No Devices showing for Ecobee Thermostat
Sun Jan 17, 2021 2:04 pm
RickStreet offline
Folks,
I got my new Ecobee3 Lite and get everything outside of Indigo working. I followed the instructions for the Ecobee plug-in. It authenticated ok. The debug shows the thermostat:
Ecobee 2 Debug Ecobee Account (1982410693): Ecobee Account Update OK, got info on 1 thermostats
Ecobee 2 Debug Ecobee Account (1982410693): getting data for 'Living Room', 411934889577
There are no devices showing when I attempt to create a thermostat.
Any help would be greatly appreciated. I followed the advice in the other similar topic. I'm starting to pull my hair out.
Rick
Rick
Sun Jan 17, 2021 2:46 pm
Re: No Devices showing for Ecobee Thermostat
Is "Living Room" your only thermostat? Do you have more than one?
Turn on debug level logging (NOT detailed), restart the plugin, and try to create the device again. Then post the log.
Sat Jan 23, 2021 1:21 pm
DU Lou offline
Hi Joe,
Same exact scenario it seems with my E3 Lite. Here is the debug output:
Stopped plugin "Ecobee 2 2.3.0"
   Starting plugin "Ecobee 2 2.3.0" (pid 733)
   Ecobee 2 Debug                  logLevel = 10
   Started plugin "Ecobee 2 2.3.0"
   Ecobee 2                        Starting Ecobee
   Ecobee 2 Debug                  macOS 10.13.6, Indigo 7.5.0
   Ecobee 2 Debug                  updateFrequency = 180.0
   Ecobee 2 Debug                  setting temperature scale to F
   Ecobee 2                        Ecobee Account (1043274434): Starting EcobeeAccount Device 1043274434
   Ecobee 2                        Ecobee Account (1043274434): EcobeeAccount created using refresh token = 48VdTA8O9pTEkZgdNKTjDUGiFYOS-IxepGBxtLnMdq5h7
   Ecobee 2 Debug                  Ecobee Account (1043274434): Token Refresh, old refresh_token = 48VdTA8O9pTEkZgdNKTjDUGiFYOS-IxepGBxtLnMdq5h7
   Ecobee 2 Debug                  Ecobee Account (1043274434): Token Refresh OK, new access_token = eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6IlJFWXhNVEpDT0Rnek9UaERRelJHTkRCRlFqZEdNVGxETnpaR1JUZzRNalEwTmtWR01UQkdPQSJ9.eyJpc3MiOiJodHRwczovL2F1dGguZWNvYmVlLmNvbS8iLCJzdWIiOiJhdXRoMHwxMjU5NGQ2Ny1jMTdkLTRjYjEtYTBhNi1lMWU5ZGY2ZDk2NDAiLCJhdWQiOlsiaHR0cHM6Ly9kZXZlbG9wZXItYXBwcy5lY29iZWUuY29tL2FwaS92MSIsImh0dHBzOi8vZWNvYmVlLXByb2QuYXV0aDAuY29tL3VzZXJpbmZvIl0sImlhdCI6MTYxMTQyOTMzNiwiZXhwIjoxNjExNDMyOTM2LCJhenAiOiJvcFNNTzZSdG9VbGhvQXRsUWVoTlpkYU9aNkVRQk82USIsInNjb3BlIjoib3BlbmlkIHNtYXJ0V3JpdGUgb2ZmbGluZV9hY2Nlc3MifQ.b4tbYlcWM5nIiCScFB4UI-Zn8TXTHeBHc_82kqNCQJgPsh0xkQaDI5J15Wx5W_hQvP2Nd-CywmZ1uBMqQrQEBn-qK61EMZlKJW2DHqvMPvIQPrIPAbOVZFUjjfO37PUgrgxYNEgtZ6kkziD60wnq7hESpmGPdL6jenhqAr5jPuaXnHaH87Dez5gjaN9l3GUrIDOxEjWQyN9PSnhVbJgZINsELw-L1WbKxoAroNnh84t8kNSywHi0qDmPr-vAnt2LVqf33NZxN_M7Ldi4dCqXHomWHTrSIoeUsx2twVytF-hUHXRJjdSaw77guFJWWzEPY9NvUHtvJ_1sQRoRvwm4bg
   Ecobee 2 Debug                  Ecobee Account (1043274434): Refresh Token did not change
   Ecobee 2 Debug                  runConcurrentThread starting
   Ecobee 2 Debug                  Ecobee Account (1043274434): Ecobee Account Update OK, got info on 1 thermostats
   Ecobee 2 Debug                  Ecobee Account (1043274434): getting data for 'Home', 412837588217
Jan 23, 2021 at 2:15:53 PM
   Ecobee 2 Debug                  getDeviceFactoryUiValues: devIdList = UiElemIdList : (list)
   Ecobee 2 Warning                get_device_list: unknown deviceType = EcobeeThermostat
   Ecobee 2 Debug                  get_account_list: accounts = [(1043274434, u'Ecobee Account (1043274434)')]
   Ecobee 2 Debug                  closedDeviceFactoryUi: user cancelled
Thanks for the support!
~Lou
Sat Jan 23, 2021 1:23 pm
Is the E3 lite a new model? I don't recall seeing that name. Use the menu command that dumps the thermostat data to the log and post it here.
Sat Jan 23, 2021 1:35 pm
DU Lou offline
Sorry for the shorthand :)
Device: ecobee 3 lite
Firmware: 4.6.3.86
~Lou
Sat Jan 23, 2021 1:38 pm
DU Lou offline
Is that the "Detailed Debugging" in your plugin?
I need the actual data from the plugin. It's a lot of data, but it includes the actual model name and capabilities.
Sat Jan 23, 2021 1:39 pm
No. It's a menu command. Plugins->Ecobee->Write Thermostat Data to Log
Sat Jan 23, 2021 1:41 pm
DU Lou offline
hmmmm - seems a little light on the output...should I be expecting more?
Jan 23, 2021 at 2:39:39 PM
   Ecobee 2 Debug                  closedPrefsConfigUi called
   Ecobee 2 Debug                  menuDumpThermostat
   Ecobee 2                        {
    "412837588217": {
        "actualHumidity": 54,
        "actualTemperature": 698,
        "brand": "ecobee",
        "climates": {
            "away": "Away",
            "home": "Home",
            "sleep": "Sleep"
        "currentClimate": "home",
        "desiredCool": 700,
        "desiredFanMode": "auto",
        "desiredHeat": 700,
        "equipmentStatus": "",
        "fanMinOnTime": 0,
        "features": "Home,HomeKit",
        "hvacMode": "cool",
        "internal": {
            "humidity": "54",
            "temperature": "698"
        "latestEventType": "hold",
        "modelNumber": "nikeSmart",
        "name": "Home",
        "remotes": {}
   Ecobee 2                        {}
Sat Jan 23, 2021 1:43 pm
No, that's fine. It the "nikeSmart" line I needed to see, to make sure this is a model I've already accounted for.
I'll look into the error.
Sat Jan 23, 2021 1:44 pm
DU Lou offline
Sounds good and thanks again Joe!
~Lou
Sat Jan 23, 2021 1:45 pm
RickStreet offline
Joe,
It is the only thermostat. I renamed it to "Upstairs". I deleted the Ecobee Account Device from Indigo and deleted the app from the Ecobee site. I added the account device back in and authorized it. I then tried to add an Ecobee thermostat device to indigo. The device list is blank. Here's the debug output:
   Ecobee 2 Debug                  get_account_list: accounts = []
   Ecobee 2                        Created EcobeeAccount device 'Ecobee Account (608027512)'
   Ecobee 2                        new device: Starting EcobeeAccount Device 608027512
   Ecobee 2                        new device: EcobeeAccount created using refresh token = 2Iuzf9R1xQf_kBP2DNnURBqItz2f62YCCtLxf9V9d7vh3
   Ecobee 2 Debug                  Ecobee Account (608027512): Token Refresh, old refresh_token = 2Iuzf9R1xQf_kBP2DNnURBqItz2f62YCCtLxf9V9d7vh3
   Ecobee 2 Debug                  Ecobee Account (608027512): Token Refresh OK, new access_token = eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6IlJFWXhNVEpDT0Rnek9UaERRelJHTkRCRlFqZEdNVGxETnpaR1JUZzRNalEwTmtWR01UQkdPQSJ9.eyJpc3MiOiJodHRwczovL2F1dGguZWNvYmVlLmNvbS8iLCJzdWIiOiJhdXRoMHwyNmQ0NTYwYS00MmViLTQ4MDgtYjQzMi05Yjc3MmM1N2ZjNGUiLCJhdWQiOlsiaHR0cHM6Ly9kZXZlbG9wZXItYXBwcy5lY29iZWUuY29tL2FwaS92MSIsImh0dHBzOi8vZWNvYmVlLXByb2QuYXV0aDAuY29tL3VzZXJpbmZvIl0sImlhdCI6MTYxMTQzMDI1OSwiZXhwIjoxNjExNDMzODU5LCJhenAiOiJvcFNNTzZSdG9VbGhvQXRsUWVoTlpkYU9aNkVRQk82USIsInNjb3BlIjoib3BlbmlkIHNtYXJ0V3JpdGUgb2ZmbGluZV9hY2Nlc3MifQ.OjZDBPo6BUXGGqXdIOMDYJV87IHcvjAcVJdyIA2RteE5GqhLSTCg_5RdZzQjfuDRKCvNFGU0zoRMwnnU6GEXKS8ZH60r-UOnk8-3tvGnpm2Mzt_NI25MT2nJKwchHE1S07Kgqw8ZhBKBIpUoFsIEqt_nihPgXmXV_HwwaWBBoSypjxduQm6OJ7EnAgCrtmyWBezhHJAO4quf7tYa-srbvorPDp7sjKL0kNTMl37leVvH9gBS5RRbrhwSBigvIXJ7pRx6-ng01scw2Y46bBHq7EisB4Aa9841Xxga3CbL3J6eJrJMZ28y-f0bAAsT88DXlmSV2Hu66GnGrztfqhUi1g
   Ecobee 2 Debug                  Ecobee Account (608027512): Refresh Token did not change
Jan 23, 2021 at 11:31:17 AM
   Ecobee 2 Debug                  Ecobee Account (608027512): Ecobee Account Update OK, got info on 1 thermostats
   Ecobee 2 Debug                  Ecobee Account (608027512): getting data for 'Upstairs', 411934889577
   Ecobee 2 Debug                  Ecobee Account (608027512): getting data for remote sensor 'Master Bedroom', 6Y6H
   Ecobee 2 Debug                  Ecobee Account (608027512): getting data for remote sensor 'Chuck's Office', 2WQQ
   Ecobee 2 Debug                  Ecobee Account (608027512): getting data for remote sensor 'Kitchen', TJZG
   Ecobee 2 Debug                  Ecobee Account (608027512): getting data for remote sensor 'Wine Cellar', TNRC
   Ecobee 2 Debug                  get_account_list: accounts = [(608027512, u'Ecobee Account (608027512)')]
Rick
Thu Feb 04, 2021 5:13 pm
I seem to be experiencing the same issue, so +1. :lol:
Fri Feb 05, 2021 10:37 am
