Ecobee Version 2.0.3 Pre-release
Sun Oct 28, 2018 9:19 am
New thread for this release since there are major changes.
  • Except for the Ecobee Account devices, all device definitions have changed and you need to delete the old devices.
  • You only need to create a device for the Ecobee Thermostat itself. All remotes will be auto-created.
  • Type of Ecobee thermostat is auto-detected and an appropriate device will be created for you.
  • Thermostats with built-in occupancy sensor will get an additional device created for that sensor.
  • Reminder - High Sierra or Mojave required. There will be a message in the Indigo log if you're not running a supported OS.
Download: https://github.com/FlyingDiver/Indigo-E ... /tag/2.0.3
Please post here with a summary of your Ecobee hardware. I especially need testers with something other than Ecobee 3 units (I have four of those). Also, configurations with no remote sensors, as all of mine have at least one.
Feedback on the device naming scheme appreciated. It's kind verbose now, but that's mostly to ensure I don't get name collisions.
Enhancement requests always welcome, but if it's something significant expect me to request you create a GitHub issue for it.
Mon Oct 29, 2018 6:21 am
eme jota ce offline
Re: Ecobee Version 2.0.3 Pre-release
Seeing the following errors after update to latest version for Ecobee 2, from Ecobee 2 beta.
Indigo 7.2 on Mojave 10.14.
Ecobee 2 Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 140, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Ecobee 2.indigoPlugin/Contents/Server Plugin/ecobee.py", line 459, in update
KeyError: u'511880787182'
Ecobee 2 Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Mon Oct 29, 2018 6:23 am
Did you delete all your devices (except the EcobeeAccount) and recreate them as directed above?
Mon Oct 29, 2018 7:05 am
eme jota ce offline
I did, only after posting above. Sorry. After deleting old devices, and reauthorizing with new PIN at the Ecobee site, I added the device. Now seeing the following errors.
Ecobee 2 Debug MBR HVAC ecobee: action.thermostatAction: IncreaseCoolSetpoint
Ecobee 2 MBR HVAC ecobee: set cool to: 77.0 and leave heat at: 70.0
Ecobee 2 Debug API 'set hold temp' request completed, result = <Response [200]>
Ecobee 2 Debug Thermostat Update OK, got info on 1 devices
Ecobee 2 Debug Thermostat Update, thermostats =
{u'511880787182': {'hvacMode': u'cool', 'brand': u'ecobee', 'desiredFanMode': u'auto', 'desiredHeat': 700, 'equipmentStatus': u'', 'remotes': {u'HNPY': {u'name': u'guest room bee', u'occupancy': u'false', u'temperature': u'741'}}, 'internal': {u'temperature': u'738', u'occupancy': u'false', u'humidity': u'54'}, 'currentClimate': u'home', 'latestEventType': u'hold', 'name': u'Thermostat', 'desiredCool': 770, 'modelNumber': u'apolloSmart', 'actualTemperature': 739, 'fanMinOnTime': 0, 'actualHumidity': 54}}
Error device "Ecobee Thermostat (511880787182)" state key device_type not defined (ignoring update request)
Error device "Ecobee Thermostat (511880787182)" state key climate not defined (ignoring update request)
Error device "Ecobee Thermostat (511880787182)" state key fanMinOnTime not defined (ignoring update request)
Error device "Ecobee Thermostat (511880787182)" state key equipmentStatus not defined (ignoring update request)
Error device "Ecobee Thermostat (511880787182)" state key autoHome not defined (ignoring update request)
Error device "Ecobee Thermostat (511880787182)" state key autoAway not defined (ignoring update request)
Error device "MBR HVAC ecobee" state key device_type not defined (ignoring update request)
Error device "MBR HVAC ecobee" state key climate not defined (ignoring update request)
Error device "MBR HVAC ecobee" state key fanMinOnTime not defined (ignoring update request)
Error device "MBR HVAC ecobee" state key equipmentStatus not defined (ignoring update request)
Error device "MBR HVAC ecobee" state key autoHome not defined (ignoring update request)
Error device "MBR HVAC ecobee" state key autoAway not defined (ignoring update request)
Mon Oct 29, 2018 7:24 am
Ah. You have an Ecobee 4. You're the first tester with that model. I think that's all fixed in 2.0.4 which I will be releasing later today.
Other than those error messages and some of the device states not being updated, does it seem to be working properly?
Mon Oct 29, 2018 9:55 am
eme jota ce offline
I didn't realize that it's a 4, but it's:
Thermostat Model
ecobee4
Firmware Version
4.2.0.395
Yes. Inidgo is reporting and able to control the set points. Occupancy sensors might not per updating. They seem to indicated occupied, but I'm not sure how long they wait to update to unoccupied. A guest room with remote ecobee sensor was probably unoccupied for an hour or more but still showed an occupied status indicator in Indigo,.
Thanks for all your work on this plugin!
mjc
Mon Oct 29, 2018 1:18 pm
Version 2.0.4 now available: https://github.com/FlyingDiver/Indigo-E ... /tag/2.0.4
Fixed issues with apolloSmart models (Ecobee 4)
Fixed issue with creating actions.
If you have an Ecobee 4, delete your existing thermostat device and recreate it after you install this version.
Mon Oct 29, 2018 1:25 pm
rapamatic offline
It didn't work creating devices for my smart thermostat. Here's the log from device creation, and it is showing null values for temp, state, etc in the device list:
Oct 29, 2018 at 2:21:59 PM
   Ecobee 2 Debug                  getDeviceStateList, typeID = EcobeeThermostat, model = , device_type = None
   SQL Logger                      creating table device_history_725189923 for "new device"
   Ecobee 2                        new device: Starting EcobeeThermostat Device 725189923
   Ecobee 2 Debug                  new device: EcobeeThermostat __init__
   Ecobee 2                        new device: Stopping EcobeeThermostat Device 725189923
   Ecobee 2 Debug                  new device: doing initial config in __init__
   Ecobee 2 Debug                  getDeviceStateList, typeID = EcobeeThermostat, model = ecobee Smart, device_type = None
   Ecobee 2                        Configured Ecobee Master (150992022817)
   SQL Logger                      adding column "humidityinput1" to table device_history_725189923 ("Ecobee Master (150992022817)")
   Ecobee 2                        Ecobee Master (150992022817): Stopping EcobeeThermostat Device 725189923
   Ecobee 2                        Ecobee Master (150992022817): Starting EcobeeThermostat Device 725189923
   Ecobee 2 Debug                  getDeviceStateList, typeID = EcobeeThermostat, model = ecobee Smart, device_type = idtSmart
   Ecobee 2 Debug                  Ecobee Master (150992022817): EcobeeThermostat __init__
   Ecobee 2 Debug                  Ecobee Master (150992022817): adding occupancy device None
   Ecobee 2 Debug                  Ecobee Master (150992022817): adding remote list None
   Ecobee 2 Error                  Error in plugin execution ServerReplacedElem:
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 1179, in deviceUpdated
  File "plugin.py", line 368, in deviceStartComm
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Ecobee 2.indigoPlugin/Contents/Server Plugin/ecobee.py", line 277, in __init__
TypeError: object of type 'NoneType' has no len()
   SQL Logger                      adding column "humidityinputsall" to table device_history_725189923 ("Ecobee Master (150992022817)")
   SQL Logger                      adding column "hvaccoolerison" to table device_history_725189923 ("Ecobee Master (150992022817)")
   SQL Logger                      adding column "hvacdehumidifierison" to table device_history_725189923 ("Ecobee Master (150992022817)")
   SQL Logger                      adding column "hvacfanison" to table device_history_725189923 ("Ecobee Master (150992022817)")
   SQL Logger                      adding column "hvacheaterison" to table device_history_725189923 ("Ecobee Master (150992022817)")
   SQL Logger                      adding column "hvachumidifierison" to table device_history_725189923 ("Ecobee Master (150992022817)")
   SQL Logger                      adding column "climate" to table device_history_725189923 ("Ecobee Master (150992022817)")
   SQL Logger                      adding column "device_type" to table device_history_725189923 ("Ecobee Master (150992022817)")
   SQL Logger                      adding column "equipmentstatus" to table device_history_725189923 ("Ecobee Master (150992022817)")
   Ecobee 2 Debug                  Thermostat Update OK, got info on 3 devices
{u'173448830954': {'hvacMode': u'heat', 'brand': u'ecobee', 'desiredFanMode': u'auto', 'desiredHeat': 720, 'equipmentStatus': u'', 'remotes': {}, 'currentClimate': u'home', 'latestEventType': u'template', 'name': u'Downstairs', 'desiredCool': 750, 'modelNumber': u'idtSmart', 'actualTemperature': 717, 'fanMinOnTime': 15, 'actualHumidity': 46}, u'314784831377': {'hvacMode': u'heat', 'brand': u'ecobee', 'desiredFanMode': u'auto', 'desiredHeat': 690, 'equipmentStatus': u'', 'remotes': {u'G5PH': {u'name': u'Desk', u'occupancy': u'false', u'temperature': u'721'}}, 'internal': {u'temperature': u'674', u'occupancy': u'false', u'humidity': u'55'}, 'currentClimate': u'home', 'latestEventType': u'template', 'name': u'Office', 'desiredCool': 750, 'modelNumber': u'athenaSmart', 'actualTemperature': 697, 'fanMinOnTime': 10, 'actualHumidity': 55}, u'150992022817': {'hvacMode': u'heat', 'brand': u'ecobee', 'desiredFanMode': u'auto', 'desiredHeat': 680, 'equipmentStatus': u'', 'remotes': {}, 'currentClimate': u'home', 'latestEventType': None, 'name': u'Master', 'desiredCool': 740, 'modelNumber': u'idtSmart', 'actualTemperature': 710, 'fanMinOnTime': 15, 'actualHumidity': 50}}
Mon Oct 29, 2018 1:37 pm
Yeah, that's a bug. I can't test for thermostats with no remotes (or without an occupancy sensor) without breaking the Ecobee setup at home. :(
I don't want to push out releases hourly, but if you want to try the fix, grab 2.0.4 and change line 293 of ecobee.py to:
            if remote_list and len(remote_list) > 0:
Mon Oct 29, 2018 1:46 pm
rapamatic offline
I changed line 293, but now I get this error:
  Error                           device "Ecobee Master (150992022817)" state key fanMinOnTime not defined (ignoring update request)
  File "plugin.py", line 139, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Ecobee 2.indigoPlugin/Contents/Server Plugin/ecobee.py", line 561, in update
AttributeError: EcobeeThermostat instance has no attribute 'remotes'
Mon Oct 29, 2018 1:56 pm
Ack. Add the two lines at the end here to make that block of code look like:
            remote_list = dev.pluginProps.get('remotes', None)
            self.logger.debug(u"{}: adding remote list {}".format(dev.name, remote_list))
                self.remotes = {}
                for code, rem_id in remote_list.items():
                    self.remotes[code] = indigo.devices[int(rem_id)]
                self.remotes = None
Mon Oct 29, 2018 2:00 pm
rapamatic offline
Ok, that is working now, although I note that I am seeing error messages about fanminontime - the smart definitely have that capability...
Error                           device "Ecobee Downstairs (173448830954)" state key fanMinOnTime not defined (ignoring update request)
Mon Oct 29, 2018 2:10 pm
OK, I missed that one. Fix is to add the following after line 360 of plugin.py:
            stateList.append({  "Disabled"     : False,
                                "Key"          : "fanMinOnTime",
                                "StateLabel"   : "Minimum fan time",
                                "TriggerLabel" : "Minimum fan time",
                                "Type"         : 100 })
Mon Oct 29, 2018 2:24 pm
rapamatic offline
Alright, all seems to be working now - thanks!
Tue Oct 30, 2018 1:07 pm
Pre-release 2.0.5 now available: https://github.com/FlyingDiver/Indigo-E ... /tag/2.0.5
Fixes for Ecobee Smart devices, or any thermostat with no Remote Sensors.
I think we're getting very close to an actual release. More testing needed!
