoolPoint" owning_logical_component="HVAC_controller" state_center_binding="CurrentWorkingCoolPoint" state_center_type="integer" min_value="0" max_value="99">76</state_variable>
        <state_variable name="WorkingHeatPoint" owning_logical_component="HVAC_controller" state_center_binding="CurrentWorkingHeatPoint" state_center_type="integer" min_value="0" max_value="99">70</state_variable>
    </state_variable_list>
    <logical_component logical_component_name="HVAC_controller">
        <implementation>
            <internal name_on_component="HVAC Controller"/>
        </implementation>
        <status_messages>
            <status_message name="ThermostatCurrentTemperature">
                <constant type="character">S</constant>
                <data type="character" constant_length="1">
                    <update state="ThermostatAddress" type="string"></update>
                </data>
                <constant type="character">Z</constant>
                    <update state="ThermostatAddress2" type="string"></update>
                </data>
                <constant type="character">RT:</constant>
                <data type="character" terminator_type="hex" terminator="B0">
                    <update state="ThermostatCurrentTemperature" type="string"></update>
                </data>
                <data type="character" terminator_type="end_of_data">
                    <update state="ThermostatCurrentTemperatureFormat" type="string"></update>
                </data>
                <append_data_to_state_names state="ThermostatAddress" note="'1' - '2'"/>
                <append_data_to_state_names state="ThermostatAddress2" note="'1' - '8'"/>
            </status_message>
            <status_message name="ThermostatCurrentHumidity">
                </data>
                </data>
                <constant type="character">RH:</constant>
                    <update state="ThermostatCurrentHumidity" type="string"></update>
                </data>
            </status_message>
            <status_message name="SystemCurrentOutdoorTemperature">
                <constant type="character">S1OAT:</constant>
                    <update state="ThermostatCurrentRemoteTemperature_1_1" type="string"></update>
                    <update state="ThermostatCurrentRemoteTemperature_1_2" type="string"></update>
                    <update state="ThermostatCurrentRemoteTemperature_1_3" type="string"></update>
                    <update state="ThermostatCurrentRemoteTemperature_1_4" type="string"></update>
                </data>
                    <update state="ThermostatCurrentRemoteTemperatureFormat_1" type="string"></update>
                </data>
            </status_message>
            <status_message name="SystemCurrentOutdoorTemperature2">
                <constant type="character">S2OAT:</constant>
                    <update state="ThermostatCurrentRemoteTemperature_2_1" type="string"></update>
                    <update state="ThermostatCurrentRemoteTemperature_2_2" type="string"></update>
                    <update state="ThermostatCurrentRemoteTemperature_2_3" type="string"></update>
                    <update state="ThermostatCurrentRemoteTemperature_2_4" type="string"></update>
                </data>
                    <update state="ThermostatCurrentRemoteTemperatureFormat_2" type="string"></update>
                </data>
            </status_message>
            <status_message name="SystemCurrentOutdoorTemperature3"> <!-- Won't match, prototype status var names -->
                <data type="character" constant_length="400">
                    <update state="ThermostatCurrentRemoteTemperature" type="string"></update>
                </data>
            </status_message>
            <status_message name="ThermostatCurrentFanMode">
                </data>
                </data>
                <constant type="character">FAN:</constant>
                    <data_map match_required="yes">
                        <map key="AUTO">
                            <update state="ThermostatCurrentFanMode" type="string">AUTO</update>
                            <update state="IsThermostatCurrentFanModeAuto" type="boolean">true</update>
                            <update state="IsThermostatCurrentFanModeOn" type="boolean">false</update>
                        </map>
                        <map key="LOW">
                            <update state="ThermostatCurrentFanMode" type="string">ON</update>
                            <update state="IsThermostatCurrentFanModeAuto" type="boolean">false</update>
                            <update state="IsThermostatCurrentFanModeOn" type="boolean">true</update>
                        </map>
                        <map key="MED">
                        </map>
                        <map key="HIGH">
                        </map>
                    </data_map>
                </data>
            </status_message>
            <status_message name="SystemCurrentHVACMode">
                <constant type="character">S1MODE:</constant>
                        <map key="HEAT">
                            <update state="ThermostatMode_1_1" type="string">HEAT</update>
                            <update state="ThermostatMode_1_2" type="string">HEAT</update>
                            <update state="ThermostatMode_1_3" type="string">HEAT</update>
                            <update state="ThermostatMode_1_4" type="string">HEAT</update>
                            <update state="IsCurrentHVACModeHeat_1_1" type="boolean">true</update>
                            <update state="IsCurrentHVACModeHeat_1_2" type="boolean">true</update>
                            <update state="IsCurrentHVACModeHeat_1_3" type="boolean">true</update>
                            <update state="IsCurrentHVACModeHeat_1_4" type="boolean">true</update>
                            <update state="IsCurrentHVACModeCool_1_1" type="boolean">false</update>
                            <update state="IsCurrentHVACModeCool_1_2" type="boolean">false</update>
                            <update state="IsCurrentHVACModeCool_1_3" type="boolean">false</update>
                            <update state="IsCurrentHVACModeCool_1_4" type="boolean">false</update>
                            <update state="IsCurrentHVACModeAuto_1_1" type="boolean">false</update>
                            <update state="IsCurrentHVACModeAuto_1_2" type="boolean">false</update>
                            <update state="IsCurrentHVACModeAuto_1_3" type="boolean">false</update>
                            <update state="IsCurrentHVACModeAuto_1_4" type="boolean">false</update>
                            <update state="IsCurrentHVACModeOff_1_1" type="boolean">false</update>
                            <update state="IsCurrentHVACModeOff_1_2" type="boolean">false</update>
                            <update state="IsCurrentHVACModeOff_1_3" type="boolean">false</update>
                            <update state="IsCurrentHVACModeOff_1_4" type="boolean">false</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_1_1" type="boolean">false</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_1_2" type="boolean">false</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_1_3" type="boolean">false</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_1_4" type="boolean">false</update>
                        </map>
                        <map key="HEAT 1">
                        </map>
                        <map key="HEAT 2">
                        </map>
                        <map key="HEAT 3">
                        </map>
                        <map key="COOL">
                            <update state="CurrentHVACMode_1_1" type="string">COOL</update>
                            <update state="CurrentHVACMode_1_2" type="string">COOL</update>
                            <update state="CurrentHVACMode_1_3" type="string">COOL</update>
                            <update state="CurrentHVACMode_1_4" type="string">COOL</update>
                            <update state="IsCurrentHVACModeHeat_1_1" type="boolean">false</update>
                            <update state="IsCurrentHVACModeHeat_1_2" type="boolean">false</update>
                            <update state="IsCurrentHVACModeHeat_1_3" type="boolean">false</update>
                            <update state="IsCurrentHVACModeHeat_1_4" type="boolean">false</update>
                            <update state="IsCurrentHVACModeCool_1_1" type="boolean">true</update>
                            <update state="IsCurrentHVACModeCool_1_2" type="boolean">true</update>
                            <update state="IsCurrentHVACModeCool_1_3" type="boolean">true</update>
                            <update state="IsCurrentHVACModeCool_1_4" type="boolean">true</update>
                        </map>
                        <map key="COOL 1">
                        </map>
                        <map key="COOL 2">
                        </map>
                        <map key="COOL 3">
                        </map>
                        <map key="AUTO">
                            <update state="CurrentHVACMode_1_1" type="string">AUTO</update>
                            <update state="CurrentHVACMode_1_2" type="string">AUTO</update>
                            <update state="CurrentHVACMode_1_3" type="string">AUTO</update>
                            <update state="CurrentHVACMode_1_4" type="string">AUTO</update>
                            <update state="IsCurrentHVACModeAuto_1_1" type="boolean">true</update>
                            <update state="IsCurrentHVACModeAuto_1_2" type="boolean">true</update>
                            <update state="IsCurrentHVACModeAuto_1_3" type="boolean">true</update>
                            <update state="IsCurrentHVACModeAuto_1_4" type="boolean">true</update>
                        </map>
                        <map key="AUTO 1">
                        </map>
                        <map key="AUTO 2">
                        </map>
                        <map key="AUTO 3">
                        </map>
                        <map key="OFF">
                            <update state="CurrentHVACMode_1_1" type="string">OFF</update>
                            <update state="CurrentHVACMode_1_2" type="string">OFF</update>
                            <update state="CurrentHVACMode_1_3" type="string">OFF</update>
                            <update state="CurrentHVACMode_1_4" type="string">OFF</update>
                            <update state="IsCurrentHVACModeOff_1_1" type="boolean">true</update>
                            <update state="IsCurrentHVACModeOff_1_2" type="boolean">true</update>
                            <update state="IsCurrentHVACModeOff_1_3" type="boolean">true</update>
                            <update state="IsCurrentHVACModeOff_1_4" type="boolean">true</update>
                        </map>
                        <map key="EHEAT">
                            <update state="CurrentHVACMode_1_1" type="string">EMERGENCY HEAT</update>
                            <update state="CurrentHVACMode_1_2" type="string">EMERGENCY HEAT</update>
                            <update state="CurrentHVACMode_1_3" type="string">EMERGENCY HEAT</update>
                            <update state="CurrentHVACMode_1_4" type="string">EMERGENCY HEAT</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_1_1" type="boolean">true</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_1_2" type="boolean">true</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_1_3" type="boolean">true</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_1_4" type="boolean">true</update>
                        </map>
                    </data_map>
                </data>
            </status_message>
            <status_message name="SystemCurrentHVACMode2">
                <constant type="character">S2MODE:</constant>
                        <map key="HEAT">
                            <update state="ThermostatMode_2_1" type="string">HEAT</update>
                            <update state="ThermostatMode_2_2" type="string">HEAT</update>
                            <update state="ThermostatMode_2_3" type="string">HEAT</update>
                            <update state="ThermostatMode_2_4" type="string">HEAT</update>
                            <update state="IsCurrentHVACModeHeat_2_1" type="boolean">true</update>
                            <update state="IsCurrentHVACModeHeat_2_2" type="boolean">true</update>
                            <update state="IsCurrentHVACModeHeat_2_3" type="boolean">true</update>
                            <update state="IsCurrentHVACModeHeat_2_4" type="boolean">true</update>
                            <update state="IsCurrentHVACModeCool_2_1" type="boolean">false</update>
                            <update state="IsCurrentHVACModeCool_2_2" type="boolean">false</update>
                            <update state="IsCurrentHVACModeCool_2_3" type="boolean">false</update>
                            <update state="IsCurrentHVACModeCool_2_4" type="boolean">false</update>
                            <update state="IsCurrentHVACModeAuto_2_1" type="boolean">false</update>
                            <update state="IsCurrentHVACModeAuto_2_2" type="boolean">false</update>
                            <update state="IsCurrentHVACModeAuto_2_3" type="boolean">false</update>
                            <update state="IsCurrentHVACModeAuto_2_4" type="boolean">false</update>
                            <update state="IsCurrentHVACModeOff_2_1" type="boolean">false</update>
                            <update state="IsCurrentHVACModeOff_2_2" type="boolean">false</update>
                            <update state="IsCurrentHVACModeOff_2_3" type="boolean">false</update>
                            <update state="IsCurrentHVACModeOff_2_4" type="boolean">false</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_2_1" type="boolean">false</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_2_2" type="boolean">false</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_2_3" type="boolean">false</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_2_4" type="boolean">false</update>
                        </map>
                        <map key="HEAT 1">
                        </map>
                        <map key="HEAT 2">
                        </map>
                        <map key="HEAT 3">
                        </map>
                        <map key="COOL">
                            <update state="CurrentHVACMode_2_1" type="string">COOL</update>
                            <update state="CurrentHVACMode_2_2" type="string">COOL</update>
                            <update state="CurrentHVACMode_2_3" type="string">COOL</update>
                            <update state="CurrentHVACMode_2_4" type="string">COOL</update>
                            <update state="IsCurrentHVACModeHeat_2_1" type="boolean">false</update>
                            <update state="IsCurrentHVACModeHeat_2_2" type="boolean">false</update>
                            <update state="IsCurrentHVACModeHeat_2_3" type="boolean">false</update>
                            <update state="IsCurrentHVACModeHeat_2_4" type="boolean">false</update>
                            <update state="IsCurrentHVACModeCool_2_1" type="boolean">true</update>
                            <update state="IsCurrentHVACModeCool_2_2" type="boolean">true</update>
                            <update state="IsCurrentHVACModeCool_2_3" type="boolean">true</update>
                            <update state="IsCurrentHVACModeCool_2_4" type="boolean">true</update>
                        </map>
                        <map key="COOL 1">
                        </map>
                        <map key="COOL 2">
                        </map>
                        <map key="COOL 3">
                        </map>
                        <map key="AUTO">
                            <update state="CurrentHVACMode_2_1" type="string">AUTO</update>
                            <update state="CurrentHVACMode_2_2" type="string">AUTO</update>
                            <update state="CurrentHVACMode_2_3" type="string">AUTO</update>
                            <update state="CurrentHVACMode_2_4" type="string">AUTO</update>
                            <update state="IsCurrentHVACModeAuto_2_1" type="boolean">true</update>
                            <update state="IsCurrentHVACModeAuto_2_2" type="boolean">true</update>
                            <update state="IsCurrentHVACModeAuto_2_3" type="boolean">true</update>
                            <update state="IsCurrentHVACModeAuto_2_4" type="boolean">true</update>
                        </map>
                        <map key="AUTO 1">
                        </map>
                        <map key="AUTO 2">
                        </map>
                        <map key="AUTO 3">
                        </map>
                        <map key="OFF">
                            <update state="CurrentHVACMode_2_1" type="string">OFF</update>
                            <update state="CurrentHVACMode_2_2" type="string">OFF</update>
                            <update state="CurrentHVACMode_2_3" type="string">OFF</update>
                            <update state="CurrentHVACMode_2_4" type="string">OFF</update>
                            <update state="IsCurrentHVACModeOff_2_1" type="boolean">true</update>
                            <update state="IsCurrentHVACModeOff_2_2" type="boolean">true</update>
                            <update state="IsCurrentHVACModeOff_2_3" type="boolean">true</update>
                            <update state="IsCurrentHVACModeOff_2_4" type="boolean">true</update>
                        </map>
                        <map key="EHEAT">
                            <update state="CurrentHVACMode_2_1" type="string">EMERGENCY HEAT</update>
                            <update state="CurrentHVACMode_2_2" type="string">EMERGENCY HEAT</update>
                            <update state="CurrentHVACMode_2_3" type="string">EMERGENCY HEAT</update>
                            <update state="CurrentHVACMode_2_4" type="string">EMERGENCY HEAT</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_2_1" type="boolean">true</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_2_2" type="boolean">true</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_2_3" type="boolean">true</update>
                            <update state="IsCurrentHVACModeEmergencyHeat_2_4" type="boolean">true</update>
                        </map>
                    </data_map>
                </data>
            </status_message>
            <status_message name="SystemCurrentHVACMode3"> <!-- Won't match, defines prototype status var names -->
                <data type="character" constant_length="200">
                    <update state="ThermostatAddress" type="string"> </update>
                    <update state="ThermostatAddress2" type="string"> </update>
                    <update state="CurrentHVACMode" type="string"> </update>
                    <update state="IsCurrentHVACModeHeat" type="boolean">false</update>
                    <update state="IsCurrentHVACModeCool" type="boolean">false</update>
                    <update state="IsCurrentHVACModeAuto" type="boolean">false</update>
                    <update state="IsCurrentHVACModeOff" type="boolean">false</update>
                    <update state="IsCurrentHVACModeEmergencyHeat" type="boolean">false</update>
                </data>
            </status_message>
            <status_message name="ThermostatCurrentHeatPoint">
                </data>
                </data>
                <constant type="character">HTSP:</constant>
                    <update state="ThermostatCurrentHeatPoint" type="string"></update>
                </data>
                    <update state="ThermostatCurrentHeatPointTemperatureFormat" type="string"></update>
                </data>
            </status_message>
            <status_message name="ThermostatCurrentCoolPoint">
                </data>
                </data>
                <constant type="character">CLSP:</constant>
                    <update state="ThermostatCurrentCoolPoint" type="string"></update>
                </data>
                    <update state="ThermostatCurrentCoolPointTemperatureFormat" type="string"></update>
                </data>
            </status_message>
            <status_message name="ThermostatCurrentHumidifyPoint">
                </data>
                </data>
                <constant type="character">RHGT:</constant>
                    <update state="ThermostatCurrentHumidifyPoint" type="string"></update>
                </data>
            </status_message>
            <status_message name="ThermostatCurrentZoneName">
                </data>
                </data>
                <constant type="character">NAME:</constant>
                    <update state="ThermostatCurrentZoneName" type="string"></update>
                </data>
            </status_message>
            <status_message name="SystemCurrentTemperatureFormat">
                </data>
                <constant type="character">CFGEM:</constant>
                        <map key="F">
                            <update state="SystemCurrentTemperatureFormat" type="string">F</update>
                        </map>
                        <map key="C">
                            <update state="SystemCurrentTemperatureFormat" type="string">C</update>
                        </map>
                    </data_map>
                </data>
            </status_message>
        </status_messages>
Sat May 22, 2021 9:57 pm
sbe08 offline
        <resource_component_actions resource_type="ENV_HVACCONTROLLER_SOURCE">
            <action name="SetFanModeOn">
                <action_argument name="ThermostatAddress" note="Carrier System Number (1 - 2)"/>
                <action_argument name="ThermostatAddress2" note="Carrier Zone Number (1 - 8)"/>
                <command_interface interface="rs232">
                    <command>
                        <command_string>S</command_string>
                        <parameter_list>
                            <parameter parameter_data_type="character" action_argument="ThermostatAddress" parameter_total_width="1" parameter_data_width="1"></parameter>
                            <parameter parameter_data_type="character" parameter_total_width="1" parameter_data_width="1">Z</parameter>
                            <parameter parameter_data_type="character" action_argument="ThermostatAddress2" parameter_data_width="1" parameter_total_width="1"></parameter>
                            <parameter parameter_data_type="character" parameter_total_width="7" parameter_data_width="7">FAN!MED</parameter> <!-- Default to Medium Fan Speed -->
                        </parameter_list>
                        <delay ms_delay="1500"/>
                    </command>
                    <command response_required="no"> <!-- Query Fan Mode For Zone -->
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="4" parameter_data_width="4">FAN?</parameter>
                        </parameter_list>
                        <delay ms_delay="200"/>
                    </command>
                </command_interface>
            </action>
            <action name="SetFanModeAuto">
                    <command>
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="8" parameter_data_width="8">FAN!AUTO</parameter>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="SetHVACModeAuto">
                <action_argument name="ThermostatAddress2" note="not used"/>
                    <command>
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="9" parameter_data_width="9">MODE!AUTO</parameter>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Query system HVAC mode -->
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="5" parameter_data_width="5">MODE?</parameter>
                        </parameter_list>
                    </command>
            </action>
            <action name="SetHVACModeCool">
                    <command>
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="9" parameter_data_width="9">MODE!COOL</parameter>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="SetHVACModeOff">
                    <command>
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="8" parameter_data_width="8">MODE!OFF</parameter>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="SetHVACModeHeat">
                    <command>
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="9" parameter_data_width="9">MODE!HEAT</parameter>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
      <action name="IncreaseCoolPointTemperature">
                    <command response_required="yes"> <!-- Query current Cool Point -->
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="5" parameter_data_width="5">CLSP?</parameter>
                        </parameter_list>
                        <response_codes>
                            <rspmessage status="success" name="QueryCoolPointSuccess">
                                <constant type="character">S2Z</constant>
                                    <update state="UnusedStatusData" type="string"></update>
                                </data>
                                <data type="character" constant_length="2">
                                    <update state="CurrentWorkingCoolPoint" type="string"></update> <!-- Update Working Cool Point Status variable, state variable via statecenter binding -->
                                </data>
                                </data>
                            </rspmessage>
                            <rspmessage status="success" name="QueryCoolPointSuccess2">
                                <constant type="character">S1Z</constant>
                                </data>
                                </data>
                                </data>
                            </rspmessage>
                        </response_codes>
                    </command>
                    <command> <!-- Set the New Cool Point-->
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="5" parameter_data_width="5">CLSP!</parameter>
                            <parameter parameter_data_type="character" parameter_total_width="2" parameter_data_width="2" state_variable="WorkingCoolPoint++"></parameter>
                        </parameter_list>
                        <delay ms_delay="2000"/>
                    </command>
                    <command response_required="no"> <!-- Query Cool Point -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="DecreaseCoolPointTemperature">
                        <parameter_list>
                        </parameter_list>
                        <response_codes>
                                </data>
                                </data>
                                </data>
                            </rspmessage>
                                </data>
                                </data>
                                </data>
                            </rspmessage>
                        </response_codes>
                    </command>
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="2" parameter_data_width="2" state_variable="WorkingCoolPoint--"></parameter>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="IncreaseHeatPointTemperature">
                    <command response_required="yes"> <!-- Query current Heat Point -->
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="5" parameter_data_width="5">HTSP?</parameter>
                        </parameter_list>
                        <response_codes>
                            <rspmessage status="success" name="QueryHeatPointSuccess">
                                </data>
                                    <update state="CurrentWorkingHeatPoint" type="string"></update> <!-- Update Working Heat Point Status variable, state variable via statecenter binding -->
                                </data>
                                </data>
                            </rspmessage>
                            <rspmessage status="success" name="QueryHeatPointSuccess2">
                                </data>
                                </data>
                                </data>
                            </rspmessage>
                        </response_codes>
                    </command>
                    <command> <!-- Set the New Heat Point-->
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="5" parameter_data_width="5">HTSP!</parameter>
                            <parameter parameter_data_type="character" parameter_total_width="2" parameter_data_width="2" state_variable="WorkingHeatPoint++"></parameter>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Query Heat Point -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="DecreaseHeatPointTemperature">
                        <parameter_list>
                        </parameter_list>
                        <response_codes>
                                </data>
                                </data>
                                </data>
                            </rspmessage>
                                </data>
                                </data>
                                </data>
                            </rspmessage>
                        </response_codes>
                    </command>
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="2" parameter_data_width="2" state_variable="WorkingHeatPoint--"></parameter>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="SetHeatPointTemperature">
                <action_argument name="HeatPointTemperature" note="Carrier Heat Point Temperature, Degrees F/C (00 - 99)"/>
                    <command>
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="2" parameter_data_width="2" action_argument="HeatPointTemperature"></parameter>
                        </parameter_list>
                        <delay ms_delay="3000"/>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="SetCoolPointTemperature">
                <action_argument name="CoolPointTemperature" note="Carrier Cool Point Temperature, Degrees F/C (00 - 99)"/>
                    <command>
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="2" parameter_data_width="2" action_argument="CoolPointTemperature"></parameter>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="UpdateHVACStatus"> <!-- Update All status variables -->
                <action_argument name="ThermostatAddress" note="not used"/>
                    <command>
                        <command_string>S2Z1RT?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z2RT?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z1RH?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z2RH?</command_string>
                    </command>
                    <command>
                        <command_string>S2OAT?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z1FAN?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z2FAN?</command_string>
                    </command>
                    <command>
                        <command_string>S2MODE?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z1HTSP?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z2HTSP?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z1CLSP?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z2CLSP?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z1RHTG?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z2RHTG?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z1NAME?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z2NAME?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z1CFGEM?</command_string>
                    </command>
                    <command>
                        <command_string>S2Z2CFGEM?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z1RT?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z2RT?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z1RH?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z2RH?</command_string>
                    </command>
                    <command>
                        <command_string>S1OAT?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z1FAN?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z2FAN?</command_string>
                    </command>
                    <command>
                        <command_string>S1MODE?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z1HTSP?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z2HTSP?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z1CLSP?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z2CLSP?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z1RHTG?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z2RHTG?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z1NAME?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z2NAME?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z1CFGEM?</command_string>
                    </command>
                    <command>
                        <command_string>S1Z2CFGEM?</command_string>
                    </command>
            </action>
            <entity name="Zone" address_components="2">
                <screen_representation>
                    <common_unique_identifier name="ThermostatAddress" address_component="1"/>
                    <common_unique_identifier name="ThermostatAddress2" address_component="2"/>
                </screen_representation>
                <query_status_with_action name="QueryCurrentTemperature" period_ms="0">
                    <with_arg name="ThermostatAddress" address_component="1"/>
                    <with_arg name="ThermostatAddress2" address_component="2"/>
                </query_status_with_action>
                <query_status_with_action name="QueryCurrentTemperature" period_ms="300000">
                <query_status_with_action name="QueryCurrentFanMode" period_ms="0">
                <query_status_with_action name="QueryCurrentFanMode" period_ms="180000">
                <query_status_with_action name="QueryCurrentHeatSetPoint" period_ms="0">
                <query_status_with_action name="QueryCurrentHeatSetPoint" period_ms="180000">
                <query_status_with_action name="QueryCurrentCoolSetPoint" period_ms="0">
                <query_status_with_action name="QueryCurrentCoolSetPoint" period_ms="180000">
            </entity>
        </resource_component_actions>
sbe08 offline
        <custom_component_actions>
            <!-- Fan Modes -->
            <action name="SetFanModeLow">
                    <command>
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="7" parameter_data_width="7">FAN!LOW</parameter>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="SetFanModeMed">
                    <command>
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="SetFanModeHigh">
                    <command>
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="8" parameter_data_width="8">FAN!HIGH</parameter>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <!-- HVAC Modes -->
            <action name="SetHVACModeEmergencyHeat">
                    <command>
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="10" parameter_data_width="10">MODE!EHEAT</parameter>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <!-- Query Actions -->
            <action name="QueryCurrentTemperature">
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="3" parameter_data_width="3">RT?</parameter>
                        </parameter_list>
                    </command>
            </action>
            <action name="QueryCurrentHumidity">
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="3" parameter_data_width="3">RH?</parameter>
                        </parameter_list>
                        <delay ms_delay="1300"/>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="QueryCurrentOutdoorTemperature">
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="4" parameter_data_width="4">OAT?</parameter>
                        </parameter_list>
                    </command>
                <execute_on_schedule period_ms="0">
                    <with_arg name="ThermostatAddress" value="1"/>
                </execute_on_schedule>
                <execute_on_schedule period_ms="60000">
                    <with_arg name="ThermostatAddress" value="2"/>
            </action>
            <action name="QueryCurrentFanMode">
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="QueryCurrentHVACMode">
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="QueryCurrentHeatSetPoint">
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="QueryCurrentCoolSetPoint">
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="QueryCurrentHumidifyPoint">
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="5" parameter_data_width="5">RHTG?</parameter>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="QueryCurrentZoneName">
                        <parameter_list>
                            <parameter parameter_data_type="character" parameter_total_width="5" parameter_data_width="5">NAME?</parameter>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="QueryCurrentTemperatureFormat">
                        <parameter_list>
                            <parameter parameter_data_type="character">CFGEM?</parameter>
                        </parameter_list>
                    </command>
            </action>
            <action name="QueryStatusForZone">
                    <command response_required="no"> <!-- Temperature -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Humidity -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Outdoor Temp -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Fan Mode -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- HVAC Mode -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Heat Setpoint -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Cool Setpoint -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Humidity SetPoint -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Zone Name -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Temp. Format -->
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <!-- Update Working Set Point State Variables -->
            <action name="UpdateWorkingCoolPoint">
                        <parameter_list>
                        </parameter_list>
                        <response_codes>
                                </data>
                                </data>
                            </rspmessage>
                                </data>
                                </data>
                            </rspmessage>
                        </response_codes>
                    </command>
            </action>
            <action name="UpdateWorkingHeatPoint">
                        <parameter_list>
                        </parameter_list>
                        <response_codes>
                                </data>
                                <data type="character" terminator="B0" terminator_type="hex">
                                </data>
                            </rspmessage>
                                </data>
                                </data>
                            </rspmessage>
                        </response_codes>
                    </command>
            </action>
            <!-- System Polling -->
            <action name="SystemInfo">
                    <command response_required="no"> <!-- System Mode -->
                        <command_string type="character">S2MODE?</command_string>
                        <delay ms_delay="1400"/>
                    </command>
                    <command response_required="no"> <!-- System Temp Units -->
                        <command_string type="character">S2CFGEM?</command_string>
                    </command>
                    <command response_required="no"> <!-- System Outdoor temp -->
                        <command_string type="character">S2OAT?</command_string>
                    </command>
                        <command_string type="character">S1MODE?</command_string>
                    </command>
                        <command_string type="character">S1CFGEM?</command_string>
                    </command>
                        <command_string type="character">S1OAT?</command_string>
                    </command>
            </action>
            <!-- Zone Polling -->
            <action name="ZoneInfo">
                    <command response_required="no"> <!-- Room Temp -->
                        <command_string type="character">S</command_string>
                        <parameter_list>
                            <parameter parameter_data_type="character" action_argument="ThermostatAddress2" parameter_total_width="1" parameter_data_width="1"></parameter>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Room Fan Mode -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Room Heatpoint -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <command response_required="no"> <!-- Room coolpoint -->
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <!-- name
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <!-- Humidity info
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
            </action>
            <action name="CurrentTempUpdate">
                        <parameter_list>
                        </parameter_list>
                    </command>
                        <parameter_list>
                        </parameter_list>
                    </command>
                    <!-- name
                        <parameter_list>
                        </parameter_list>
                        </command>
                    <!-- Humidity info
                        <parameter_list>
                        </parameter_list>
                        </command>
                        <parameter_list>
                        </parameter_list>
                        </command>
            </action>
        </custom_component_actions>
    </logical_component>
</component>
Fri Sep 10, 2021 3:31 pm
7rdr7 offline
Sweet plugin if you're using HomeKit/Homebridge.
https://github.com/grivkees/homebridge- ... ity#readme
