Ecobee Authentication issues with Indigo 7.4
Mon Oct 07, 2019 12:18 pm
7rdr7 offline
Anyone experiencing any Ecobee authentication issues with Indigo 7.4. After upgrading, it began to fail authentications. I re-authenticated twice, still the same problem. The plugin authentication window confirms a successful authentication, but the errors continue.
Oct 7, 2019 at 2:06:21 PM
Indigo Cocoa client authenticated (192.168.1.10)
Enabling plugin "Ecobee 2 2.2.0"
Starting plugin "Ecobee 2 2.2.0" (pid 29061)
Started plugin "Ecobee 2 2.2.0"
Ecobee 2 Starting Ecobee
Ecobee 2 Ecobee Account (1561638859): Starting EcobeeAccount Device 1561638859
Ecobee 2 Error Ecobee Account (1561638859): Authentication lost, please re-authenticate.'
Ecobee 2 Kitchen Occupancy: Starting OccupancySensor Device 1577145367
Ecobee 2 Kitchen Thermostat: Starting EcobeeThermostat Device 702521190
Ecobee 2 Media Room Occupancy: Starting OccupancySensor Device 352480444
Ecobee 2 Media Room Pillar (LSC3): Starting RemoteSensor Device 1482903299
Ecobee 2 Media Room Thermostat: Starting EcobeeThermostat Device 911299020
Ecobee 2 Sunroom Sensor (X7FP): Starting RemoteSensor Device 938326233
Ecobee 2 not authenticated to Ecobee servers yet; not initializing state of device 311003735841
Ecobee 2 not authenticated to Ecobee servers yet; not initializing state of device 311080879621
Ecobee 2 not authenticated to Ecobee servers yet; not initializing state of device X7FP
Ecobee 2 not authenticated to Ecobee servers yet; not initializing state of device LSC3
Z-Wave received "Outdoor Probe" sensor update to 25.6 °C
Z-Wave received "Pool Probe" sensor update to 25.1 °C
Z-Wave received "Floor Drain" power load to 0.4 W
Ecobee 2 Error Error in plugin execution UiAction:
Oct 7, 2019 at 2:07:26 PM
Ecobee 2 Error Token Request failed, response = '{
"error": "authorization_pending",
"error_description": "Waiting for user to authorize application.",
"error_uri": "https://tools.ietf.org/html/rfc6749#section-5.2"
Oct 7, 2019 at 2:09:04 PM
Z-Wave received "Main Pump" energy total to 1156.394 kWh
Trigger Control Page Pump Power Cumulative
Oct 7, 2019 at 2:11:32 PM
Ecobee 2 Error Ecobee account 1561638859 not authenticated, skipping refresh
Z-Wave received "Outdoor Probe" sensor update to 25.5 °C
Z-Wave received "Floor Drain" power load to 0.1 W
Mon Oct 07, 2019 12:30 pm
Re: Ecobee Authentication issues with Indigo 7.4
That's definitely telling you to redo the authentication. Not sure how it got lost. My install did not have that problem.
Just go into the config dialog for the Ecobee Account device and redo the authentication process.
Tue Oct 08, 2019 11:40 am
Hap offline
I had the same issue, reauthenticated and then got this:
   Ecobee 2 Error                  Error in plugin execution UiClosed3:
  File "plugin.py", line 414, in closedDeviceFactoryUi
UnboundLocalError: local variable 'newdev' referenced before assignment
and this...
 Ecobee 2 Error                  Error in plugin execution GetUiDynamicList:
  File "plugin.py", line 248, in get_device_list
UnboundLocalError: local variable 'available_devices' referenced before assignment
Tue Oct 08, 2019 11:46 am
OK, I'm going to have to see if I can figure out a way to reproduce this. I'm not seeing anything like that.
Tue Oct 08, 2019 12:29 pm
I cannot reproduction this issue. I went to the Ecobee site, logged in, then removed the Indigo 'app' from the account. Then I restarted the plugin and got the same errors:
   Ecobee 2                        Ecobee Account: Starting EcobeeAccount Device 363954845
   Ecobee 2 Error                  Ecobee Account: Authentication lost, please re-authenticate.'
   Ecobee 2                        Ecobee Master Suite: Starting EcobeeThermostat Device 860569872
   Ecobee 2                        Ecobee Master Suite Occupancy: Starting OccupancySensor Device 357830907
   Ecobee 2                        Ecobee Master Suite Remote - Master Bedroom: Starting RemoteSensor Device 686322743
   Ecobee 2                        Ecobee Upstairs: Starting EcobeeThermostat Device 253943175
   Ecobee 2                        Ecobee Upstairs Occupancy: Starting OccupancySensor Device 1590516520
   Ecobee 2                        Ecobee Upstairs Remote - Bonus Room: Starting RemoteSensor Device 303466546
   Ecobee 2                        not authenticated to Ecobee servers yet; not initializing state of device 313892758064
   Ecobee 2                        not authenticated to Ecobee servers yet; not initializing state of device 311018773951
Then I went through the normal authentication process. And then I restarted the plugin again. No errors.
Tue Oct 08, 2019 3:29 pm
7rdr7 offline
I finally got it working after disabling/enabling the plugin, deleting/ adding the app on the Ecobee site, and authenticating. It took a few cycles, but it's finally working now.
Wed Sep 30, 2020 5:01 pm
SMUSEBY offline
I'm having the same problem - the error messages are overwhelming indigo.
I haven't been tinkering with the thermostat and have no idea why this failure started. To fix it, I reiloaded the plug-in, and next, deleted the app (plug-in) on the ecobee website, and reinstalled it.
Same behavior.
Scrolling up the log, the first engry in the log that wasn't the 'not authenticated' error message is quoted below. The plug-in is configured for informational messages, which I am about to turn off.
2020-09-30 15:40:12.398   Ecobee 2 Error   Error in plugin execution runConcurrentThread:
  File "plugin.py", line 159, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Ecobee 2.indigoPlugin/Contents/Server Plugin/ecobee_devices.py", line 79, in update
KeyError: u'521703550260'
2020-09-30 15:40:12.398   Ecobee 2 Error   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2020-09-30 15:40:22.402   Ecobee 2 Error   Ecobee account 123… not authenticated, skipping refresh
Wed Sep 30, 2020 5:54 pm
Same behavior.
That keyError generally means a bad Indigo device. Delete ALL devices associated with the plugin and start from scratch.
Wed Sep 30, 2020 8:25 pm
SMUSEBY offline
Oh - deleting the thermostat sounds like an arduous 'fix'.
Is there anyway I can preserve the various triggers, schedules and action groups that deleting the device will take down with it? If this is something that is going to happen frequently, this sounds like a troublesome flaw.
Any idea what may have caused this?
Wed Sep 30, 2020 8:35 pm
Hmm. Let me look at the code again. There might be a way to get around this long enough to authenticate the plugin. I need you to turn on debug level logging, and give me the log outputs before and after the error.
Also, run the "Write Thermostat data to Log" menu command and include that part of the log.
Thu Oct 01, 2020 12:28 pm
There's two problems - First, that error on the periodic update. Second, the Ecobee refresh token is bad, so it's failing authentication. Which means you'll need to redo the authentication process.
Have you tried to re-authenticate? Or is the update error breaking that? Also, the log segment doesn't show the exception after the restart. Does it do it 15 minutes later (update frequency 900 seconds)?
Thu Oct 01, 2020 12:38 pm
SMUSEBY offline
The log messages are from my regular home. Two days ago, on the Ecobee internet interface, I deleted the plug-in, and then reinstalled it and redid the authentication. It continued to be broken. I have done nothing on the vacation home other than look at the log entries, change the plug-in message level to critical only, and reload the plug-in.
If by 'log segment', you are referring to the request for 'thermostat data to log', the entry for the first request was at 11:05; subsequent to that are hundreds of authentication errors, and no log entry with a date or time (including anything at 11:20).
Thu Oct 01, 2020 12:42 pm
Try https://github.com/FlyingDiver/Indigo-E ... /tag/2.2.3
It should keep the plugin from crashing, but you'll still need to get the re-authentication completed.
Thu Oct 01, 2020 12:49 pm
SMUSEBY offline
what are the exact steps to do the re authentication?
Thu Oct 01, 2020 12:51 pm
Same as initial authentication, but using the existing account device.
https://github.com/FlyingDiver/Indigo-Ecobee-2
