Mon Nov 25, 2019 1:14 pm
Busta999 wrote:
shapa wrote:
I've got similar issue - floor heating thermostat keeps resetting to 5C :)
BTW added "Generic Thermostat v2" manually to the XML file, so, for now, the only real issue it an electric floor one.
Any progress on enabling "smart thermostats self-management" - i.e. only to specify heat points (and enable global heating device if required)?
Is it at all possible you set the target set point to include a decimal point in it, i.e. 18.5c 0r 21.5c
I have done a test on a Spirit and if I set TRV target to 18.5c I get weird behaviour, as soon as I set to a whole number it works ok.
My issues with this have stopped since I kept to whole digits...
It's getting near the top of my to-do list to look at. :)
Mon Nov 25, 2019 1:17 pm
Busta999 offline
Autolog - not an issue - there is an easy work around:-)
Sun Jan 05, 2020 3:42 pm
Umtauscher offline
Hi Matt,
it‘s been more than 2 Months now, is there any chance this minor change is released any time soon?
matt (support) wrote:
Strange they are using the manufacture ID, but we'll update Indigo (in 7.4.1) to use the Spirit device definition for that manufacture + model ID combination.
Happy new yer, btw.
Wilhelm
Sun Jan 05, 2020 5:08 pm
That model ID will be in Indigo 7.4.1, which are are (and have been) actively working on finishing since 7.4.0 shipped. No exact ETA though.
Mon Jan 20, 2020 3:47 pm
siclark offline
Hi Jon.
Any chance you can make your request for status not run in a group for all TRVs? With 8, it can take over 10 seconds for all to respond and nothing else runs in that time, adding a noticeable lag to some of my responses.
Thanks, from a nice warm room, whilst the rest of the house is much cooler, which is just what I need.
Fri Jan 31, 2020 9:30 am
siclark offline
Hi Jon. No pressure but just wondering if you saw this?
Fri Jan 31, 2020 12:50 pm
I missed it. :oops:
Good idea; the thought had crossed my mind. :)
What I would actually like is for Indigo to have a priority queuing mechanism for Z-Wave - The status requests could then go on the low priority queue,
I am not sure how easy it will be to implement it but I will see what I can do.
I have a few other things getting in the way at the moment, so it will be a little while before I can do anything on it. :)
Fri Jan 31, 2020 12:59 pm
siclark offline
Cheers. It's not often but there are times when I ask for lights to go off and they sit in a queue for 10 seconds plus which makes people (wife) wonder what's going on and why the stupid* system doesn't work.
I'm also holding off putting another 2 in which would add to this delay.
Fri Feb 07, 2020 2:07 pm
Indigo 7.4.1 is now available and includes the new manufacture / model ID for this module.
Fri Feb 07, 2020 2:57 pm
Umtauscher offline
Thanks fo the info.
Cheers
Wilhelm
Wed Feb 12, 2020 5:14 pm
siclark offline
Hi Jon. Just got my first zigbee temp sensor connected to indigo via Mqtt and Joe’s plugin. It shows as a temperature device but it doesnt appear as an option for a remote temperature sensor in the TRV plugin. What do you need from me to enable?
Cheers. Simon
Thu Feb 13, 2020 1:45 am
Hi Simon,
Do a print to the log of the device details as in:
indigo.server.log(u"Remote Stat Device:\n {}".format(indigo.devices[12345678]))
Replacing 12345678 with the device id and then post the results back here. :)
Thu Feb 13, 2020 2:08 am
siclark offline
Interactive Shell Remote Stat Device:
address : Master
allowOnStateChange : False
allowSensorValueChange : False
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
deviceTypeId : shimValueSensor
displayStateId : sensorValue
displayStateImageSel : TemperatureSensorOn
displayStateValRaw : 19.58
displayStateValUi : 19.6 °C
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1335677605
com.flyingdiver.indigoplugin.shims : (dict)
SupportsOnState : false (bool)
SupportsSensorValue : true (bool)
address : Master (string)
adjustmentFunction : (string)
brokerID : 62320332 (string)
message_type : ##Aqara## (string)
shimSensorPrecision : 1 (string)
shimSensorSubtype : Temperature-C (string)
state_dict_payload_key : temperature.humidity.pressure.battery (string)
state_location : payload (string)
state_location_payload_key : temperature (string)
state_location_payload_type : json (string)
state_location_topic_field : 0 (string)
states_list : (list)
uid_location : topic (string)
uid_location_payload_key : (string)
uid_location_topic_field : 2 (string)
lastChanged : 2020-02-13 06:39:35
lastSuccessfulComm : 2020-02-13 06:39:35
model : MQTT Value Sensor Device
name : Bedroom temperature
onState : None
ownerProps : com.flyingdiver.indigoplugin.shims : (dict)
pluginId : com.flyingdiver.indigoplugin.shims
protocol : Plugin
remoteDisplay : True
sensorValue : 19.58
states : States : (dict)
sensorValue : 19.580000 (real)
sensorValue.ui : 19.6 °C (string)
subModel :
supportsAllOff : False
supportsOnState : False
supportsSensorValue : True
supportsStatusRequest : False
version : None
Thu Feb 13, 2020 2:31 am
Thanks - I will look at adding this in later on today - I am out this morning. :)
Thu Feb 13, 2020 2:41 am
siclark offline
Cheers... no rush at all. Just looking to see how I could use these. They seem to report temperature changes very fast and frequently, so interested on how the battery lasts.
