Authentication token has expired. Refresh your tokens.
Sun Dec 06, 2020 1:27 pm
bjmouton offline
I installed this plugin a few days ago and installation, setup & authentication went fine, I was able to read/write to thermostat just fine. I have not made any changes to the Indigo objects the plugin created, but now my thermostat data is no longer updating. The following are captures from the event logger as I issued setpoint changes from my mobile app:
Ecobee 2                        Ecobee Hallway: set cool to: 74.5 and leave heat at: 68.5
   Ecobee 2 Warning                API 'set hold temp' request failed, result = {
  "status": {
    "code": 14,
    "message": "Authentication token has expired. Refresh your tokens. "
   Ecobee 2                        Ecobee Hallway: set heat to: 69.5 and leave cool at: 73.5
  "status": {
    "code": 14,
   Ecobee 2                        Ecobee Hallway: set cool to: 75.5 and leave heat at: 69.5
  "status": {
    "code": 14,
   Ecobee 2                        Ecobee Hallway: set heat to: 70.5 and leave cool at: 74.5
  "status": {
    "code": 14,
   Ecobee 2                        Ecobee Hallway: set cool to: 76.5 and leave heat at: 70.5
  "status": {
    "code": 14,
   Ecobee 2                        Ecobee Hallway: set heat to: 71.5 and leave cool at: 75.5
  "status": {
    "code": 14,
Sun Dec 06, 2020 1:40 pm
Re: Authentication token has expired. Refresh your tokens.
Somehow the authentication was lost. Go through the process again in the device configuration dialog.
Sun Dec 06, 2020 1:46 pm
And if you still have problems, turn on debug level logging in the Plugin configuration, restart the plugin, then post the log from the restart.
Sun Dec 06, 2020 1:48 pm
bjmouton offline
I have already done that twice. It did not rectify the issue. Latest from logger after re-authentication:
   Ecobee 2                        Ecobee Hallway: set heat to: 67.5 and leave cool at: 72.5
  "status": {
    "code": 14,
   Ecobee 2 Error                  updatable: Error obtaining ecobee account object
Sun Dec 06, 2020 1:49 pm
I'm going to need debug level logging of the whole authentication process.
Sun Dec 06, 2020 1:52 pm
Oh, crap, I just thought of something. You first set this up after Dec 1, right? They made an API change then, so maybe new authentications (since the change) are not getting saved properly. I looked at their proposed changes, and didn't see anything that would be a problem, but who knows? I really need to see those debug logs.
Sun Dec 06, 2020 1:58 pm
Well, I just re-authenticated the plugin on my development platform, so far so good. I'll see if it fails.
Sun Dec 06, 2020 1:59 pm
bjmouton offline
Here is log of authentication process:
Edit: deleted actual data
Sun Dec 06, 2020 2:04 pm
Yeah, that looks a lot like mine. The format of those two strings changed in the API update. I'm guessing that it fails when storing the refresh token string when it's got characters in it that Indigo doesn't like. I'll watch to see what happens on mine. I'll probably have to re-encode the string somehow.
Sun Dec 06, 2020 2:09 pm
bjmouton offline
OK, I will be on standby.
Wed Dec 09, 2020 7:01 am
FYI. Have not seen the problem on my system yet. If you see it, please add the log info here: https://github.com/FlyingDiver/Indigo-Ecobee-2/issues/9
Specifically, I'm looking for the line like the following. The last occurrence before the errors start.
   Ecobee 2 Debug                  Token Request OK, access_token = eyJhbGciOiJSU ... yuV_wPfAyczLNabEoykxdYZyMg, refresh_token = Ya04RRv3lzvUYSOO22_NWYsd-f6fyrFmb5o, expires_in = 3600
Might also look like:
   Ecobee 2 Debug                  Token Refresh OK, new access_token = A96Cfz5yon9DMbrvs...5ogAoAj1J, new refresh_token = BMiRc8Dbj86w6NZ...Ui8goT5uQ69CR, expires_in = 3599
