Re: Ecobee thermometer not showing during device creation
Posted: Wed Aug 21, 2019 5:57 am
Same problem as others - TStat device not appearing in dropdown. Here's the log. No obvious errors during the authenication process - however earlier this morning when trying to create the account device, the authentication kept being lost. Anyway here's the log...
- Code: Select all
Aug 21, 2019 at 7:51:27 AM
Enabling plugin "Ecobee 2 2.2.0"
Starting plugin "Ecobee 2 2.2.0" (pid 55130)
Started plugin "Ecobee 2 2.2.0"
Ecobee 2 Starting Ecobee
Aug 21, 2019 at 7:52:27 AM
Ecobee 2 Debug logLevel = 5
Ecobee 2 Debug updateFrequency = 900.0
Ecobee 2 Debug setting temperature scale to F
Aug 21, 2019 at 7:53:01 AM
Ecobee 2 Debug getDeviceFactoryUiValues: devIdList = UiElemIdList : (list)
Ecobee 2 Debug get_account_list: accounts = []
Aug 21, 2019 at 7:54:13 AM
Ecobee 2 Debug PIN Request OK, pin = 6imp. authorization_code = KwFo7fW8CWPAUKthoPmahgqBWBaookyp
Aug 21, 2019 at 7:54:32 AM
Ecobee 2 Debug validateDeviceFactoryUi: valuesDict = UiValuesDict : (dict)
account : (string)
address : (string)
authStatus : PIN Request OK (string)
createRemotes : true (bool)
deviceType : EcobeeAccount (string)
getPin : (string)
getTokens : (string)
holdType : nextTransition (string)
openEcobee : (string)
openEcobeeNote : (string)
pin : 6imp (string)
separator1 : (string)
spacer1 : (string)
spacer2 : (string)
spacer3 : (string), devIdList = IdList : (list)
Ecobee 2 Warning validateDeviceFactoryUi - Ecobee Account Not Authenticated
Aug 21, 2019 at 7:54:48 AM
Ecobee 2 Debug Token Request OK, access_token = 92v595wLnM1BIsUJajzPbqyjko2EhD5f, refresh_token = 5FOYUpkmvABmL9yVpjsyc7sSS1qIU0PP, expires_in = 3599
account : (string)
address : (string)
authStatus : Authenticated (string)
getPin : (string)
pin : (string)
spacer1 : (string)
spacer2 : (string)
Error (client) _sendClosedConfigUi3() caught exception: LowLevelBadParameterError
Ecobee 2 Debug closedDeviceFactoryUi: valuesDict =
account : (string)
address : (string)
getPin : (string)
pin : (string)
spacer1 : (string)
spacer2 : (string)
spacer3 : (string)
devIdList =
IdList : (list)
Ecobee 2 Created EcobeeAccount device 'Ecobee Account (780204832)'
Ecobee 2 Error Error in plugin execution UiClosed3:
File "plugin.py", line 414, in closedDeviceFactoryUi
UnboundLocalError: local variable 'newdev' referenced before assignment
Ecobee 2 new device 2: Starting EcobeeAccount Device 780204832
Ecobee 2 Debug new device 2: EcobeeAccount __init__, using refresh token = 5FOYUpkmvABmL9yVpjsyc7sSS1qIU0PP
Ecobee 2 Debug Token Request with refresh_token = 5FOYUpkmvABmL9yVpjsyc7sSS1qIU0PP
Ecobee 2 Debug Token Refresh OK, new access_token = a2eyfsV3eXtFFwWWgqzpESxDfQaSnUub, new refresh_token = cjC3oUUoIZjYOkgahP3uRxGroxTMor3R, expires_in = 3599
Error (client) doPluginDeviceFactory requires at least one root device
Aug 21, 2019 at 7:55:21 AM
Ecobee 2 Debug get_device_list: active_stats = []
Ecobee 2 Debug get_device_list: available_devices for EcobeeThermostat = []
Ecobee 2 Debug get_account_list: accounts = [(780204832, u'Ecobee Account (780204832)')]
Aug 21, 2019 at 7:55:52 AM
account : 780204832 (integer)
address : (string)
authStatus : (string)
deviceType : EcobeeThermostat (string)
getPin : (string)
pin : (string)
spacer1 : (string)
spacer2 : (string)
Ecobee 2 Warning validateDeviceFactoryUi - No Thermostat Specified
Ecobee 2 Debug closedDeviceFactoryUi: user cancelled
