Temperature sensed 'state ID'
Posted:
Wed Dec 30, 2020 3:16 pm
by SMUSEBY
What is the state ID to access the value of the temperature sensed by the thermostat. (temperature, Temperature, temperatures do not work).
I need the term to use with Better Email that specifies the format %%d:123456:someStateID%%.
Thank you.
Re: Temperature sensed 'state ID'
Posted:
Wed Dec 30, 2020 3:23 pm
by FlyingDiver
Excerpt from
indigo.server.log(unicode(indigo.devices[860569872]))- Code: Select all
states : States : (dict)
autoAway : no (yes/no bool)
autoHome : no (yes/no bool)
climate : home (string)
device_type : athenaSmart (string)
equipmentStatus : (string)
fanMinOnTime : 0 (integer)
humidityInput1 : 50 (real)
humidityInputsAll : 50 (string)
hvacCoolerIsOn : off (on/off bool)
hvacDehumidifierIsOn : off (on/off bool)
hvacFanIsOn : off (on/off bool)
hvacFanMode : 0 (integer)
hvacFanMode.ui : auto on (string)
hvacFanModeIsAlwaysOn : false (bool)
hvacFanModeIsAuto : true (bool)
hvacHeaterIsOn : off (on/off bool)
hvacHumidifierIsOn : off (on/off bool)
hvacOperationMode : 2 (integer)
hvacOperationMode.ui : cool on (string)
hvacOperationModeIsAuto : false (bool)
hvacOperationModeIsCool : true (bool)
hvacOperationModeIsHeat : false (bool)
hvacOperationModeIsOff : false (bool)
hvacOperationModeIsProgramAuto : false (bool)
hvacOperationModeIsProgramCool : false (bool)
hvacOperationModeIsProgramHeat : false (bool)
occupied : no (yes/no bool)
setpointCool : 77.5 (real)
setpointCool.ui : 77.5°F (string)
setpointHeat : 71.5 (real)
setpointHeat.ui : 71.5°F (string)
temperatureInput1 : 76.4 (real)
temperatureInput1.ui : 76.4°F (string)
temperatureInput2 : 77.4 (real)
temperatureInput2.ui : 77.4°F (string)
temperatureInputsAll : 76.4, 77.4 (string)
Looks like you want temperatureInput1 or temperatureInput2.
Posted:
Wed Dec 30, 2020 3:40 pm
by SMUSEBY
temperatureInput1 works.
Thank you.
