Ecobee mode: when OFF, not responding to Auto Cool/Heat cmd
Thu Sep 17, 2020 6:44 pm
SMUSEBY offline
I may have found another plug in bug. With the thermostat mode = "Off", at the device, changing the mode to "Auto Cool/Heat" is not changing the thermostat from "Off".
Below, with thermostat in OFF, I set the mode to "Auto Cool/Heat"
The relevant thermostat is "Front Hall".
Sep 17, 2020 at 5:36:22 PM
Ecobee 2 Debug logLevel = 10
Ecobee 2 Debug updateFrequency = 900.0
Ecobee 2 Debug setting temperature scale to C
Ecobee 2 Debug Ecobee Account (1428206274): Ecobee Account Update OK, got info on 2 thermostats
Ecobee 2 Debug Ecobee Account (1428206274): getting data for 'Front Hall', 521703550260
Ecobee 2 Debug Ecobee Account (1428206274): getting data for remote sensor 'North Office', C5SW
Ecobee 2 Debug Ecobee Account (1428206274): getting data for 'Stairs', 521781046633
Ecobee 2 Debug Ecobee Front Hall: Updating device
Ecobee 2 Debug Ecobee Front Hall Remote - North Office: Updating device
Sep 17, 2020 at 5:36:42 PM
Ecobee 2 Debug Ecobee Front Hall: action.thermostatAction: SetHvacMode
Ecobee 2 Debug Ecobee Front Hall (521703550260): Mode set to: auto
Ecobee 2 Debug API 'set HVAC mode' request completed, result = <Response [200]>
Thu Sep 17, 2020 7:02 pm
Re: Ecobee mode: when OFF, not responding to Auto Cool/Heat
You're going to have to go to Detailed Debugging for more info.
Thu Sep 17, 2020 7:14 pm
Well, never mind. That section of code doesn't have any more detailed debug logging.
But I can't reproduce your results. I started with the thermostat in Auto mode. Indigo showed the same state. I used the Ecobee app to change the mode to Off (which should be the same as going to the device and doing it on the display). I clicked "Send Status Request" in the Indigo UI, and a couple seconds later the Mode updated correctly. Then I turned the system back on, requested status update again, and it correctly updated.
If you're not getting those results, please post your EXACT sequence of events, remembering that the plugin POLLs the Ecobee servers and won't update in real time unless you specifically request a status update.
Fri Sep 18, 2020 4:20 pm
SMUSEBY offline
I am able to reproduce your results. My steps differed by my selecting 'Auto Cool/Heat', while you were selected 'Heat'.
A few days ago, I learned from Ecobee support that the Y1 wire is for controlling AC. I don't have the Y1 connected, and that might be the explanation as to why the system does not respond to the Auto Heat/Cool command.
Fri Sep 18, 2020 4:23 pm
Ah. All my systems are heat and cooling, so they work for any of the modes. I'm not sure there's anything I can do in the plugin to prevent your error.
Fri Sep 18, 2020 4:38 pm
SMUSEBY offline
easy work-around - just select heat.
assuming I'm correct, you could document: "with no Y1 connection, auto heat/cool does not work".
Fri Sep 18, 2020 4:40 pm
Well, since your system doesn't have any cooling, that would seem obvious. ;)
Fri Sep 18, 2020 4:42 pm
SMUSEBY offline
Right - but it wasn't...
