2 new sensors on Ecobee4 not showing up
Sat Jan 19, 2019 6:03 pm
eric offline
I have an Ecobee 4 with three sensors. I just added two new ones (total now five) and they are appearing in the Ecobee app and on their site, but they have not shown up in Indigo.
Any ideas how to get them to show up?
I have tried reloading the plugin, reregistering, restarting Indigo.
Thanks.
Sat Jan 19, 2019 7:03 pm
Re: 2 new sensors on Ecobee4 not showing up
Hmm. I don't think accounted for that case when creating devices. I'll have to look into it.
Sat Jan 19, 2019 7:41 pm
Can you dump the thermostat data to the log. It's a menu command. Then post the log segment here or add it to the issue I created for this problem: https://github.com/FlyingDiver/Indigo-Ecobee-2/issues/7
Sat Jan 19, 2019 8:20 pm
eric offline
I'm getting authentication errors not for some reason. I've tried re-authenticating but it doesn't seem to help.
I don't think this is related to the described issue.
File "plugin.py", line 601, in menuDumpThermostat
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Ecobee 2.indigoPlugin/Contents/Server Plugin/ecobee.py", line 508, in dump_data
KeyError: (u'511832998677',)
Ecobee 2 Error Ecobee account 994942277 not authenticated, skipping refresh
Sat Jan 19, 2019 8:21 pm
You need to fix that authentication error before anything else. Make sure you're running the latest version then re-authenticate the Account device.
Sat Jan 19, 2019 9:06 pm
In any case, I know what the problem is. It's not a trivial issue to fix, so it'll be a few days at least before I have a possible fix.
Sat Jan 19, 2019 9:10 pm
eric offline
Thanks.
I think the auth errors are with ecobee as they are not fixable at the moment.
I'll keep trying.
Look forward to the new version and thanks!
Sun Jan 20, 2019 12:01 pm
Thanks for that, but it turns out that I didn't really need it. :oops:
As I said before, it's non-trivial to fix this right. So it's going to be a while. The short-cut is to delete the thermostat device and re-create it, but that's going to mess up anything you have connected to the existing devices (scripts, triggers, control pages, etc). Not really recommended.
Thu Jan 24, 2019 5:08 pm
FYI - I am making progress on this. Should have something for you to try out this weekend.
Did you solve your Authentication issues?
Thu Jan 24, 2019 9:37 pm
eric offline
Great!
Yes, as above they solved spontaneously.
Probably Ecobee.
Thanks.
Fri Feb 01, 2019 5:25 pm
Try https://github.com/FlyingDiver/Indigo-E ... /tag/2.2.0
This version allows for creating and deleting remote sensor devices independently of the linked thermostat.
Lots of code changes, as enabling this functionality required a major rewrite.
Remote sensors are no longer part of the thermostat device group. Only the built-in occupancy sensor is (if present).
Default device naming is simpler. I'm making an assumption that Ecobee requires unique names.
Sun Feb 03, 2019 9:47 am
eric offline
Thank you for this update!
It's installed and appears to work very well - I like the independent addition of the remotes.
Eric
Sun Feb 03, 2019 9:51 am
Good. I'm going to leave this as a test release for a while longer. I'm running it on my system (4 thermostats, 5 total remotes), but it could use some more testing, especially with devices other than my Ecobee3 models.
Fri Mar 08, 2019 7:14 am
eric offline
Another update from me.
Bought and added two more sensors yesterday, one to each of two thermostats.
Worked perfectly.
Wed Mar 27, 2019 2:27 pm
Changing the plugin from pre-release to release. Updating the store.
